I just reinstall my XA2 with latest SFOS release and I’m now trying to make Meecast event view working. So, using Storeman, I have installed Meecast, Meecast daemon and Meecast eventview.
Meecast itself works pretty well (I was just adding the “magic” section in his .desktop file to optout from SailJail because Meecast was not able to detect his daemon in Settings > Appearance > Lockscreen widget, I guess an extra permission is needed, probably AppLaunch).
But when I try to use Meecast eventview, I enable it in sfos general settings (in Events view > Weather) and in events view itself I just see “Meecast” (Big, theme color), then next line “Meecast” (small, light gray) and at bottom right “Last update: undefined”…
So I guess the “eventview” part of Meecast is unable to communicate with the daemon. What should I do to make it works?
Getting the same “Last update: undefined”.
But I can’t even update inside the app itself. Non of the weather provider seem to work.
On top of that I can’t even delete any locations due to the missing delete button.
Maybe the great Meecast finally isn’t usable any more.
32-bit/4.5.0.19: FMI, Foreca, OpenWeatherMap and GPS (The Weather Channel) work, yr.no doesn’t, I haven’t tried others.
The delete button is there, just tap blindly or
[root@Sailfish-XA2 nemo]# cd /usr/share/themes/sailfish-default/meegotouch/z1.75/icons
Edit:
64-bit: FMI and Foreca work. On the 10 III it wouldn’t update in the app or Event View but started working after a couple of
pkill meecast
in Terminal.
If the phone gets hot or eats the battery like crazy AND top shows a lot of MeeCast related processes, kill the MeeCast daemon.
I have checked the meecast binaries in /usr/bin and found references to paths with nemo user. I created a symbolic link from defaultuser home to nemo and the event view is working.
This sounds good. Could you write down the code for Terminal to create such link. I think many users will use now meecast because the jolla event weather is down. Thanks in advance. Also the Logo from the used source are not show in meecast under 64bit? Maybe also for this we need a link…?
The link works for me, on Xperia 10 iii with the latest 4.5.0.21 release, and with the modern ‘defaultuser’ home directory rather than the older ‘nemo’. The meecast app seems far more functional than the Jolla Foreca based one, and seeing that they presumably have to pay for access, maybe a good idea would be to re-invigorate and support the meecast solution instead.
I have a Sony Xperia 10 ii with 4.5.0.21 but it not work.
I have now follow link under nemo:
and I have insalled follow apps from https://openrepos.net/
Under home/defaultuser/.share… I could not find files? Is that normal?
I have already checked and in Sony Xperia 10 II with 4.5.0.21 it does work.
/home/defaultuser/.share doesn’t exist do you mean /home/defaultuser/.local/.share ?
Have you reboot (the easiest way)your phone?
You only have to install the following 64 bit packages - the daemon, events view and lock screen; the rest (non64 bit) on OpenRepos seemed to get ticked anyway.
Never use absolute links, if you do not have an explicit reason to do so!
Also, always use symbolic (“soft”) links, if you do not have an explicit reason to use a “hard” link. But that is already the case here.
I found the reason. The folder Nemo was created from me in root and only root could write. Meecast have to create a .cache folder in nemo and this was blocked. Now it works perfekt. Thanks all helpers and a nice rest weekend.
