[4.3.0] Camera & Torch not working
BUILD ID = OS VERSION (Settings > About product): 4.3.0.12(Suomenlinna)
HARDWARE (XA2, X10, X10 II, …): XA2 H113
UI LANGUAGE: English US
REGRESSION: (compared to previous public release: Yes, No, ?): Did a factory reset and installed updates till 4.3.0.12; somewhere between version 3 and version 4 it was working fine - I didn’t test it in all versions.
jolla-camera crashes on startup, I suspect the torch is not working for the same reason.
Have Jolla Camera installed on Sailfish OS 4.3.0.12(Suomenlinna)
  1. Start Camera application
Camera app loads & works fine
Camera app loads & crashes
WORKAROUND:
Root privs required:
devel-su
ssu ar adaptation-common https://releases.jolla.com/releases/4.3.0.12/jolla-hw/adaptation-common/armv7hl/
ssu ur
zypper ref
zypper dup
Note 1:
You may need to run first, if getting error messages on ssu ar:
rm -f /var/cache/ssu/features.ini
ssu ur
Note 2:
If you don’t have zypper installed (root privs required):
pkcon install zypper
Opening jolla-camera from terminal gets me:
[nemo@XperiaXA2 ~]$ jolla-camera
jolla-camera: /usr/share/droidmedia/hybris.c:53: __resolve_sym: Assertion `ptr != NULL’ failed.
Aborted (core dumped)
[nemo@XperiaXA2 ~]$
What I also tried(as described here: Main camera does not start - #31 by peterleinchen):
[nemo@XperiaXA2 ~]$ devel-su; kill -9 $(ps aux | grep .android.hardware.camera. | grep -v grep | tr -s ’ ’ | cut -f2 -
d’ ‘) || kill -9 $(ps aux | grep .android.hardware.camera. | grep -v grep | tr -s ’ ’ | cut -f3 -d’ '); killall
-r .camera.; echo done;
bash: invalid number ‘camerase’
bash: invalid number ‘{provider@2.4-se}’
killall: bad signal name ‘r’
done
[nemo@XperiaXA2 ~]#
but no result.
Hi, did you have advanced camera installed?
previously I hade the same problem as you, I uninstall advanced camera and solve it.
Now I don’t have any problem with torch and camera on XA2 plus with 4.3
Please take a look to this bug report, it is exactly the same:
And for a quick workaround (definitely not a solution, which should be given by @Jolla or at least reacted to) please look here:
I didn’t have advanced camera installed. I don’t even know what that is; is it a sailfish native app or an android app?
Thank you very much, the workaround solved my problem!
I will update the bug report with the workaround.
And I confirm that advanced-camera does not have anything to do with this mismanagement.
Advanced-camera is a very nice enhanced native camera, available from official Jolla store as well as from openrepos.
It’s a salfish app, Who provides more settings for the came
On my two phones (Xperia 10) the same. Both cameras not working with Jolla Camera and Advanced Camera. Torch is also not working.
But both cameras are working fine with Android app “Delta Chat”.
edit: on my wifes phone (Xperia 10), Jolla camera is working fine (both cams), Advanced Camera started OK with main cam, but selfie cam not working. app crashed after few attempts to switch back to main cam. Torch is working.
edit: See here, this solved problems with Jolla camera, torch and video playback. Thanks to @peterleinchen !
Please take a look here for solution by @Jolla
