BUILD ID = OS VERSION (Settings > About product): 4.1.0.24
HARDWARE (XA2, Xperia 10…): Gemini PDA
UI LANGUAGE: Slovak
REGRESSION: (compared to previous public release: Yes, No, ?): 4.0.1.48 OK
The sound doesn’t work
- in sound recordings
- in the video
- in alerts
… nowhere
neither in the speaker nor in the wired headphones. Sound is on - set to on.
I tried to increase/decrease the volume, restart the device, …
Play a music or video, or set an alert.
Play sound.
No sound.
EDIT 1:
pulseaudio --check - is unresponsive (does not print anything)
pulseaudio --start - restarts the device
EDIT 2:
pulseaudio --dump-modules
E: [pulseaudio] ltdl-bind-now.c: Failed to open module /usr/lib/pulse-14.2/modules/module-droid-glue.so: libdroid-util.so: unable to open shared object file: Directory or the file does not exist
E: [pulseaudio] modinfo.c: Failed to open module "/usr/lib/pulse-14.2/modules/module-droid-glue": file not found
E: [pulseaudio] ltdl-bind-now.c: Failed to open module /usr/lib/pulse-14.2/modules/module-policy-enforcement.so: libmeego-common.so: unable to open shared object file: Directory or the file does not exist
E: [pulseaudio] modinfo.c: Failed to open module "/usr/lib/pulse-14.2/modules/module-policy-enforcement": file not found
