BUILD ID = OS VERSION (Settings > About product): 4.1.0.23
HARDWARE (XA2, Xperia 10…): XA2 Plus
UI LANGUAGE: German
I cannot activate dark mode, nothing happens toggling the switch for that in android settings. It is back to disabled if you restart the settings app. This was working in 4.0
- Open android settings (for example using aliendalvik control)
- Go to “display”
- Try setting dark mode to on
Android applications are using dark mode.
Android applications are still white.
Same result on both the 10 III and XA2U.
