[4.0.1] 'Access Events when device is locked' disables 'Quick Events access' from lock screen on unlocked device
REPRODUCIBILITY (% or how often): always
HARDWARE (XA2, Xperia 10…): Jolla Tablet
REGRESSION: (compared to previous public release: Yes, No, ?): yes
If you enable both ‘Quick Events access’ in the Gestures settings, and ‘Access Events when device is locked’ in the Events settings, then go to the lock screen without locking the device, then swipe to the right, you will be looking at the last opened application. You should be looking at the Events view instead.
Events view is opened.
Last application is opened.
Doesn’t seem to be fixed in 4.1.0 yet.
For me it worked in 4.0.1 but not any more in 4.1.0.
i have not seen this issue in 4.0.1, but I am experiencing the same issue. To elaborate, on 4.1.0.24, swiping right to left at the lock screen always takes me to Events, which is normally a left-to-right gesture. So, swiping from the Events side is what takes me to my last screen. The Event peek option is ignored outright.
Now, if I double-tap to lock the device fully, the gestures are correct, and swiping from left to right is event view, right-to-left is last screen. Event peek also works as intended when locked. The rules change when unlocked.
That’s a different issue, reported here:
I’m not able to reproduce it on 4.5.
Just checked and it seems to be fixed!
