[4.0.1.48] VPN losing credentials
REPRODUCIBILITY (% or how often): twice per day
BUILD ID = 4.0.1.48
HARDWARE (XA2, Xperia 10…): Xperia 10
UI LANGUAGE: French
REGRESSION: No Vpn never worked properly
When having two VPN services configured, the credentials of the active VPN are lost after a while.
  1. Configure two VPN services (I’m using Proton VPN with same credentials for both)
  2. Check save login/password checkbox
  3. Switch between the two => No Pb
  4. Check status after few hours. Active VPN is disabled and Sailfish is asking for credentials
  5. Enable the other VPN => it works
  6. Switch back to the faulty VPN => VPN credentials are still requested
Credentials should be stored as checkbox was checked
Credentials are lost but only after a while. Likely a specific event cleared them.
I have had that problem in the past. When it was happening I was using the sailfish utilities app, and then restart in the first restart box that comes up.
thanks. i will try your proposed solution
For me restarting the device (XA2 Ultra, 4.4.0.68) causes OpenVPN configs to be gone.
Edit: So far I have only used OpenVPN I don’t know about other formats.
