OS VERSION: 4.6.0.15
HARDWARE: Xperia 10 iii
I need to extract .xz archives, I would like to share my experience installing xz-utils program from sources
- Do not clone github repository. Download the source package from repo https://tukaani.org/xz/#_source_packages
pkcon install gcc make Install gcc and make.
tar -xf xz-5.8.1.tar.gz uncompress the source package (correct the command with the number of latest release) and cd into it
./configure./configure can give errors. Launch it with MAKE="gmake" ./configure
makeexecute make as default user
devel-su make installexecute make install as root or defaultuser
Now you can extract xz archives and flash also sd cards for your computers directly from archive
Could we evaluate to add this package and let it be used by our sailfish-archive native app?
Erm, xz is available from Jolla repos. No need for a custom build.
pkcon install xz
One can also write a simple python wrapper to do xz extraction.
As a related note, zstd is a bit harder as there is no (python)
support to use the libs already in the system…
(pkcon install could do this, too? - but If i needed to vendor…)
Many thanks! I was searching for it but I still not find “xz” or “xz-utils”.
Can I ask you the very repository? I could add it in my list.
Checking on SFOS 4.4, it’s in the standard ‘jolla’ repo.
Has it been dropped in later releases? I can’t imagine that.
Have you pkcon refreshed before searching?
It’s in the jolla repo on 5.0.0.67.
pkcon search xz
Searching by details
Starting
Refreshing software list
Querying
Finished
Available wordgrinder-0.8+git3-1.2.1.bso.aarch64 (sailfishos-chum) Cell word processor
Installed xz-5.6.2+git1-1.5.1.jolla.aarch64 (installed) LZMA compression utilities
Available xz-debuginfo-5.6.2+git1-1.5.1.jolla.aarch64 (jolla) Debug information for package xz
Available xz-debugsource-5.6.2+git1-1.5.1.jolla.aarch64 (jolla) Debug sources for package xz
Available xz-devel-5.6.2+git1-1.5.1.jolla.aarch64 (jolla) Devel libraries & headers for liblzma
Available xz-doc-5.6.2+git1-1.5.1.jolla.noarch (jolla) Documentation for xz
Installed xz-libs-5.6.2+git1-1.5.1.jolla.aarch64 (installed) Libraries for decoding LZMA compression
Installed xz-lzma-compat-5.6.2+git1-1.5.1.jolla.aarch64 (installed) Older LZMA format compatibility binaries
PS: version info is removed when installing, so:
pkcon install xz
As root/devel-su.
Thank you. Pkcon refresh worked, so it’s better way to install it than to compile them from binaries.
