REPRODUCIBILITY: always
OS VERSION: 5.0.0.62 fresh flashed 5.0.0.61 updated to 62
HARDWARE: Xperia 10 Dual SIM
UI LANGUAGE:DE / german
REGRESSION: yes
At the end of a sentence ending with a dot + if last word is inserted by XT9, there remains the space between the last word and the dot. The space is no more removed when entering the dot.
Have paid version of SFOS 5.0.0.62, XT9 on, language german,
Use an app with text input, e.g. Jolla Notes, E-Mail, To-Do-List, etc.
Enter first letters of last word in a sentence.
Tap on word as it appears in word suggestions.
Enter dot because it’s the last word of sentence.
Space after last word is removed.
Space remains between last word and the dot.
Storeman, Chum, some tweaks, NO Patchmanager
This bug was not present in 4.5.0.24 that I had before for dots, but was always present for exclamation mark. Question mark don’t know.
edit: It seems to affect only Android apps.
@pvuorela I checked it again right now, and this time it also works great at my device, too. It has fixed itself. Will observe today and if it continues working fine then I’ll delete this bug report.
Can confirm on my 10III. Also, after ending a message with an Emoji, next text input won’t be capitalized automatically (so far observed in Android apps only).
Not sure if this is also related, but I just observed that when having selected a wrong suggestion from the dictionary, it helps to just delete the last character (removing the automatically added space after the word) and typing the first different, correct character - it will trigger the dict suggestions again, where it’s possible to select the correct word, which will entirely overwrite the already (and still written) incorrect word.
Hello, I have also this bug with WhatsApp. And during a conversation, I have also another strange behaviour: when I begin a new message, it does not begin with an upper case, and it rewrite quite often one of the last words of the precedent message. (Xperia 10 III)
