Xperia10 after installation bootloader unlock or lock
after end the installation of sailfish in xperia 10, bootloader is unlocked, is more safely if i locking it , how can looking it?
enrico
you cannot have at the same time SFOS and a bootloader locked. And afaik, after unlocking the bootloader, there is no way to relock the bootloader (at least on X10).
See for example
https://forum.sailfishos.org/t/relock-bootloader-failing-xperia-10/7841/3
ok. thank you
enrico
If bootloader can’t be locked after install of Sailfish on Xperia 10 this means that some Android apps will not run on Sailfish. There are apps demanding (for security reasons I guess) the bootloader to be locked in order to run.
Example: I have the app from Swedish oil/fuel company OKQ8 which, when trying to log in with BankID, gives the following error message - “Unable to verify device integrity”.
I assume its the OKQ8-app because I have no problem, so faar, in using BankID to log in to other apps.
That’s not how it works, at all. Android runs inside a virtual machine and does not have access to whether the host OS (SailfishOS) has locked or unlocked bootloader.
