REPRODUCIBILITY (% or how often): always, at least on this device?
BUILD ID = OS VERSION (Settings > About product): 3.4.0.24
HARDWARE (Jolla1, Tablet, XA2,…): XA2
UI LANGUAGE: Finnish
REGRESSION: (compared to previous public release: Yes, No, ?): ??
XA2 battery appears to be particularly affected by cold temperatures, and causes the battery monitor to think the battery is flat. But it’s not flat, it’s just cold. I don’t expect this to be fixed though.
The problem is that when you take the device back to room temperature and let it stay there, booting will fail because something out there appears to think the battery is still flat. It briefly shows 0 % and shuts down immediately. This is probably because the battery hasn’t been charged.
This is actually dangerous because it prevents using the phone also for emergency calls until it has been charged again.
Once charged again, the battery “charges” unusually fast but this is apparently again just some monitoring circuitry (or a silly program somewhere). I charged the battery yesterday evening to 12 % and it is still 12 % now, with Charge monitor application showing voltage at just under 4 volts, meaning it’s far from flat.
Instead of relying on (apparently?) on just the percentage of charge as a condition on shutdown, could you add voltage as well? I suppose the real culprit should be somewhere in firmware and impossible to fix.
Cold weather, like - 13°C.
- Cool the device down to some -13 °C (perhaps freezer would do?) for an hour or two. Wait until it has shut down.
- Warm it up again.
- Try booting.
Sailfish boots normally when battery is warm again.
Charging is required after cold induced increase of internal resistance, even if the battery is warm again.
