OSVERSION: 4.5.0.19
HARDWARE: Sony Xperia 10 II - Dual SIM - xqau52 - xqau52 - 1.0.0.19 - aarch64
UI LANGUAGE: Deutsch (user: de_DE, os: de_DE.utf8)
REGRESSION: not specified
Frame rate is breaking down massively on apps which uses GPS, as soon as they got an GPS fix.
1.Enable GPS
2.Start an GPS using app like Pure Maps an wait for GPS fix
3. Interact with the App (On Pure Maps, go into settings and try to change some things)
EXPECTED RESULTS:
Frame rate of the apps stays at least, similar to that when no GPS fix there. And everything runs smooth and nicely.
ACTUAL RESULTS:
The GPS using app gets very sluggish. Frame rate is dropping. The apps tend to crash (Pure Maps very often).
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: none specified
Further observation: When GPS is running in background and there is a fix, this fix gets interrupted for a very short time when closing another app (or peaking).
Home Encryption: enabled
