This is to announce the 5.0.0.61 SFOS update for Xperia Tama devices: XZ2, XZ2c, and XZ3.
It has undergone minimal testing - just quick checks. Early adopters are welcome to try it and report their experiences. Those preferring to be cautious may want to wait until more users have tested the release.
I have only tested the OTA update via SSH and did not observe whether the screen went blank, as occurred during the previous update.
Please read the instructions before updating via OTA.
Hi rinigus et al, I updated my xz2c with no problems from 4.6.0.15. I had a jolla repo for adaptation0 and I found the rpm by following the link provided back to the parent folders to 4.6 arch64. Everything seems to be in order. Thanks a lot.
@rinigus I would like to thank you for your efforts on the great XZ2 Compact port. One question remains for me: Is there a complete flash archive with the current version 5.0.0.67 so that someone is not forced to do the update tango from 4.x to the latest version?
No, there is none. I am currently working on another port and don’t have time to work on this as well. So, if these images would to appear, someone has to step up and help to maintain it.
I don’t know whether it is supported with SODP. And as time is limited, I have stopped further development on Tama. So, don’t expect new features appearing on it unless you are ready to do it yourself. I’ll be happy to merge tested changes
I followed instructions and everything is ok, thanks Rinigus. At the moment I’m not using this as my main phone, so it’s sitting there turned off. Every few weeks I power on but the battery is always flat. Is this normal to lose charge while “off’?
I keep getting PMs regarding Sony Tama 5.1 SFOS release. As there is nothing private in those messages, please keep to a simple rule: ask publicly. Its a forum and reply maybe of interest to someone else too. Or maybe someone else will reply to you. Unless you need to share some private information (location related, some log with your phone number, …), keep discussion public.
Now on topic. While my daily driver is Nagara, I did work a bit on 5.1. When testing dev build it resulted in me having to reflash the phone back to 5.0 - couldn’t debug it at that time. Right now working on my apps, but hopefully will return to this port to finish the update. No promises on timing and you are always welcome to work on it too. Right now it was having screen going blank in 5.1 as soon as I tried to enter my decryption passkey on boot.
I’ve tried it for h9493 (HK 6/64gb version), it boots, I just had to flash images manually (and, to mention, shell script requires unavailable im001 image for system_b, I don’t know what it’s used for, but it’s absence doesn’t affect the boot). Bugs are the same as for any other XZ3, but it usually glitches in use (not only during boot) through the system, and, for me, Fingerprint doesn’t work in settings or dedicated app, it doesn’t see me trying to add a new FP. Unfortunately, I didn’t check it on stock Android, so, I would later do some diagnostic. Can I assure myself if it’s a software or a hardware problem?
