hi, after last upgrade i have some issue with my xperia 10, touch screen doesn’t respond like before, is slow, and many time i need to go in sleep mode and wake up it an other time for use it .
some tip?
some tip?
It is probably just bent. (See the half-dozen other threads on the topic)
well, i don’t believe, because is happened after upgrade and with second wake up, it working for a bit.
But in the case , how is possible solving?
Enrico
Slightly bend it. To the backside
I was also sure an update caused problems with my X10. But then I bent it slightly, and it worked again. I had to do that more and more often, until phone became just unusable. Unfortunately it is such a bad hardware this model.
ok, seem working better. thank you
Enrico
