Hi all,
I was a Sailfish user on the Jolla 1 and C but haven’t used it on Sony devices so have been out of touch a little, but am considering jumping back in with the Xperia 10 III.
I can’t obviously find a list of “things” (for lack of a better word) that might be expected to be supported, given what’s either supported on the Android side or that are supported in previous devices on SFOS/N9.
Can anyone confirm whether I can expect these? (my assumptions based on searches in brackets)
- Double tap to wake (no? allegedly not supported on the 10 II)
- Low Power Mode / Glance Screen, especially with infinite timeout to emulate N9’s always-on standby screen (yes? can use mce-power-tool apparently, does it use vast amounts of battery?)
- USB-C support:
- Inputs: keyboard + mouse (yes?)
- Output: video out (no?)
- A menu to select if I give/receive charge to/from another device I plug it directly into (??)
- NFC (yes)
- In Android apps (??)
- Fingerprint sensor (yes)
- Bluetooth support:
- Are codecs as per the Android side, or does SFOS have its own subset? SBC and aptX? (??)
- BLE support in alien dalvik so an Android app can get data off my Mi Band (5)? And a bike navigation widget I’ve ordered which I think is also BLE? (no? could a sfos app do it?)
- Google assistant hardware button mappable in SFOS?
- HDR (no?)
- 5G (no?)
- 120fps video recording (??)
Thanks in advance for answers, or pointing me to a wiki page I’ve missed!
