I just recently bought the Sailfish for the 10 III and was trying to flash it to my device.
Following instructions here: How to install Sailfish X on Xperia™ 10 III on Linux - Jolla
But after flashing started I got the following error:
sudo bash ./flash.sh 1 ✘ 4s
Flash utility v1.2
Detected Linux
Searching device to flash…
Found XQ-BT52, serial:XXX, baseband:62.1.A.0.587, bootloader:1322-1665_X_Boot_SM6350_LA2.0.1_S_108
Found matching device with serial XXX
Fastboot command: fastboot -s XXXX
>> fastboot -s XXX getvar secure
<< secure: no
>> fastboot -s XXX flash:raw boot_a hybris-boot.img
Sending ‘boot_a’ (25800 KB) FAILED (Status read failed (No such device))
fastboot: error: Command failed
Flashing failed (1)
Tried different ports + different cables, what could be the reason ?
Using Manjaro Linux
