REPRODUCIBILITY: 100 %
OS VERSION: 4.4.0.68
HARDWARE: Sony Xperia 10 II
UI LANGUAGE: English
REGRESSION: Unknown (new secondhand device)
When I check which cores are running (e.g. with htop), it always shows all 8 cores are on. This is despite the fact that the load average is usually quite low (around 3), so it definitely doesn’t need this horsepower. My old XA2 Plus didn’t do this, and also my wife’s 10 does not.
I have reflashed SFOS to make sure it’s not something I installed.
An Xperia 10 II with SFOS running
Start htop in the terminal (or over ssh)
locate the charger
plug it in before the battery is empty!
The number of running cores should vary depending on the load
All cores are always on
None. Stock SFOS, developer mode on and htop installed
[ 584.833648] Freezing user space processes ... (elapsed 0.034 seconds) done.
[ 584.868188] OOM killer disabled.
[ 584.868191] Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
[ 584.872202] Suspending console(s) (use no_console_suspend to debug)
[ 584.905923] Disabling non-boot CPUs ...
[ 584.908398] CPU1: shutdown
[ 584.913637] CPU2: shutdown
[ 584.919027] CPU3: shutdown
[ 584.923651] CPU4: shutdown
[ 584.927523] CPU5: shutdown
[ 584.931427] CPU6: shutdown
[ 584.935013] CPU7: shutdown
[ 584.938707] suspend ns: 584938696744 suspend cycles: 23409443172
[ 584.938696] resume cycles: 23411635310
[ 584.939621] Enabling non-boot CPUs ...
[ 584.941739] cache: parent cpu1 should not be sleeping
[ 584.942400] CPU1 is up
[ 584.943925] cache: parent cpu2 should not be sleeping
[ 584.944621] CPU2 is up
[ 584.946204] cache: parent cpu3 should not be sleeping
[ 584.946905] CPU3 is up
[ 584.948153] arch_timer: CPU4: Trapping CNTVCT access
[ 584.948669] cache: parent cpu4 should not be sleeping
[ 584.949371] CPU4 is up
[ 584.950125] arch_timer: CPU5: Trapping CNTVCT access
[ 584.950479] cache: parent cpu5 should not be sleeping
[ 584.951024] CPU5 is up
[ 584.951835] arch_timer: CPU6: Trapping CNTVCT access
[ 584.952149] cache: parent cpu6 should not be sleeping
[ 584.952794] CPU6 is up
[ 584.953513] arch_timer: CPU7: Trapping CNTVCT access
[ 584.953842] cache: parent cpu7 should not be sleeping
[ 584.954995] CPU7 is up
[ 584.995623] OOM killer enabled.
[ 584.995627] Restarting tasks ... done.
[ 585.016702] PM: PM: suspend exit 2022-09-17 18:29:54.113981794 UTC
[ 585.016706] PM: suspend exit
[ 585.065376] ## mmc1: mmc_gpio_set_uim2_en: gpio=101 value=1
Note: I’ve also contacted Jolla support, as this issue is quite problematic if you’re out for the day. You will not get through the day without carrying a battery pack. They did not have a solution, and instead told me to report it on the forum.
I know it’s not an answer but I wonder if the update to .72 might be of assitance? I’m looking at my 10ii , but it’s already at .72.
I can briefly max out all cores resizing video (8 cores), but then generally 3-4 are idle.
.72 has exactly the same issue. Whenever the phone is awake, all cores are on, unlike on XA2 or 10, which enabled core on-demand.
Ok, thanks. Create a list of installed packages, perhaps?
On the other hand, the XA2 tends to use very low clock speeds whenever possible, which makes it so sluggish. Recently, just for test, I switched all its cores to performance governor and its UI became almost as fluid and responsive as the 10 III, whereas its power consumption didn’t rise that much. For instance, I then watched several hours of streamed video via an Android VOD app and it only ate some 30% of battery. And when idle, I couldn’t really spot any noticeable difference compared to its default interactive governor.
Sure, I’ve made a list. There’s some packages I installed manually in there, but the problem occurs directly after installation, so I don’t think it has anything to do with any of these packages.
PackageKit-1.1.13+git14-1.5.2.jolla.aarch64
PackageKit-Qt5-0.9.6+git-1.5.2.jolla.aarch64
PackageKit-glib-1.1.13+git14-1.5.2.jolla.aarch64
PackageKit-zypp-1.1.13+git14-1.5.2.jolla.aarch64
SDL2-2.0.18+git1-1.8.2.jolla.aarch64
SDL2_gfx-1.0.4+git2-1.6.2.jolla.aarch64
SDL2_image-2.0.5+git1-1.6.2.jolla.aarch64
SDL2_mixer-2.0.4+git2-1.6.2.jolla.aarch64
SDL2_net-2.0.1+git2-1.6.2.jolla.aarch64
SDL2_ttf-2.0.15+git2-1.6.2.jolla.aarch64
alienaudioservice-0.18.0-1.4.3.jolla.aarch64
alienaudioservice-plugin-sailfish-0.6.0-1.3.2.jolla.aarch64
aliendalvik-1.2.0-1.3.2.jolla.aarch64
aliendalvik-configs-10.0.59.1-1.5.2.jolla.aarch64
aliendalvik-system-10.0.0.62.1.4-1.9.1.jolla.aarch64
alienkeyboardservice-0.11-1.2.3.jolla.aarch64
all-translations-pack-0.8.1-1.4.13.jolla.noarch
alsa-lib-1.2.3.2+git1-1.6.2.jolla.aarch64
ambienced-0.29.29-1.6.3.jolla.aarch64
apkd8-10.0.0.47.1-1.8.2.jolla.aarch64
apkd8-android-settings-10.0.0.47.1-1.8.2.jolla.aarch64
apkd8-l10n-all-translations-1.59-1.5.2.jolla.noarch
archivemount-0.8.7+git2-1.6.2.jolla.aarch64
audiosystem-passthrough-1.3.0-1.6.2.jolla.aarch64
audiosystem-passthrough-dummy-af-1.3.0-1.6.2.jolla.aarch64
audit-libs-2.8.4+git8-1.9.3.jolla.aarch64
basesystem-11+git1-1.6.2.jolla.noarch
binder-utils-1.0.0-1.2.2.jolla.aarch64
bluebinder-1.0.12-1.2.3.jolla.aarch64
bluez5-5.58+git4-1.7.13.jolla.aarch64
bluez5-libs-5.58+git4-1.7.13.jolla.aarch64
bluez5-obexd-5.58+git4-1.7.13.jolla.aarch64
boost-atomic-1.66.0+git2-1.7.1.jolla.aarch64
boost-chrono-1.66.0+git2-1.7.1.jolla.aarch64
boost-date-time-1.66.0+git2-1.7.1.jolla.aarch64
boost-system-1.66.0+git2-1.7.1.jolla.aarch64
boost-thread-1.66.0+git2-1.7.1.jolla.aarch64
busybox-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-bash-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-coreutils-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-dhcp-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-diffutils-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-dosfstools-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-findutils-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-grep-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-gzip-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-procps-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-psmisc-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-sed-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-tar-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-vi-1.33.1+git3-1.7.14.jolla.aarch64
busybox-symlinks-which-1.33.1+git3-1.7.14.jolla.aarch64
buteo-mtp-qt5-0.9.3-1.8.2.jolla.aarch64
buteo-sync-plugin-caldav-0.2.8-1.10.2.jolla.aarch64
buteo-sync-plugin-carddav-0.1.7-1.9.2.jolla.aarch64
buteo-sync-plugin-nextcloud-backup-1.0.0-1.5.2.jolla.aarch64
buteo-sync-plugin-nextcloud-images-1.0.0-1.5.2.jolla.aarch64
buteo-sync-plugin-nextcloud-posts-1.0.0-1.5.2.jolla.aarch64
buteo-sync-plugin-webcal-0.1.10-1.8.2.jolla.aarch64
buteo-sync-plugins-email-0.1.9-1.9.2.jolla.aarch64
buteo-sync-plugins-social-0.4.17-1.14.2.jolla.aarch64
buteo-sync-plugins-social-dropbox-0.4.17-1.14.2.jolla.aarch64
buteo-sync-plugins-social-google-0.4.17-1.14.2.jolla.aarch64
buteo-sync-plugins-social-onedrive-0.4.17-1.14.2.jolla.aarch64
buteo-sync-plugins-social-twitter-0.4.17-1.14.2.jolla.aarch64
buteo-sync-plugins-social-vk-0.4.17-1.14.2.jolla.aarch64
buteo-syncfw-qt5-0.10.13-1.17.22.jolla.aarch64
buteo-syncfw-qt5-msyncd-0.10.13-1.17.22.jolla.aarch64
bzip2-1.0.8+git1-1.6.2.jolla.aarch64
bzip2-libs-1.0.8+git1-1.6.2.jolla.aarch64
ca-certificates-2021.2.50-1.6.2.jolla.noarch
cairo-1.16.0+git1-1.6.2.jolla.aarch64
calligra-components-3.2.1+git3-1.11.2.jolla.aarch64
calligra-data-3.2.1+git3-1.11.2.jolla.aarch64
calligra-filters-3.2.1+git3-1.11.2.jolla.aarch64
calligra-kf5-3.2.1+git3-1.11.2.jolla.aarch64
calligra-libs-3.2.1+git3-1.11.2.jolla.aarch64
calligra-plugins-3.2.1+git3-1.11.2.jolla.aarch64
calligra-sheets-core-3.2.1+git3-1.11.2.jolla.aarch64
calligra-stage-core-3.2.1+git3-1.11.2.jolla.aarch64
calligra-words-core-3.2.1+git3-1.11.2.jolla.aarch64
collectd-5.12.0.sfos.5-1.4.1.jolla.aarch64
commhistory-daemon-0.8.44-1.12.2.jolla.aarch64
connectionagent-qt5-0.11.42-1.6.2.jolla.aarch64
connectionagent-qt5-declarative-0.11.42-1.6.2.jolla.aarch64
connman-1.32+git187-1.17.2.jolla.aarch64
connman-configs-sailfish-0.11.3.1-1.6.2.jolla.noarch
connman-network-monitor-0.0.0+git2-1.6.2.jolla.aarch64
connman-plugin-vpn-l2tp-1.32+git187-1.17.2.jolla.aarch64
connman-plugin-vpn-openconnect-1.32+git187-1.17.2.jolla.aarch64
connman-plugin-vpn-openvpn-1.32+git187-1.17.2.jolla.aarch64
connman-plugin-vpn-pptp-1.32+git187-1.17.2.jolla.aarch64
connman-plugin-vpn-vpnc-1.32+git187-1.17.2.jolla.aarch64
connman-qt5-1.2.39-1.6.2.jolla.aarch64
connman-qt5-declarative-1.2.39-1.6.2.jolla.aarch64
connman-vpn-scripts-1.32+git187-1.17.2.jolla.aarch64
contactsd-1.4.10-1.14.2.jolla.aarch64
crda-4.14+git5-1.7.4.jolla.aarch64
cryptsetup-libs-2.3.4+git1-1.5.2.jolla.aarch64
csd-0.16.29-1.4.28.jolla.aarch64
curl-7.81.0+git1-1.8.2.jolla.aarch64
db4-4.8.30-1.6.2.jolla.aarch64
db4-utils-4.8.30-1.6.2.jolla.aarch64
dbus-1.13.12+git6-1.6.13.jolla.aarch64
dbus-glib-0.100.2-1.5.2.jolla.aarch64
dbus-libs-1.13.12+git6-1.6.13.jolla.aarch64
dconf-0.40.0+git4-1.9.2.jolla.aarch64
declarative-transferengine-qt5-1.0.3-1.8.3.jolla.aarch64
deltarpm-3.6.3+git1-1.7.15.jolla.aarch64
desktop-file-utils-0.26+git4-1.8.2.jolla.aarch64
device-mapper-2.02.177+git6-1.8.2.jolla.aarch64
device-mapper-event-2.02.177+git6-1.8.2.jolla.aarch64
device-mapper-event-libs-2.02.177+git6-1.8.2.jolla.aarch64
device-mapper-libs-2.02.177+git6-1.8.2.jolla.aarch64
droid-config-xqau52-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-bluez5-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-flashing-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-policy-settings-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-preinit-plugin-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-pulseaudio-settings-0.1.24.3-1.7.2.jolla.aarch64
droid-config-xqau52-sailfish-0.1.24.3-1.7.2.jolla.noarch
droid-hal-pdx201-0.0.20-1.6.6.jolla.aarch64
droid-hal-pdx201-img-boot-0.0.4-1.3.86.jolla.aarch64
droid-hal-pdx201-img-recovery-0.0.4-1.3.86.jolla.aarch64
droid-hal-pdx201-kernel-dtbo-0.0.20-1.6.6.jolla.aarch64
droid-hal-pdx201-tools-0.0.20-1.6.6.jolla.aarch64
droid-hal-pdx201-users-0.0.20-1.6.6.jolla.aarch64
droid-hal-version-xqau52-0.0.2-1.3.152.jolla.aarch64
droid-system-pdx201-0.1.9-1.6.2.jolla.aarch64
droid-system-pdx201-xqau52-0.1.9-1.6.2.jolla.aarch64
droidmedia-0.20211101.0-1.5.2.jolla.aarch64
dsme-0.84.0-1.7.2.jolla.aarch64
dummy_netd-1.0.1-1.2.3.jolla.aarch64
e2fsprogs-1.45.4+git2-1.5.2.jolla.aarch64
e2fsprogs-libs-1.45.4+git2-1.5.2.jolla.aarch64
embedlite-components-qt5-1.24.33-1.35.2.jolla.aarch64
eventsview-extensions-0.1.9-1.3.2.jolla.aarch64
eventsview-extensions-nextcloud-1.0.0-1.5.2.jolla.aarch64
eventsview-extensions-twitter-posts-0.1.9-1.3.2.jolla.aarch64
eventsview-extensions-vk-posts-0.1.9-1.3.2.jolla.aarch64
exempi-2.5.2+git1-1.9.2.jolla.aarch64
expat-2.2.9+git1-1.6.2.jolla.aarch64
farstream-0.2.9+git1-1.6.2.jolla.aarch64
feature-alien-0.4.2-1.3.2.jolla.aarch64
feature-jolla-0.1.5-1.3.38.jolla.noarch
feature-sailfish-eas-0.0.9-1.3.2.jolla.aarch64
feature-xt9-0.0.7-1.3.2.jolla.aarch64
ffmpeg-4.4.1+git2-1.7.2.jolla.aarch64
file-5.37+git4-1.6.2.jolla.aarch64
file-libs-5.37+git4-1.6.2.jolla.aarch64
filesystem-3.16+git1-1.9.2.jolla.aarch64
fingerterm-1.4.3-1.8.2.jolla.aarch64
firejail-0.9.66+git2-1.7.2.jolla.aarch64
flac-1.3.3-1.5.2.jolla.aarch64
fontconfig-2.13.1+git3.1-1.6.2.jolla.aarch64
fontpackages-filesystem-1.44-1.6.1.jolla.noarch
freetype-2.10.4+git1-1.5.2.jolla.aarch64
fribidi-1.0.10+git2-1.7.2.jolla.aarch64
fuse-2.9.9+git2-1.6.16.jolla.aarch64
fuse-common-3.9.0+git1-1.6.12.jolla.aarch64
fuse-libs-2.9.9+git2-1.6.16.jolla.aarch64
gawk-1:3.1.5-1.6.2.jolla.aarch64
gecko-camera-0.1.4-1.4.9.jolla.aarch64
gecko-camera-droid-plugin-0.1.4-1.4.2.jolla.aarch64
geoclue-0.12.99.7-1.6.2.jolla.aarch64
geoclue-provider-hybris-binder-0.2.35-1.5.2.jolla.aarch64
geoclue-provider-mlsdb-0.1.7-1.5.2.jolla.aarch64
geoclue-provider-mlsdb-agreements-0.1.7-1.5.2.jolla.aarch64
giflib-5.2.1+git1-1.7.2.jolla.aarch64
glib-networking-2.63.3+git1-1.5.2.jolla.aarch64
glib2-2.66.2+git2-1.5.2.jolla.aarch64
glibc-2.30+git11-1.10.2.jolla.aarch64
glibc-common-2.30+git11-1.10.2.jolla.aarch64
gmime-2.6.20+git1-1.6.2.jolla.aarch64
gmp-droid-0.5.1-1.4.2.jolla.aarch64
gnupg2-1:2.0.4+git4-1.7.4.jolla.aarch64
gpgme-1.2.0+git7-1.7.2.jolla.aarch64
graphite2-1.3.14+git2-1.6.2.jolla.aarch64
gstreamer1.0-1.18.5+git1-1.7.12.jolla.aarch64
gstreamer1.0-droid-0.20211101.0-1.3.2.jolla.aarch64
gstreamer1.0-libav-1.18.5+git1-1.7.2.jolla.aarch64
gstreamer1.0-plugins-bad-1.18.5+git1-1.7.2.jolla.aarch64
gstreamer1.0-plugins-base-1.18.5+git2-1.7.4.jolla.aarch64
gstreamer1.0-plugins-good-1.18.5+git2-1.7.2.jolla.aarch64
harbour-advanced-camera-0.9.8-1.4.1.jolla.aarch64
harbour-aenigma-0.4.0-1.4.1.jolla.aarch64
harbour-amazfish-2.1.0-1.4.1.jolla.aarch64
harbour-batterybuddy-4.1.1-1.aarch64
harbour-fahrplan2-2.0.44-1.aarch64
harbour-fernschreiber-0.16-4.aarch64
harbour-hackernews-1.2.0-1.noarch
harbour-osmscout-server-2.2.0-1.6.1.jolla.aarch64
harbour-pure-maps-3.1.1-1.7.1.jolla.aarch64
harbour-sailfishconnect-0.6.2-1.aarch64
harbour-sailhub-0.1.3+main.20220108131006.2.g59ac8ea-1.3.1.jolla.aarch64
harbour-sailotp-1.9.4-1.aarch64
harbour-sfos-forum-viewer-1.5.0-1.noarch
harbour-storeman-0.3.1-1.10.1.jolla.aarch64
harbour-whisperfish-0.6.0.beta.12-0.sf4.aarch64
harbour-wordle-1.0.11-1.12.1.jolla.aarch64
harfbuzz-2.7.2+git1-1.5.2.jolla.aarch64
htop-3.0.2+git2-1.3.2.jolla.aarch64
hwdata-0.335-1.6.2.jolla.noarch
hybris-libsensorfw-qt5-binder-0.12.6-1.5.2.jolla.aarch64
iproute-3.7.0+git6.1-1.7.2.jolla.aarch64
iptables-1.8.7+git1-1.7.2.jolla.aarch64
iptables-ipv6-1.8.7+git1-1.7.2.jolla.aarch64
iw-5.0.1+git2-1.7.2.jolla.aarch64
jolla-actdead-charging-0.13.12-1.2.2.jolla.aarch64
jolla-alarm-ui-0.2.16-1.4.2.jolla.aarch64
jolla-alarm-ui-all-translations-pack-0.8.1-1.4.5.jolla.noarch
jolla-ambient-sound-theme-0.0.17-1.2.2.jolla.noarch
jolla-ca-0.11-1.4.2.jolla.noarch
jolla-calculator-1.0.8-1.4.2.jolla.aarch64
jolla-calculator-all-translations-pack-0.8.1-1.4.4.jolla.noarch
jolla-calendar-1.0.36-1.6.2.jolla.aarch64
jolla-calendar-all-translations-pack-0.8.1-1.4.5.jolla.noarch
jolla-camera-1.2.16.3-1.9.2.jolla.aarch64
jolla-camera-lockscreen-1.2.16.3-1.9.2.jolla.aarch64
jolla-camera-settings-1.2.16.3-1.9.2.jolla.aarch64
jolla-clock-1.1.19-1.4.2.jolla.aarch64
jolla-clock-all-translations-pack-0.8.1-1.4.5.jolla.noarch
jolla-common-configurations-0.11.3.1-1.6.2.jolla.noarch
jolla-contacts-0.6.36-1.6.2.jolla.aarch64
jolla-contacts-settings-0.6.36-1.6.2.jolla.aarch64
jolla-developer-mode-0.6.21-1.2.20.jolla.aarch64
jolla-developer-mode-preload-0.6.21-1.2.20.jolla.aarch64
jolla-developer-mode-profile-0.6.21-1.2.20.jolla.aarch64
jolla-email-1.1.29-1.8.2.jolla.aarch64
jolla-email-all-translations-pack-0.8.1-1.4.5.jolla.noarch
jolla-email-settings-1.1.29-1.8.2.jolla.aarch64
jolla-gallery-1.1.0-1.6.2.jolla.aarch64
jolla-gallery-ambience-0.2.35-1.3.2.jolla.aarch64
jolla-gallery-extension-nextcloud-1.0.0-1.5.2.jolla.aarch64
jolla-gallery-extensions-0.2.14-1.2.2.jolla.aarch64
jolla-gallery-extensions-dropbox-0.2.14-1.2.2.jolla.aarch64
jolla-gallery-extensions-onedrive-0.2.14-1.2.2.jolla.aarch64
jolla-gallery-extensions-vk-0.2.14-1.2.2.jolla.aarch64
jolla-handwriting-0.1.5-1.3.2.jolla.aarch64
jolla-keyboard-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-hwr-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-all-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-chinese-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-indian-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-kazakh-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-russian-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-tatar-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-layout-western-0.8.28.3-1.7.2.jolla.aarch64
jolla-keyboard-settings-xt9-0.8.28.3-1.7.2.jolla.aarch64
jolla-messages-1.1.60-1.6.2.jolla.aarch64
jolla-messages-settings-1.1.60-1.6.2.jolla.aarch64
jolla-notes-1.0.20-1.5.2.jolla.aarch64
jolla-notes-all-translations-pack-0.8.1-1.4.4.jolla.noarch
jolla-notes-settings-1.0.20-1.5.2.jolla.aarch64
jolla-sessions-qt5-1.4.21-1.3.2.jolla.aarch64
jolla-settings-1.1.15.1-1.5.2.jolla.aarch64
jolla-settings-accounts-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-3rd-party-all-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-dropbox-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-email-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-fruux-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-google-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-jabber-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-jolla-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-memotoo-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-onedrive-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-onlinesync-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-twitter-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-vk-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-webcal-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-accounts-extensions-yahoo-0.4.57.2-1.7.1.jolla.aarch64
jolla-settings-bluetooth-0.2.15-1.3.2.jolla.aarch64
jolla-settings-layout-1.1.15.1-1.5.2.jolla.aarch64
jolla-settings-networking-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-multisim-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-plugin-vpn-l2tp-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-plugin-vpn-openconnect-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-plugin-vpn-openvpn-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-plugin-vpn-pptp-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-networking-plugin-vpn-vpnc-1.0.1.1-1.5.2.jolla.aarch64
jolla-settings-sailfishos-0.2.25-1.3.23.jolla.aarch64
jolla-settings-system-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-about-eula-sailfish-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-about-package-licenses-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-about-product-license-jolla-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-about-product-trademark-jolla-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-developermode-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-flashlight-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-nfc-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-system-sideloading-1.1.51.2-1.9.4.jolla.aarch64
jolla-settings-transferui-qt5-1.0.3-1.8.3.jolla.aarch64
jolla-signon-ui-0.2.12-1.3.2.jolla.aarch64
jolla-startupwizard-0.4.40-1.3.2.jolla.aarch64
jolla-vault-1.1.42-1.3.3.jolla.aarch64
jolla-vault-units-1.1.42-1.3.3.jolla.aarch64
jolla-xt9-0.5.19-1.5.2.jolla.aarch64
jolla-xt9-cp-0.2.12-1.3.2.jolla.aarch64
jolla-xt9-server-0.5.19-1.4.61.jolla.aarch64
json-c-0.15+git1-1.5.2.jolla.aarch64
json-glib-1.6.0+git1-1.5.2.jolla.aarch64
kcoreaddons-5.34.0-1.1.1.jolla.aarch64
kdb-sqlite3-driver-3.1.0-1.1.1.jolla.aarch64
kf5-calendarcore-5.86+git3-1.9.2.jolla.aarch64
kf5bluezqt-bluez5-5.24.0+git18-1.5.2.jolla.aarch64
kf5bluezqt-bluez5-declarative-5.24.0+git18-1.5.2.jolla.aarch64
kmod-27+git1-1.7.2.jolla.aarch64
kmod-libs-27+git1-1.7.2.jolla.aarch64
libKDb3-3-3.1.0-1.1.1.jolla.aarch64
libaccounts-glib-1.24+git5-1.5.2.jolla.aarch64
libaccounts-glib-tools-1.24+git5-1.5.2.jolla.aarch64
libaccounts-qt5-1.16+git3-1.7.2.jolla.aarch64
libacl-2.2.53-1.7.12.jolla.aarch64
libalienaudioservice-0.18.0-1.4.3.jolla.aarch64
libarchive-3.4.0+git1-1.6.2.jolla.aarch64
libasyncns-0.8-1.6.2.jolla.aarch64
libattr-2.4.47+git2-1.7.2.jolla.aarch64
libblkid-2.33+git4-1.8.7.jolla.aarch64
libblockdev-2.26+git1-1.6.2.jolla.aarch64
libblockdev-crypto-2.26+git1-1.6.2.jolla.aarch64
libblockdev-fs-2.26+git1-1.6.2.jolla.aarch64
libblockdev-loop-2.26+git1-1.6.2.jolla.aarch64
libblockdev-part-2.26+git1-1.6.2.jolla.aarch64
libblockdev-swap-2.26+git1-1.6.2.jolla.aarch64
libblockdev-utils-2.26+git1-1.6.2.jolla.aarch64
libcanberra-0.30+git2-1.7.2.jolla.aarch64
libcap-2.25+git2-1.7.2.jolla.aarch64
libcap-ng-0.7.9+git3-1.6.14.jolla.aarch64
libcom_err-1.45.4+git2-1.5.2.jolla.aarch64
libcommhistory-qt5-1.11.11.1-1.12.2.jolla.aarch64
libcommhistory-qt5-declarative-1.11.11.1-1.12.2.jolla.aarch64
libcommhistory-qt5-tools-1.11.11.1-1.12.2.jolla.aarch64
libcontentaction-qt5-0.4.5-1.8.2.jolla.aarch64
libcurl-7.81.0+git1-1.8.2.jolla.aarch64
libdbus-qeventloop-qt5-1.31.0-1.9.2.jolla.aarch64
libdbusaccess-1.0.14-1.5.2.jolla.aarch64
libdbuslogserver-dbus-1.0.21-1.5.2.jolla.aarch64
libdbuslogserver-gio-1.0.21-1.5.2.jolla.aarch64
libdres-1.1.17-1.5.2.jolla.aarch64
libdrm-2.4.107+git1-1.6.2.jolla.aarch64
libdsme-0.66.6-1.5.2.jolla.aarch64
libexif-0.6.22+git2-1.5.2.jolla.aarch64
libfdisk-2.33+git4-1.8.7.jolla.aarch64
libffi-3.2.1+git1.1-1.7.2.jolla.aarch64
libgbinder-1.1.18-1.5.2.jolla.aarch64
libgbinder-radio-1.4.10-1.5.2.jolla.aarch64
libgbinder-tools-1.1.18-1.5.2.jolla.aarch64
libgcc-8.3.0-1.7.22.jolla.aarch64
libgcrypt-1.8.6+git2-1.6.2.jolla.aarch64
libglibutil-1.0.62-1.13.2.jolla.aarch64
libgofono-2.1.1-1.6.2.jolla.aarch64
libgofonoext-1.0.12-1.5.2.jolla.aarch64
libgpg-error-1.27+git3.1-1.8.2.jolla.aarch64
libgsf-1.14.47+git1-1.6.2.jolla.aarch64
libgsupplicant-1.0.22-1.7.2.jolla.aarch64
libgudev-232+git2-1.6.2.jolla.aarch64
libhybris-0.0.5.44.1-1.4.2.jolla.aarch64
libhybris-libEGL-0.0.5.44.1-1.4.2.jolla.aarch64
libhybris-libGLESv2-0.0.5.44.1-1.4.2.jolla.aarch64
libhybris-libhardware-0.0.5.44.1-1.4.2.jolla.aarch64
libhybris-libsync-0.0.5.44.1-1.4.2.jolla.aarch64
libhybris-libwayland-egl-0.0.5.44.1-1.4.2.jolla.aarch64
libical-3.0.9+git2-1.6.2.jolla.aarch64
libicu-68.2+git1-1.6.2.jolla.aarch64
libiodata-qt5-0.19.11+git2-1.7.2.jolla.aarch64
libiphb-1.2.7-1.5.2.jolla.aarch64
libiptcdata-1.0.5+git1-1.5.2.jolla.aarch64
libjollasettingssailfishos-0.2.25-1.3.23.jolla.aarch64
libjollasignontrampolineservice-qt5-0.4.17-1.4.1.jolla.aarch64
libjollasignonuiservice-qt5-0.4.17-1.4.1.jolla.aarch64
libjollasignonuiservice-qt5-plugin-0.4.17-1.4.1.jolla.aarch64
libjpeg-turbo-2.1.0+git1-1.7.12.jolla.aarch64
libkeepalive-1.8.7-1.7.3.jolla.aarch64
libkeepalive-glib-1.8.7-1.7.3.jolla.aarch64
libkf5archive-5.75.0+git1-1.5.2.jolla.aarch64
libksba-1.3.5+git3-1.7.2.jolla.aarch64
liblua-5.3.5-1.7.2.jolla.aarch64
libmce-glib-1.0.12-1.6.2.jolla.aarch64
libmce-qt5-1.4.2-1.6.2.jolla.aarch64
libmce-qt5-declarative-1.4.2-1.6.2.jolla.aarch64
libmlocale-qt5-0.7.4-1.7.2.jolla.aarch64
libmount-2.33+git4-1.8.7.jolla.aarch64
libmpg123-1.25.11+git1-1.7.2.jolla.aarch64
libncicore-1.1.18-1.2.2.jolla.aarch64
libnciplugin-1.1.2-1.4.2.jolla.aarch64
libnemotransferengine-qt5-2.0.0-1.10.3.jolla.aarch64
libngf-0.28-1.5.2.jolla.aarch64
libngf-qt5-0.8.2-1.9.2.jolla.aarch64
libngf-qt5-declarative-0.8.2-1.9.2.jolla.aarch64
libngf-qt5-qtfeedback-0.8.2-1.9.2.jolla.aarch64
libnghttp2-1.41.0+git1-1.5.1.jolla.aarch64
libnice-0.1.17+git4-1.5.14.jolla.aarch64
libnl-3.4.0+git3.1-1.7.2.jolla.aarch64
libofonobinderpluginext-1.1.5-1.4.2.jolla.aarch64
libogg-1.3.4-1.5.2.jolla.aarch64
libpcap-1.9.1+git1-1.6.2.jolla.aarch64
libphonenumber-8.12.33+git1-1.7.15.jolla.aarch64
libphonenumber-geocoding-8.12.33+git1-1.7.15.jolla.aarch64
libpng-1.6.37+git1-1.5.2.jolla.aarch64
libprolog-1.2.1-1.5.2.jolla.aarch64
libpsl-0.21.0+git2-1.6.2.jolla.aarch64
libqmfclient1-qt5-4.0.4+git136-1.9.1.jolla.aarch64
libqmfmessageserver1-qt5-4.0.4+git136-1.9.1.jolla.aarch64
libqofono-qt5-0.112-1.6.2.jolla.aarch64
libqofono-qt5-declarative-0.112-1.6.2.jolla.aarch64
libqofonoext-1.0.27-1.5.2.jolla.aarch64
libqofonoext-declarative-1.0.27-1.5.2.jolla.aarch64
libqt5sparql-0.3.0-1.5.10.jolla.aarch64
libqt5sparql-tracker-direct-0.3.0-1.5.10.jolla.aarch64
libqtwebkit5-5.6.2+git16-1.7.4.jolla.aarch64
libqtwebkit5-widgets-5.6.2+git16-1.7.4.jolla.aarch64
libquillmetadata-qt5-1.111111.11-1.5.2.jolla.aarch64
libresource-0.25.1-1.6.2.jolla.aarch64
libresourceqt-qt5-1.31.0-1.9.2.jolla.aarch64
libsailfishapp-1.2.13-1.7.3.jolla.aarch64
libsailfishapp-launcher-1.2.13-1.7.3.jolla.aarch64
libsailfishcrypto-0.2.31-1.11.2.jolla.aarch64
libsailfishcryptoplugin-0.2.31-1.11.2.jolla.aarch64
libsailfishcryptopluginapi-0.2.31-1.11.2.jolla.aarch64
libsailfishkeyprovider-1.0.7-1.5.2.jolla.aarch64
libsailfishkeyprovider-data-jolla-0.1.0-1.3.2.jolla.aarch64
libsailfishsecrets-0.2.31-1.11.2.jolla.aarch64
libsailfishsecretsplugin-0.2.31-1.11.2.jolla.aarch64
libsailfishsecretspluginapi-0.2.31-1.11.2.jolla.aarch64
libsbc-1.3.1-1.7.2.jolla.aarch64
libseccomp-2.5.2+git1-1.6.2.jolla.aarch64
libselinux-3.1+git3-1.6.3.jolla.aarch64
libsepol-3.1+git3-1.6.2.jolla.aarch64
libshadowutils-0.0.4-1.5.15.jolla.aarch64
libsigc++20-2.10.4+git1-1.6.2.jolla.aarch64
libsignon-glib-1.15+git1-1.6.2.jolla.aarch64
libsignon-qt5-8.60.0+git6-1.10.2.jolla.aarch64
libsmartcols-2.33+git4-1.8.7.jolla.aarch64
libsndfile-1.0.29+git1-1.5.2.jolla.aarch64
libsocialcache-0.1.7-1.5.2.jolla.aarch64
libsocialcache-qml-plugin-0.1.7-1.5.2.jolla.aarch64
libsolv-0.7.20+git1-1.6.7.jolla.aarch64
libsolv-tools-0.7.20+git1-1.6.7.jolla.aarch64
libsoup-2.68.2+git1-1.6.2.jolla.aarch64
libsrtp-2.3.0+git1-1.6.2.jolla.aarch64
libss-1.45.4+git2-1.5.2.jolla.aarch64
libstdc++-8.3.0-1.7.22.jolla.aarch64
libtasn1-4.13+git2-1.6.2.jolla.aarch64
libtheora-1.2.0alpha1+git4-1.7.2.jolla.aarch64
libtiff-4.3.0+git1-1.6.2.jolla.aarch64
libtool-ltdl-2.4.6-1.5.2.jolla.aarch64
libtrace-1.1.8+git4-1.7.2.jolla.aarch64
libudisks2-2.9.4+git2-1.10.2.jolla.aarch64
libusb-1:0.1.7+git2-1.6.2.jolla.aarch64
libusb-moded-qt5-1.9-1.6.2.jolla.aarch64
libusb1-1.0.20.1-1.7.2.jolla.aarch64
libuser-0.62+git5-1.7.2.jolla.aarch64
libutempter-1.1.5+git3-1.7.7.jolla.aarch64
libuuid-2.33+git4-1.8.7.jolla.aarch64
libvorbis-1.3.7-1.5.2.jolla.aarch64
libvpx-1.9.0-1.5.2.jolla.aarch64
libwbxml2-0.11.6+git2-1.7.2.jolla.aarch64
libwebp-1.2.0+git1-1.9.2.jolla.aarch64
libwspcodec-2.2.6-1.6.2.jolla.aarch64
libxcrypt-4.4.23+git1-1.2.2.jolla.aarch64
libxkbcommon-1.3.1+git1-1.7.2.jolla.aarch64
libxml2-2.9.12+git1-1.5.2.jolla.aarch64
libxslt-1.1.34+git1-1.7.2.jolla.aarch64
libzstd-1.5.0+git1-1.1.24.jolla.aarch64
libzypp-17.26.0+git1-1.6.3.jolla.aarch64
lipstick-jolla-home-qt5-1.24.16.3-1.9.10.jolla.aarch64
lipstick-jolla-home-qt5-components-1.24.16.3-1.9.10.jolla.aarch64
lipstick-qt5-0.36.3.2-1.15.7.jolla.aarch64
lsof-4.91+git1-1.6.18.jolla.aarch64
lvm2-2.02.177+git6-1.8.2.jolla.aarch64
lvm2-libs-2.02.177+git6-1.8.2.jolla.aarch64
lxc-4.0.10+git3-1.6.12.jolla.aarch64
lxc-libs-4.0.10+git3-1.6.12.jolla.aarch64
lzo-2.09-1.6.2.jolla.aarch64
maliit-framework-wayland-0.99.1+git11-1.9.2.jolla.aarch64
maliit-framework-wayland-inputcontext-0.99.1+git11-1.9.2.jolla.aarch64
mapboxgl-qml-2.1.1-1.5.1.jolla.aarch64
mapplauncherd-4.2.11-1.10.13.jolla.aarch64
mapplauncherd-booster-browser-0.1.3-1.6.16.jolla.aarch64
mapplauncherd-booster-silica-qt5-0.5.2-1.4.21.jolla.aarch64
mapplauncherd-booster-silica-qt5-media-0.5.2-1.4.21.jolla.aarch64
mapplauncherd-qt5-1.1.21-1.8.19.jolla.aarch64
mce-1.109.1-1.9.2.jolla.aarch64
mce-plugin-libhybris-1.14.3-1.2.2.jolla.aarch64
mkcal-qt5-0.5.50-1.13.2.jolla.aarch64
mlite-qt5-0.3.8-1.8.2.jolla.aarch64
mms-engine-1.0.78-1.6.2.jolla.aarch64
mobile-broadband-provider-info-20131125+git78-1.6.2.jolla.noarch
mpris-qt5-1.0.6-1.5.2.jolla.aarch64
mpris-qt5-qml-plugin-1.0.6-1.5.2.jolla.aarch64
mtdev-1.1.3-1.6.2.jolla.aarch64
mtp-vendor-configuration-sailfish-0.11.3.1-1.6.2.jolla.noarch
ncurses-base-6.1+git3-1.7.2.jolla.aarch64
ncurses-libs-6.1+git3-1.7.2.jolla.aarch64
nemo-gstreamer1.0-interfaces-0.20200911.0-1.5.1.jolla.aarch64
nemo-password-manager-0.1.5-1.6.2.jolla.aarch64
nemo-qml-plugin-alarms-qt5-0.3.10-1.5.2.jolla.aarch64
nemo-qml-plugin-calendar-qt5-0.6.26-1.10.21.jolla.aarch64
nemo-qml-plugin-calendar-qt5-lightweight-0.6.26-1.10.21.jolla.aarch64
nemo-qml-plugin-calendar-qt5-tools-0.6.26-1.10.21.jolla.aarch64
nemo-qml-plugin-configuration-qt5-0.2.5-1.7.3.jolla.aarch64
nemo-qml-plugin-connectivity-0.2.10-1.6.2.jolla.aarch64
nemo-qml-plugin-contacts-qt5-0.3.21-1.12.2.jolla.aarch64
nemo-qml-plugin-contacts-qt5-tools-0.3.21-1.12.2.jolla.aarch64
nemo-qml-plugin-dbus-qt5-2.1.28-1.6.3.jolla.aarch64
nemo-qml-plugin-devicelock-0.3.7-1.7.2.jolla.aarch64
nemo-qml-plugin-email-qt5-0.6.23-1.10.2.jolla.aarch64
nemo-qml-plugin-filemanager-0.1.37-1.11.2.jolla.aarch64
nemo-qml-plugin-messages-internal-qt5-0.1.30-1.7.2.jolla.aarch64
nemo-qml-plugin-models-qt5-0.2.3-1.7.2.jolla.aarch64
nemo-qml-plugin-notifications-qt5-1.2.16-1.8.3.jolla.aarch64
nemo-qml-plugin-policy-qt5-0.1.3-1.6.2.jolla.aarch64
nemo-qml-plugin-social-qt5-0.1.2-1.6.2.jolla.aarch64
nemo-qml-plugin-systemsettings-0.5.90-1.10.12.jolla.aarch64
nemo-qml-plugin-thumbnailer-qt5-1.0.5-1.6.3.jolla.aarch64
nemo-qml-plugin-thumbnailer-qt5-libav-0.0.10-1.2.2.jolla.aarch64
nemo-qml-plugin-time-qt5-0.1.3-1.6.2.jolla.aarch64
nemo-qtmultimedia-plugins-gstvideotexturebackend-0.1.4-1.6.2.jolla.aarch64
nemo-transferengine-qt5-2.0.0-1.10.3.jolla.aarch64
net-tools-1.60-1.6.2.jolla.aarch64
nfcd-1.1.7-1.8.2.jolla.aarch64
nfcd-binder-plugin-1.1.8-1.2.2.jolla.aarch64
nfcd-dbuslog-plugin-1.0.2-1.5.2.jolla.aarch64
nfcd-mce-plugin-1.0.1-1.4.2.jolla.aarch64
ngfd-1.3.1-1.6.2.jolla.aarch64
ngfd-plugin-native-vibrator-1.3.0-1.6.2.jolla.aarch64
ngfd-settings-sailfish-0.11.3.1-1.6.2.jolla.noarch
nspr-4.29.0+git1-1.5.16.jolla.aarch64
nss-3.73.1+git1-1.8.11.jolla.aarch64
nss-softokn-3.73.1+git1-1.8.11.jolla.aarch64
nss-softokn-freebl-3.73.1+git1-1.8.11.jolla.aarch64
nss-sysinit-3.73.1+git1-1.8.11.jolla.aarch64
nss-util-3.73.1+git1-1.8.11.jolla.aarch64
obex-capability-0.0.2-1.6.2.jolla.aarch64
obexd-calldata-provider-0.1.4-1.3.2.jolla.aarch64
obexd-contentfilter-helper-0.0.2-1.2.2.jolla.noarch
ofono-1.28+git3.2-1.13.2.jolla.aarch64
ofono-alien-binder-plugin-0.1.5.1-1.3.3.jolla.aarch64
ofono-binder-plugin-1.1.5-1.4.2.jolla.aarch64
ofono-modem-switcher-plugin-1.0.2-1.1.2.jolla.aarch64
ofono-vendor-qti-radio-plugin-1.0.1-1.1.2.jolla.aarch64
ohm-1.3.0-1.5.2.jolla.aarch64
ohm-plugin-accessories-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-core-1.3.0-1.5.2.jolla.aarch64
ohm-plugin-mdm-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-media-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-profile-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-resolver-1.1.17-1.5.2.jolla.aarch64
ohm-plugin-route-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-ruleengine-1.1.14-1.5.2.jolla.aarch64
ohm-plugin-signaling-1.8.0-1.8.2.jolla.aarch64
ohm-plugin-telephony-1.8.0-1.8.2.jolla.aarch64
ohm-plugins-dbus-1.8.0-1.8.2.jolla.aarch64
ohm-plugins-misc-1.8.0-1.8.2.jolla.aarch64
okboard-full-0.6.35-1.aarch64
oneshot-0.6.11-1.6.2.jolla.noarch
openconnect-8.10+git2-1.5.15.jolla.aarch64
openjpeg-2.4.0+git1-1.7.2.jolla.aarch64
openssh-8.8p1+git1-1.9.6.jolla.aarch64
openssh-clients-8.8p1+git1-1.9.6.jolla.aarch64
openssh-server-8.8p1+git1-1.9.6.jolla.aarch64
openssl-libs-1.1.1l+git1-1.10.28.jolla.aarch64
openvpn-2.5.2+git3-1.9.12.jolla.aarch64
opus-1.3.1-1.5.2.jolla.aarch64
orc-0.4.26+git1.1-1.7.2.jolla.aarch64
p11-kit-0.23.22+git1-1.7.2.jolla.aarch64
p11-kit-nss-ckbi-0.23.22+git1-1.7.2.jolla.aarch64
p11-kit-trust-0.23.22+git1-1.7.2.jolla.aarch64
pacrunner-0.15+git6-1.6.14.jolla.aarch64
pam-1.3.1+git2-1.7.2.jolla.aarch64
pango-1.42.3-1.6.2.jolla.aarch64
passwd-0.80+git2-1.7.2.jolla.aarch64
patch-2.7.6+git1-1.6.2.jolla.aarch64
patchmanager-3.2.2-1.6.1.jolla.aarch64
patterns-sailfish-api-3-3.0.1-1.5.2.jolla.noarch
patterns-sailfish-app-blacklist-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-applications-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-cellular-apps-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-consumer-generic-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-core-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-core-device-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-customer-content-default-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-device-adaptation-pdx201-0.1.24.3-1.7.2.jolla.aarch64
patterns-sailfish-device-configuration-common-xqau52-0.1.24.3-1.7.2.jolla.aarch64
patterns-sailfish-device-configuration-xqau52-0.1.24.3-1.7.2.jolla.aarch64
patterns-sailfish-mw-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-ui-1.1.6+git2-1.8.1.jolla.noarch
patterns-sailfish-xt9-0.0.7-1.3.2.jolla.aarch64
pcre-8.45+git1-1.7.2.jolla.aarch64
pixman-0.40.0+git3-1.7.2.jolla.aarch64
policy-settings-common-0.12.1-1.8.15.jolla.aarch64
polkit-0.105+git9-1.9.2.jolla.aarch64
poppler-21.08.0+git1-1.6.2.jolla.aarch64
poppler-glib-21.08.0+git1-1.6.2.jolla.aarch64
poppler-qt5-21.08.0+git1-1.6.2.jolla.aarch64
popt-1.18+git1-1.5.2.jolla.aarch64
powertop-2.10+git2-1.3.2.jolla.aarch64
ppp-2.4.9+git2-1.7.2.jolla.aarch64
ppp-libs-2.4.9+git2-1.7.2.jolla.aarch64
pptp-1.8.0+git4-1.6.2.jolla.aarch64
profiled-1.0.12-1.5.2.jolla.aarch64
prolog-resourcepolicy-extensions-1.1.14-1.5.2.jolla.aarch64
protobuf-lite-3.18.0+git1-1.7.2.jolla.aarch64
provisioning-service-0.1.7-1.7.2.jolla.aarch64
pth-2.0.7-1.6.2.jolla.aarch64
pulseaudio-14.2+git6-1.8.2.jolla.aarch64
pulseaudio-module-keepalive-1.0.1-1.6.2.jolla.aarch64
pulseaudio-modules-droid-14.2.94-1.4.2.jolla.aarch64
pulseaudio-modules-droid-common-14.2.94-1.4.2.jolla.aarch64
pulseaudio-modules-droid-hidl-1.3.1-1.2.2.jolla.aarch64
pulseaudio-modules-nemo-common-14.2.30-1.5.1.jolla.aarch64
pulseaudio-modules-nemo-mainvolume-14.2.30-1.5.1.jolla.aarch64
pulseaudio-modules-nemo-parameters-14.2.30-1.5.1.jolla.aarch64
pulseaudio-modules-nemo-stream-restore-14.2.30-1.5.1.jolla.aarch64
pulseaudio-policy-enforcement-14.2.45-1.6.2.jolla.aarch64
pyotherside-qml-plugin-python3-qt5-1.5.9+git3-1.5.2.jolla.aarch64
python3-base-3.8.11+git3-1.7.29.jolla.aarch64
python3-dbus-1.2.16+git3-1.5.13.jolla.aarch64
python3-libs-3.8.11+git3-1.7.29.jolla.aarch64
python3-sqlite-3.8.11+git3-1.7.1.jolla.aarch64
qmaplibregl-2.0.1.0-1.4.1.jolla.aarch64
qmf-notifications-plugin-0.2.10-1.5.2.jolla.aarch64
qmf-notifications-plugin-all-translations-pack-0.8.1-1.6.3.jolla.noarch
qmf-oauth2-plugin-0.1.0-1.2.2.jolla.aarch64
qr-filter-qml-plugin-1.0.4-1.5.2.jolla.aarch64
qt5-plugin-bearer-connman-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-generic-evdev-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-imageformat-gif-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-imageformat-ico-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-imageformat-jpeg-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-platform-minimal-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-plugin-position-geoclue-5.4.2+git1-1.5.2.jolla.aarch64
qt5-plugin-sqldriver-sqlcipher-0.2.31-1.11.2.jolla.aarch64
qt5-plugin-sqldriver-sqlite-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qpa-hwcomposer-plugin-5.6.2.20-1.3.2.jolla.aarch64
qt5-qtconcurrent-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtconnectivity-qtbluetooth-5.6.2+git3-1.6.1.jolla.aarch64
qt5-qtcore-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtdbus-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtdeclarative-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-folderlistmodel-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-localstorageplugin-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-models2-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-multimedia-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtdeclarative-import-particles2-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-positioning-5.4.2+git1-1.5.1.jolla.aarch64
qt5-qtdeclarative-import-qtquick2plugin-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-qttest-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-sensors-5.6.3+git2-1.5.2.jolla.aarch64
qt5-qtdeclarative-import-window2-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-import-xmllistmodel-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-qtquick-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-qtquickparticles-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdeclarative-qtquicktest-5.6.3+git21.1-1.9.2.jolla.aarch64
qt5-qtdocgallery-5.3.0+git2-1.7.2.jolla.aarch64
qt5-qtfeedback-5.2.0+git7-1.5.3.jolla.aarch64
qt5-qtgraphicaleffects-5.6.2+git4-1.6.2.jolla.aarch64
qt5-qtgui-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtimageformats-plugin-tiff-5.6.3+git4-1.6.1.jolla.aarch64
qt5-qtimageformats-plugin-webp-5.6.3+git4-1.6.1.jolla.aarch64
qt5-qtmultimedia-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-gsttools-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-plugin-audio-pulseaudio-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-plugin-mediaservice-gstcamerabin-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-plugin-mediaservice-gstmediacapture-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-plugin-mediaservice-gstmediaplayer-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtmultimedia-plugin-resourcepolicy-resourceqt-5.6.2+git31-1.12.2.jolla.aarch64
qt5-qtnetwork-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtopengl-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtpim-contacts-5.6.0+git15-1.6.1.jolla.aarch64
qt5-qtpim-versit-5.6.0+git15-1.6.1.jolla.aarch64
qt5-qtpositioning-5.4.2+git1-1.5.1.jolla.aarch64
qt5-qtprintsupport-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtqml-import-webkitplugin-5.6.2+git16-1.7.4.jolla.aarch64
qt5-qtqml-import-webkitplugin-experimental-5.6.2+git16-1.7.4.jolla.aarch64
qt5-qtquickcontrols-layouts-5.2.1+git4-1.5.1.jolla.aarch64
qt5-qtsensors-5.6.3+git2-1.5.2.jolla.aarch64
qt5-qtsensors-plugin-sensorfw-5.6.3+git2-1.5.2.jolla.aarch64
qt5-qtsql-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtsvg-5.6.2+git3-1.5.2.jolla.aarch64
qt5-qtsvg-plugin-imageformat-svg-5.6.2+git3-1.5.2.jolla.aarch64
qt5-qtsysteminfo-5.2.0+git12-1.5.1.jolla.aarch64
qt5-qttest-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtwayland-wayland_egl-5.6.3+git2-1.8.2.jolla.aarch64
qt5-qtwebkit-uiprocess-launcher-5.6.2+git16-1.7.4.jolla.aarch64
qt5-qtwidgets-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtxml-5.6.3+git46.2-1.17.1.jolla.aarch64
qt5-qtxmlpatterns-5.6.3+git4-1.7.2.jolla.aarch64
qtcontacts-sqlite-qt5-0.3.14-1.6.2.jolla.aarch64
qtmozembed-qt5-1.53.23-1.33.1.jolla.aarch64
qtscenegraph-adaptation-0.7.7-1.4.2.jolla.aarch64
quota-minimal-4.05+git2-1.6.2.jolla.aarch64
quota-nld-4.05+git2-1.6.2.jolla.aarch64
rootfiles-8.1+git3-1.6.2.jolla.noarch
rpm-4.16.1.3+git9-1.11.2.jolla.aarch64
rrdtool-1.7.2.3-1.2.1.jolla.aarch64
rsync-3.1.3+git2-1.6.2.jolla.aarch64
sailfish-access-control-0.0.6-1.7.2.jolla.aarch64
sailfish-access-control-qml-plugin-0.0.6-1.7.1.jolla.aarch64
sailfish-account-nextcloud-1.0.0-1.5.2.jolla.aarch64
sailfish-account-nextcloud-features-all-1.0.0-1.5.2.jolla.aarch64
sailfish-aml-1.0.2+git1-1.1.2.jolla.aarch64
sailfish-aml-data-1.0.2+git1-1.1.2.jolla.noarch
sailfish-archive-0.1.2-1.2.2.jolla.aarch64
sailfish-audiorecorder-0.1.8-1.4.2.jolla.aarch64
sailfish-audiorecorder-l10n-all-translations-1.21.2-1.6.2.jolla.noarch
sailfish-browser-2.2.54.1-1.26.1.jolla.aarch64
sailfish-browser-settings-2.2.54.1-1.26.1.jolla.aarch64
sailfish-ca-0.2-1.3.2.jolla.noarch
sailfish-components-accounts-qt5-0.2.55-1.5.3.jolla.aarch64
sailfish-components-accounts-qt5-tools-0.2.55-1.5.3.jolla.aarch64
sailfish-components-bluetooth-qt5-0.2.19-1.4.2.jolla.aarch64
sailfish-components-calendar-qt5-1.0.36-1.6.2.jolla.aarch64
sailfish-components-contacts-qt5-0.4.37-1.5.2.jolla.aarch64
sailfish-components-filemanager-0.2.25-1.3.2.jolla.aarch64
sailfish-components-gallery-qt5-1.2.3-1.7.2.jolla.aarch64
sailfish-components-media-qt5-0.9.6-1.3.2.jolla.aarch64
sailfish-components-pickers-qt5-1.0.21-1.6.3.jolla.aarch64
sailfish-components-store-0.0.12-1.2.2.jolla.aarch64
sailfish-components-telephony-qt5-0.2.0-1.2.2.jolla.aarch64
sailfish-components-textlinking-0.1.5-1.2.2.jolla.aarch64
sailfish-components-timezone-qt5-0.2.1-1.3.25.jolla.aarch64
sailfish-components-weather-qt5-1.1.11-1.3.5.jolla.aarch64
sailfish-components-weather-qt5-all-translations-pack-0.8.1-1.4.4.jolla.noarch
sailfish-components-webview-qt5-1.5.9.2-1.20.2.jolla.aarch64
sailfish-components-webview-qt5-pickers-1.5.9.2-1.20.2.jolla.aarch64
sailfish-components-webview-qt5-popups-1.5.9.2-1.20.2.jolla.aarch64
sailfish-connman-plugin-suspend-0.0.10-1.2.6.jolla.aarch64
sailfish-content-ambiences-default-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-about-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-airy-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-community-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-default-ambience-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-favorites-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-flow-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-glacial-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-origami-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-party-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-rolling-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-sailfish3-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-sailing-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-salamander-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-silent-1.0.12-1.3.2.jolla.noarch
sailfish-content-ambiences-default-work-1.0.12-1.3.2.jolla.noarch
sailfish-content-apps-default-configs-0.11.3.1-1.6.2.jolla.noarch
sailfish-content-browser-default-0.1.6-1.3.2.jolla.noarch
sailfish-content-configuration-jolla-0.1.1-1.2.2.jolla.noarch
sailfish-content-gallery-default-0.32.0-1.2.2.jolla.noarch
sailfish-content-graphics-closed-0.6.3-1.2.2.jolla.noarch
sailfish-content-graphics-closed-z1.75-0.6.3-1.2.2.jolla.noarch
sailfish-content-graphics-default-base-1.3.0.1-1.6.2.jolla.noarch
sailfish-content-graphics-default-z1.75-base-1.3.0.1-1.6.2.jolla.noarch
sailfish-content-graphics-jolla-0.0.8-1.2.2.jolla.noarch
sailfish-content-graphics-jolla-z1.75-0.0.8-1.2.2.jolla.noarch
sailfish-content-profiled-settings-default-0.16.1-1.2.2.jolla.noarch
sailfish-content-tones-default-0.16.1-1.2.2.jolla.noarch
sailfish-content-vpn-default-0.0.1-1.3.2.jolla.noarch
sailfish-device-encryption-0.10.3.1-1.5.4.jolla.aarch64
sailfish-device-encryption-service-0.10.3.1-1.5.4.jolla.aarch64
sailfish-device-encryption-settings-0.10.3.1-1.5.4.jolla.aarch64
sailfish-device-encryption-unlock-ui-0.10.3.1-1.5.4.jolla.aarch64
sailfish-device-encryption-unlock-ui-resources-z1.75-0.10.3.1-1.5.4.jolla.aarch64
sailfish-devicelock-fpd-1.1.3-1.2.25.jolla.aarch64
sailfish-fonts-0.2.0-1.3.2.jolla.noarch
sailfish-fpd-1.5.0-1.4.2.jolla.aarch64
sailfish-fpd-slave-binder-1.5.0-1.2.3.jolla.aarch64
sailfish-homescreen-services-0.1.6-1.4.12.jolla.aarch64
sailfish-homescreen-services-libs-0.1.6-1.4.12.jolla.aarch64
sailfish-installationhandler-1.0.5-1.3.3.jolla.aarch64
sailfish-minui-resources-z1.75-0.0.32.1-1.4.1.jolla.aarch64
sailfish-office-1.6.1-1.5.2.jolla.aarch64
sailfish-office-all-translations-pack-0.8.1-1.4.5.jolla.noarch
sailfish-policy-0.4.14-1.4.14.jolla.aarch64
sailfish-settings-networking-1.0.1.1-1.5.2.jolla.aarch64
sailfish-setup-0.3.2-1.6.2.jolla.noarch
sailfish-silica-background-qt5-0.9.15-1.2.2.jolla.aarch64
sailfish-tutorial-default-0.2.27-1.4.2.jolla.aarch64
sailfish-tutorial-default-data-0.2.27-1.4.2.jolla.noarch
sailfish-upgrade-ui-0.1.16-1.2.4.jolla.aarch64
sailfish-upgrade-ui-resources-logo-z1.75-0.1.16-1.2.4.jolla.aarch64
sailfish-upgrade-ui-resources-z1.75-0.1.16-1.2.4.jolla.aarch64
sailfish-version-4.4.0-1.5.72.jolla.noarch
sailfish-version-variant-4.4.0-1.5.72.jolla.noarch
sailfish-wayland-libs-0.1.3-1.4.13.jolla.aarch64
sailfish-weather-1.0.8-1.3.6.jolla.aarch64
sailfish-weather-all-translations-pack-0.8.1-1.4.4.jolla.noarch
sailfishos-chum-gui-0.5.0-1.6.1.jolla.aarch64
sailfishsecretsdaemon-0.2.31-1.11.2.jolla.aarch64
sailfishsecretsdaemon-cryptoplugins-default-0.2.31-1.11.2.jolla.aarch64
sailfishsecretsdaemon-secretsplugin-common-0.2.31-1.11.2.jolla.aarch64
sailfishsecretsdaemon-secretsplugins-default-0.2.31-1.11.2.jolla.aarch64
sailfishshare-components-1.0.3-1.8.3.jolla.aarch64
sailfishsilica-qt5-1.2.79.1-1.8.2.jolla.aarch64
sailjail-1.1.18.2-1.18.7.jolla.aarch64
sailjail-daemon-1.1.18.2-1.18.7.jolla.aarch64
sailjail-permissions-1.1.1-1.32.3.jolla.aarch64
sensorfw-qt5-0.12.6-1.8.2.jolla.aarch64
sensorfw-qt5-configs-0.12.6-1.8.2.jolla.noarch
setup-2.13.6+git5-1.10.11.jolla.noarch
shadow-utils-4.8.1+git2-1.7.15.jolla.aarch64
shared-mime-info-1.12+git1-1.7.2.jolla.aarch64
signon-plugin-oauth2-qt5-0.25+git1-1.6.1.jolla.aarch64
simkit-0.4.30-1.4.13.jolla.aarch64
sound-theme-freedesktop-0.8+git1-1.7.2.jolla.noarch
speex-1.2.0+git2-1.6.14.jolla.aarch64
speexdsp-1.2.0+git3-1.5.2.jolla.aarch64
sqlcipher-3.4.1+git2.1-1.6.2.jolla.aarch64
sqlite-libs-3.37.2+git1-1.7.2.jolla.aarch64
ssu-1.0.19-1.8.2.jolla.aarch64
ssu-declarative-1.0.19-1.8.2.jolla.aarch64
ssu-network-proxy-plugin-1.0.19-1.8.2.jolla.aarch64
ssu-sysinfo-1.3.0-1.5.2.jolla.aarch64
ssu-vendor-data-jolla-0.131-1.13.2.jolla.noarch
store-client-1.3.4.1-1.6.2.jolla.aarch64
sudo-1.8.20p2+git4-1.2.41.jolla.aarch64
swi-prolog-7.6.4+git1-1.6.18.jolla.aarch64
swi-prolog-library-core-7.6.4+git1-1.6.18.jolla.aarch64
swi-prolog-runtime-lib-7.6.4+git1-1.6.18.jolla.aarch64
systemd-238+git13.1-1.14.2.jolla.aarch64
systemd-config-sailfish-0.11.3.1-1.6.2.jolla.noarch
systemd-libs-238+git13.1-1.14.2.jolla.aarch64
systemd-user-session-targets-0.0.2-1.7.2.jolla.noarch
taglib-1.12+git2-1.6.2.jolla.aarch64
telepathy-accounts-signon-0.1.27.3-1.6.2.jolla.aarch64
telepathy-farstream-0.6.2+git1-1.5.2.jolla.aarch64
telepathy-gabble-0.18.4+git4-1.7.15.jolla.aarch64
telepathy-glib-0.24.1+git1-1.5.2.jolla.aarch64
telepathy-mission-control-5.16.6+git6-1.7.2.jolla.aarch64
telepathy-qt5-0.9.8+git2.1-1.10.2.jolla.aarch64
telepathy-qt5-farstream-0.9.8+git2.1-1.10.2.jolla.aarch64
telepathy-ring-2.5.12-1.7.7.jolla.aarch64
thumbnaild-0.0.10-1.7.2.jolla.aarch64
timed-qt5-3.6.13-1.8.2.jolla.aarch64
timed-qt5-tools-3.6.13-1.8.2.jolla.aarch64
totem-pl-parser-3.26.1+git1.1-1.7.2.jolla.aarch64
tracker-3.2.1+git1-1.6.2.jolla.aarch64
tracker-miners-3.2.1+git1-1.6.3.jolla.aarch64
transferengine-plugin-nextcloud-1.0.0-1.5.2.jolla.aarch64
transferengine-plugins-0.3.0-1.6.2.jolla.aarch64
tzdata-2021a+git1-1.5.2.jolla.noarch
tzdata-timed-2021a+git1-1.6.2.jolla.noarch
unzip-6.0-1.6.14.jolla.aarch64
usb-moded-0.86.0+mer56-1.8.7.jolla.aarch64
user-managerd-0.8.7-1.8.2.jolla.aarch64
util-linux-2.33+git4-1.8.7.jolla.aarch64
vault-1.0.4-1.5.2.jolla.aarch64
voicecall-qt5-0.7.13-1.7.2.jolla.aarch64
voicecall-qt5-plugin-telepathy-0.7.13-1.7.2.jolla.aarch64
voicecall-ui-jolla-1.14.38.1-1.6.2.jolla.aarch64
voicecall-ui-jolla-settings-1.14.38.1-1.6.2.jolla.aarch64
vpnc-0.5.3-1.6.2.jolla.aarch64
wayland-1.19.0+git1-1.6.2.jolla.aarch64
wayland-egl-1.19.0+git1-1.6.2.jolla.aarch64
wireless-regdb-2020.04.29+git4-1.6.4.jolla.noarch
wpa_supplicant-2.9+git5-1.8.2.jolla.aarch64
xdg-dbus-proxy-0.1.2+git4-1.8.2.jolla.aarch64
xdg-user-dirs-0.16+git2.1-1.7.2.jolla.aarch64
xdg-utils-1.1.2+git2-1.8.2.jolla.noarch
xkeyboard-config-2.29+git1-1.6.2.jolla.noarch
xl2tpd-1.3.15+git1-1.6.2.jolla.aarch64
xulrunner-qt5-78.15.1+git24.3-1.32.2.jolla.aarch64
xz-libs-5.2.5+git1-1.5.2.jolla.aarch64
yaml-cpp-0.6.3+git1-1.6.2.jolla.aarch64
yamui-1.1.2-1.3.2.jolla.aarch64
yamuisplash-1.0.2-1.4.2.jolla.aarch64
zlib-1.2.11+git2-1.7.13.jolla.aarch64
zxing-cpp-1.1.1+git2-1.7.2.jolla.aarch64
The problem isn’t with the governer. The problem is with cores not turning off when not needed. It’s especially problematic when combined with issues like voicecall-ui getting stuck consuming CPU, meaning the phone doesn’t enter sleep properly.
Sorry, I missed that. This is a very odd issue.
Quite possible. The XA2 Ultra apparently also switches unused cores to offline mode. Yesterday I wanted to check its full performance with an Amiga emulator that we’re discussing in another thread, so I attepted to switch all cores to ‘performance’ governor. It worked fine with cores 0-3, but trying to switch cores 4-7 kept giving me errors. It turned out that all four 1.8 GHz cores were offline and thus unreachable. It took giving the device a heavy load (launch jellyfish benchmark in the browser with 100 jellyfish) for the cores to be switched to online, and only then I was able to change the governor setting.
While it is nice for powersaving, I’m afraid that it contributes to the XA2’s awful sluggishness. Apparently the four “upper” cores only switch on when there’s quite a high load.
fingus
17 November 2022 10:29
12
Aren´t there always 2 performance Cores and the others are just “normal” Cores?
It is so in the 10 III (six 1.7 GHz A55 cores + two 2.0 GHz A77 cores). But in the XA2 Ultra it is 4:4 (four 2.2 GHz A53 cores + four 1.8 GHz A53 cores).
fingus
17 November 2022 13:50
14
Mine X Compact have Hexa-core (4x1.4 GHz Cortex-A53 & 2x1.8 GHz Cortex-A72)
Can I suggest you, as temporary workaround, these two actions:
mcetool --set-cpu-scaling-governor=automat
ic (you can also choose perrformance or interactive)
or force the power saving mode in the battery menu.
Thanks for the suggestion. Unfortunately, neither of those options has any effect. All 8 cores remain stubbornly on.
I’m starting to think that whatever process is supposed to govern these cores is simply not running. I can turn the cores on/off manually by writing 1/0 to /sys/devices/system/cpu/cpuX/online.
I guess that on the 10 III all 8 cores are permanently online, too. So there’s clearly no process there to control it, either. It would be interesting to see how manually switching either the big or the small cores to offline affects 10 III’s performance and power consumption.
There is core_ctl which does “turn” cores on and off based on their load. Have a look at /sys/devices/system/cpu/cpu0/core_ctl/. Depending on the chipset cpu0 is for the first cluster and fe cpu4 or cpu6 for the performance cluster.
File enable will turn core_ctl on or off.
min_cpus defines minimum amount of cpus running.
max_cpus defines maximum amount of cpus running.
busy_up_thres defines the threshold where an additional core is turned on.
busy_down_thres defines the threshold where the core is going to be turned off.
offline_delay_ms defines how long a core is still active after being selected to turn off in milliseconds.
The settings have to be set for each cluster. One can check the core status with cat /sys/devices/system/cpu/cpu0/core_ctl/global_state.
I’m not sure if the cores are turned off or core_ctl just adjusts the scheduler to not use certain cpus. They still show in htop. With my measurements the impact on battery consumption is minimal while the device is used. Only reducing max_cpus to a few cores / one core did lower average battery current. But I’m still investigating it’s impact.
Interesting, I don’t seem to have that core_ctl. The only thing remotely like it is /sys/devices/system/cpu/core_ctl_isolated, but that just looks like an empty file. No idea what to do with that.
If I turn off a core manually, it stops showing up in htop after you start htop fresh (it doesn’t update core counts for a running process).
