https://openrepos.net/sites/default/files/packages/6735/telepathy-gabble-plus-0.18.4-32.aarch64.rpm
Hm weird.
Storeman shows the version I have installed as the latest available, but itās not one of those listed on the Openrepos website.
Also the rpm name looks like an OBS built one.
But I donāt remember building it
$ pkcon resolve telepathy-gabble-plus
Resolving
Querying
Installed telepathy-gabble-plus-0.18.4+git2+HEAD.20220403191913.bc2e989+telepathy.gabble.aa0a11f6b+li
b.ext.wocky.6a31d2c-32.aarch64 (installed) A Jabber/XMPP connection manager
Available telepathy-gabble-plus-0.18.4+git2+HEAD.20220318195648.9da4537+telepathy.gabble.502a2ffad+li
b.ext.wocky.6a31d2c-31.aarch64 (openrepos-noonien) A Jabber/XMPP connection manager
Whatās really strange is that I have it installed and had completely forgotten. I have to stop doing crack.
Maybe someone should have a look to kaidan.im .
If it could be compiled for Sailfish too it would be great.
The native implementation of xmpp is very unusable for several aspects:
No omemo,
No muc,
No several other basicsā¦
The reason is that telepathy framework is so far behind of modern xepāsā¦
The backend kaidan uses, GitHub - qxmpp-project/qxmpp: Cross-platform C++ XMPP client and server library , could probably be built with current SFOS tooling. The front end, which also uses kirigami ( not a fan ) and requires 5.15, so thatād be a challenge. qxmpp would be a upgrade over telepathy (I think!?)
The native XMPP account works, but is very limited:
The only thing that really works are 1:1 unencrypted text chats, similar to SMS.
Video chats do not work, group chats neither, end-to-end encryption does not work,you cannot send pictures, videos or voice message (but at least receive them), read markers are not correctly set and so on. And you cannot create new contacts, you have to add them in some other client to your contact list, then they also appear in Sailfish āContactsā app and can be used.
With installation of telepathy-gabble-plus this can be a little bit improved: Read makers work, sending pictures/videos/files works.
Shmoose can also be used, but as itās an extra app, so it does not extend the native messaging system but works in parallel. It does at least support group chats, sending pictures/videos/files, adding contacts, and has limited support for OMEMO end-to-end encryption.
In total thereās unfortunately no XMPP client on Sailfish that comes near to Conversations (Android) or Monal (iOS).
I personally normally use the native client beefed up with telepathy-gabble-plus on the phone. Usually thatās sufficient. If someone uses OMEMO or if I want to use groups I start Conversations. On my computers I use Gajim.
Just to play the devilās advocate (Iām a long time XMPP user/service provider) what if we consider the most likely to be a win for all case? Iām thinking, even though I have my issues (both software as organizational), that doing OS level integration (given that @HengYeDev is doing fundamental client work already) of something like matrix might get us further, faster?
Iāve been losing the fight for upgrading XMPP in the organization for 2 years now. Defacto, matrix has become the standard.
How many here are still using primarily XMPP? Serious question. Not ideological. Not to say they exclude one another, but obviously Jolla isntā able to support XMPP so that itās usable.
Valid question. Personally I would be happy with any native communication app which supports chat, voice and video and is supported in the android and apple world as well.
Itās the permanent bugs with, e.g., calls or video calls which annoy me when using Telegram or Threema via the android compatibility.
via GitHub - TelepathyIM/telepathy-tank: Matrix connection operator for the Telepathy framework Matrix could have the same level of āintegrationā as XMPP actually. And Telegram if you dare GitHub - TelepathyIM/telepathy-morse: Telegram connection manager for the Telepathy framework ⦠
Ah, thank you. But that doesnāt cover E2E which seems to be the ābaselineā. So that would be libolm. Still, I wasnāt suggesting that plumbing is entirely absent, just that maybe the developer āmind-shareā is a problem. Unfortunately, if youāve ever looked at how synapse stores json arrays in an otherwise fine pg database, you might argue that itās better not to have that mind-share.
How much effort would you guess is involved in supporting libolm? In the case of implementing libolm support, how far up the tree (I mean UI support for stuff like key exchange, backup, etc.) does it go?
Could be time to push this to the funding page. Itās discrete enough ⦠(currently stuck writing grant applications that Iām not qualified to writeā¦)
libquotient seems to support and use libolm already for EE encryption. In how far the telepathy specification contains meta data for EE encryption and key handling I donāt know. Maybe @kaffeine is here as well?
To be honest I wasnāt seriously suggesting to extend those! Creating an abstraction layer like telepathy or libpurple across protocols (this includes SMS, MMS, telephony btw) seems to create quite some friction and loss of features.
Had forgotten!
But you mentioned the same level of integration, which suggests libolm integration?
Within the next release kaidan will have omemo fully integrated.
The new version will be released soon.
If Kaidan will compile then maybe we would have a good xmpp client
With the new support of QT 5.15 Qt 5.15: what's next? - #49 by tortoisedoc, I think that compile kaidan for Sailfish will now be possible
Thatās a good idea! Having a look now!
and kaidan with OMEMO was released on May 5th, it would be very nice to have it (they only lack group chat support which will be in next versions, for the moment they have only implemented group chat search). Kaidan 0.9: End-to-End Encryption & XMPP Providers - Kaidan
Sadly, fedora doesnāt have a recent spec for it, or itās stuck in kde-extras. Looking aboutā¦
EDIT: File kaidan.spec of Package kaidan - openSUSE Build Service looks fairly usable!
This is the ground work with a submodule. However, we need another dep: ZXing. so itās gonna take time. If someone wants to take a crack at it: GitHub - poetaster/kaidan: xmpp messanger from kde
Thereās a zxing-cpp package available, is that not it?
