REPRODUCIBILITY:
OS VERSION: 4.4.0.58
HARDWARE: Sony Xperia XA2
UI LANGUAGE: English
REGRESSION:
Since the latest update, though i can set my xmpp account to online or away from the ‘settings → presence’ menu, i can receive and send xmpp messages, but the status of the contact (online, busy, away) is not anymore seen neither in contacts app, nor in messages app.
i can never know if the contact is online before sending the message.
- setup an xmpp account, make it active
- go to settings → presence. set yourself online
- open ‘contacts’ or ‘messages’ app - there is a short vertical line near each contact. it should be grey, if the contact is offline, green, if the contact is online, orange, if the contact is away.
it is always gray, though the contacts are online, and we are able to chat with them.
it is expected to see the xmpp status of the contact in the contacts and messages app.
i had to install telepathy-gabble-plus, but i always install this after update, otherwise xmpp doesn’t work at all. don’t know when jolla will fix that.
