XMPP can not connect to recent ejabberd (GNU_TLS bug)
BUILD ID = OS VERSION (Settings > About product): 3.4.0.24
HARDWARE (Jolla1, Tablet, XA2,…): Sony X
UI LANGUAGE: DE
I recently upgraded my legacy ejabberd service and found out that native XMPP client is no longer able to connect to current ejabberd 20.01 pulled from dockerhub (docker pull ejabberd/ecs) using Let’s encrypt certificate. It looks like GNU_TLS has trouble negotiating the STARTTLS handshake.
  • Pulled latest ejabberd image form dockerhub
  • Generated Let’s encrypt certificate and configured ejabberd.yml
## When using let's encrypt to generate certificates
certfiles:
  - /home/ejabberd/conf/fullchain.pem
  - /home/ejabberd/conf/privkey.pem
listen:
    port: 5222
    ip: "::"
    module: ejabberd_c2s
    max_stanza_size: 262144
    shaper: c2s_shaper
    access: c2s
    starttls_required: true
  1. Create ejabberd container and add Let’s encrypt certs
  2. Setup XMPP account
  3. Try to connect to XMPP server
  • XMPP account up and running
  • no connection possible, ejabberd shows
2020-10-19 08:56:00.533693+00:00 [warning] (tls|<0.3813.0>) Failed to secure c2s connection: TLS failed: SSL_do_handshake failed: error:1417A0C1:SSL routines:tls_post_process_client_hello:no shared cipher
  • Journalctl shows:
Oct 19 10:12:24 Sailfish dbus-daemon[1385]: dbus-daemon[1385]: [session uid=100000 pid=1385] Successfully activated serv
ice 'org.freedesktop.Telepathy.ConnectionManager.gabble'
Oct 19 10:12:25 Sailfish [2934]: [W] unknown:0 - tp-qt 0.9.8 WARN: Nested PendingReady for true failed with "org.f
reedesktop.Telepathy.Error.NetworkError" : "WOCKY_CONNECTOR_ERROR_TLS_SESSION_FAILED (#7): TLS handshake error: -9: GNUT
LS_E_UNEXPECTED_PACKET_LENGTH"
Oct 19 10:12:25 Sailfish [2934]: [W] unknown:0 - tp-qt 0.9.8 WARN: Building connection "/org/freedesktop/Telepathy
/Connection/gabble/jabber/heiko_40xxxx_2exxx_2ede_2fJolla" failed with "org.freedesktop.Telepathy.Error.NetworkE
rror" - "WOCKY_CONNECTOR_ERROR_TLS_SESSION_FAILED (#7): TLS handshake error: -9: GNUTLS_E_UNEXPECTED_PACKET_LENGTH"
reedesktop.Telepathy.Error.NetworkError" : "ConnectionStatusReason = 2"
  • tested with Gajim client on desktop PC and it works fine (ejabberd config is ok)
  • run testssl.sh with the following result:
    testssl.sh       3.1dev from https://testssl.sh/dev/
    (e51301d 2020-10-17 17:04:49 -- )
      This program is free software. Distribution and
             modification under GPLv2 permitted.
      USAGE w/o ANY WARRANTY. USE IT AT YOUR OWN RISK!
       Please file bugs @ https://testssl.sh/bugs/
 Using "OpenSSL 1.0.2-chacha (1.0.2k-dev)" [~183 ciphers]
 on qsc-VirtualBox:./bin/openssl.Linux.x86_64
 (built: "Jan 18 17:12:17 2019", platform: "linux-x86_64")
 Start 2020-10-19 11:06:50        -->> x.x.x.x:5222 (xxx.de) <<--
 rDNS (xxxx):   xxxxx.de.
 Service set:            STARTTLS via XMPP (XMPP domain=\'xxxx.de\')
 Testing protocols via sockets
 SSLv2      not offered (OK)
 SSLv3      not offered (OK)
 TLS 1      offered (deprecated)
 TLS 1.1    offered (deprecated)
 TLS 1.2    offered (OK)
 TLS 1.3    offered (OK): final
 Testing cipher categories
 NULL ciphers (no encryption)                      not offered (OK)
 Anonymous NULL Ciphers (no authentication)        not offered (OK)
 Export ciphers (w/o ADH+NULL)                     not offered (OK)
 LOW: 64 Bit + DES, RC[2,4], MD5 (w/o export)      not offered (OK)
 Triple DES Ciphers / IDEA                         not offered
 Obsoleted CBC ciphers (AES, ARIA etc.)            offered
 Strong encryption (AEAD ciphers) with no FS       not offered
 Forward Secrecy strong encryption (AEAD ciphers)  offered (OK)
 Testing servers cipher preferences
 Has server cipher order?     yes (OK) -- TLS 1.3 and below
 Negotiated protocol          TLSv1.3
 Negotiated cipher            TLS_AES_256_GCM_SHA384, 253 bit ECDH (X25519)
 Cipher per protocol
Hexcode  Cipher Suite Name (OpenSSL)       KeyExch.   Encryption  Bits     Cipher Suite Name (IANA/RFC)
SSLv2
SSLv3
TLSv1 (server order)
 xc00a   ECDHE-ECDSA-AES256-SHA            ECDH 256   AES         256      TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA
 xc009   ECDHE-ECDSA-AES128-SHA            ECDH 256   AES         128      TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA
TLSv1.1 (server order)
TLSv1.2 (server order)
 xc02c   ECDHE-ECDSA-AES256-GCM-SHA384     ECDH 253   AESGCM      256      TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
 xcca9   ECDHE-ECDSA-CHACHA20-POLY1305     ECDH 253   ChaCha20    256      TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
 xc0af   ECDHE-ECDSA-AES256-CCM8           ECDH 253   AESCCM8     256      TLS_ECDHE_ECDSA_WITH_AES_256_CCM_8
 xc0ad   ECDHE-ECDSA-AES256-CCM            ECDH 253   AESCCM      256      TLS_ECDHE_ECDSA_WITH_AES_256_CCM
 xc05d   ECDHE-ECDSA-ARIA256-GCM-SHA384    ECDH 253   ARIAGCM     256      TLS_ECDHE_ECDSA_WITH_ARIA_256_GCM_SHA384
 xc024   ECDHE-ECDSA-AES256-SHA384         ECDH 253   AES         256      TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384
 xc073   ECDHE-ECDSA-CAMELLIA256-SHA384    ECDH 253   Camellia    256      TLS_ECDHE_ECDSA_WITH_CAMELLIA_256_CBC_SHA384
 xc00a   ECDHE-ECDSA-AES256-SHA            ECDH 253   AES         256      TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA
 xc02b   ECDHE-ECDSA-AES128-GCM-SHA256     ECDH 253   AESGCM      128      TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
 xc0ae   ECDHE-ECDSA-AES128-CCM8           ECDH 253   AESCCM8     128      TLS_ECDHE_ECDSA_WITH_AES_128_CCM_8
 xc0ac   ECDHE-ECDSA-AES128-CCM            ECDH 253   AESCCM      128      TLS_ECDHE_ECDSA_WITH_AES_128_CCM
 xc05c   ECDHE-ECDSA-ARIA128-GCM-SHA256    ECDH 253   ARIAGCM     128      TLS_ECDHE_ECDSA_WITH_ARIA_128_GCM_SHA256
 xc023   ECDHE-ECDSA-AES128-SHA256         ECDH 253   AES         128      TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256
 xc072   ECDHE-ECDSA-CAMELLIA128-SHA256    ECDH 253   Camellia    128      TLS_ECDHE_ECDSA_WITH_CAMELLIA_128_CBC_SHA256
 xc009   ECDHE-ECDSA-AES128-SHA            ECDH 253   AES         128      TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA
TLSv1.3 (server order)
 x1302   TLS_AES_256_GCM_SHA384            ECDH 253   AESGCM      256      TLS_AES_256_GCM_SHA384
 x1303   TLS_CHACHA20_POLY1305_SHA256      ECDH 253   ChaCha20    256      TLS_CHACHA20_POLY1305_SHA256
 x1301   TLS_AES_128_GCM_SHA256            ECDH 253   AESGCM      128      TLS_AES_128_GCM_SHA256
 Testing robust forward secrecy (FS) -- omitting Null Authentication/Encryption, 3DES, RC4
 FS is offered (OK)           TLS_AES_256_GCM_SHA384 TLS_CHACHA20_POLY1305_SHA256 ECDHE-ECDSA-AES256-GCM-SHA384
                              ECDHE-ECDSA-AES256-SHA384 ECDHE-ECDSA-AES256-SHA ECDHE-ECDSA-CHACHA20-POLY1305
                              ECDHE-ECDSA-AES256-CCM8 ECDHE-ECDSA-AES256-CCM ECDHE-ECDSA-CAMELLIA256-SHA384
                              ECDHE-ECDSA-ARIA256-GCM-SHA384 TLS_AES_128_GCM_SHA256 ECDHE-ECDSA-AES128-GCM-SHA256
                              ECDHE-ECDSA-AES128-SHA256 ECDHE-ECDSA-AES128-SHA ECDHE-ECDSA-AES128-CCM8 ECDHE-ECDSA-AES128-CCM
                              ECDHE-ECDSA-CAMELLIA128-SHA256 ECDHE-ECDSA-ARIA128-GCM-SHA256
 Elliptic curves offered:     prime256v1 secp384r1 secp521r1 X25519 X448
 Testing server defaults (Server Hello)
 TLS extensions (standard)    "renegotiation info/#65281" "server name/#0" "EC point formats/#11" "supported versions/#43"
                              "key share/#51" "supported_groups/#10" "max fragment length/#1" "encrypt-then-mac/#22"
                              "extended master secret/#23"
 Session Ticket RFC 5077 hint no -- no lifetime advertised
 SSL Session ID support       yes
 Session Resumption           Tickets no, ID: no
 TLS clock skew               Random values, no fingerprinting possible
 Signature Algorithm          SHA256 with RSA
 Server key size              EC 256 bits (curve P-256)
 Server key usage             Digital Signature
 Server extended key usage    TLS Web Server Authentication, TLS Web Client Authentication
 Serial / Fingerprints        xxxxxxxxxxxxxxxxxxx
 Common Name (CN)             xxxxxx.de
 subjectAltName (SAN)         xxxxxxxxxxxxx
 Trust (hostname)             Ok via SAN (same w/o SNI)
 Chain of trust               Ok
 EV cert (experimental)       no
 Certificate Validity (UTC)   87 >= 30 days (2020-10-16 xx:xx --> 2021-01-14 xx:xx)
 ETS/"eTLS", visibility info  not present
 Certificate Revocation List  --
 OCSP URI                     http://ocsp.int-x3.letsencrypt.org
 OCSP stapling                not offered
 OCSP must staple extension   --
 DNS CAA RR (experimental)    not offered
 Certificate Transparency     yes (certificate extension)
 Certificates provided        2
 Issuer                       Let's Encrypt Authority X3 (Let's Encrypt from US)
 Intermediate cert validity   #1: ok > 40 days (2021-03-17 xx:xx). Let's Encrypt Authority X3 <-- DST Root CA X3
 Intermediate Bad OCSP (exp.) Ok
 Testing vulnerabilities
 Heartbleed (CVE-2014-0160)                not vulnerable (OK), no heartbeat extension
 CCS (CVE-2014-0224)                       not vulnerable (OK)
 ROBOT                                     Server does not support any cipher suites that use RSA key transport
 Secure Renegotiation (RFC 5746)           supported (OK)
 Secure Client-Initiated Renegotiation     not vulnerable (OK)
 CRIME, TLS (CVE-2012-4929)                not vulnerable (OK) (not using HTTP anyway)
 POODLE, SSL (CVE-2014-3566)               not vulnerable (OK), no SSLv3 support
 TLS_FALLBACK_SCSV (RFC 7507)              some unexpected "handshake failure" instead of "inappropriate fallback"
 SWEET32 (CVE-2016-2183, CVE-2016-6329)    not vulnerable (OK)
 FREAK (CVE-2015-0204)                     not vulnerable (OK)
 DROWN (CVE-2016-0800, CVE-2016-0703)      not vulnerable on this host and port (OK)
                                           no RSA certificate, thus certificate can't be used with SSLv2 elsewhere
 LOGJAM (CVE-2015-4000), experimental      not vulnerable (OK): no DH EXPORT ciphers, no DH key detected with <= TLS 1.2 BEAST (CVE-2011-3389)                     TLS1: ECDHE-ECDSA-AES256-SHA ECDHE-ECDSA-AES128-SHA
                                           VULNERABLE -- but also supports higher protocols  TLSv1.1 TLSv1.2 (likely mitigated)
 LUCKY13 (CVE-2013-0169), experimental     potentially VULNERABLE, uses cipher block chaining (CBC) ciphers with TLS. Check patches
 Winshock (CVE-2014-6321), experimental    not vulnerable (OK)
 RC4 (CVE-2013-2566, CVE-2015-2808)        no RC4 ciphers detected (OK)
 Running client simulations via sockets
 Android 8.1 (native)         TLSv1.2 ECDHE-ECDSA-AES256-GCM-SHA384, 253 bit ECDH (X25519)
 Android 9.0 (native)         TLSv1.3 TLS_AES_256_GCM_SHA384, 253 bit ECDH (X25519)
 Android 10.0 (native)        TLSv1.3 TLS_AES_256_GCM_SHA384, 253 bit ECDH (X25519)
 Java 6u45                    No connection
 Java 7u25                    TLSv1.0 ECDHE-ECDSA-AES128-SHA, 256 bit ECDH (P-256)
 Java 8u161                   TLSv1.2 ECDHE-ECDSA-AES256-GCM-SHA384, 256 bit ECDH (P-256)
 Java 11.0.2 (OpenJDK)        TLSv1.3 TLS_AES_256_GCM_SHA384, 256 bit ECDH (P-256)
 Java 12.0.1 (OpenJDK)        TLSv1.3 TLS_AES_256_GCM_SHA384, 256 bit ECDH (P-256)
 OpenSSL 1.0.2e               TLSv1.2 ECDHE-ECDSA-AES256-GCM-SHA384, 256 bit ECDH (P-256)
 OpenSSL 1.1.0l (Debian)      TLSv1.2 ECDHE-ECDSA-AES256-GCM-SHA384, 253 bit ECDH (X25519)
 OpenSSL 1.1.1d (Debian)      TLSv1.3 TLS_AES_256_GCM_SHA384, 253 bit ECDH (X25519)
 Rating (experimental)
 Rating specs (not complete)  SSL Labs's 'SSL Server Rating Guide' (version 2009q from 2020-01-30)
 Specification documentation  https://github.com/ssllabs/research/wiki/SSL-Server-Rating-Guide
 Protocol Support (weighted)  0 (0)
 Key Exchange     (weighted)  0 (0)
 Cipher Strength  (weighted)  0 (0)
 Final Score                  0
 Overall Grade                T
 Grade cap reasons            Grade capped to T. Encryption via STARTTLS is not mandatory (opportunistic).
                              Grade capped to B. TLS 1.1 offered
                              Grade capped to B. TLS 1.0 offered
 Done 2020-10-19 11:08:10 [  83s] -->> xxxxx.de:5222 (xxxxxx.de) <<--
I analysed TLS handshake with some older GNU TLS version and found the reason why SailfishOS XMPP client is not connecting with ejabberd.
The “bug” was my Let’s Encrypt certificate created as EC256 keytype, however 11 year old GNU TLS 2.12.24 library on our phones does not support this kind of cryptographic feature. After creating a new certificate as RSA keytype the connection finally works.
i just installed own Prosody xmpp server and was very surprised that recent SF5.0.0.77 still using tls1.0 !
well i still use jp-1 phone with SF 1.1.7.28 maybe in past i rebuild telepathy-gabble i do not remember, anyway it does use tls1.2 so after changing certificate to RSA keytype and adjusting ciphers in prosody (DHE-RSA-AES128-SHA) JP-1 connected and works as expected.
but then i was going to add account into xperia and was not able to get it work even i tried prosody force to use tls1, re-enabling legacy provider in openssl did not work either.
(final dirty solution was unpack telepathy-gable-plus from open repos and replace files as the system version of gabble can not be uninstalled and/or forced instalation of plus could broke system updates, but for now i can connect to xmpp in recent SF)
lets say tls 1.0 is realy outdated and should not be used anymore nowhere…
so please @jolla update telepathy-gabble to use tls 1.2+
btw as the SF is alternative OS, your priority should be also alternative messenger so ppl could leave google, fb or whatzapp… if i mention for example Monal for iOS it is true alternative with all for what people expecting from chat app.. (share media, groups, calls…)
Exactly my point ever. Thanks. Up to date xmpp implementation is one must have for SFOS from my POV.
