My journal gets spammed with this message:
XperiaXA2-DualSIM kernel: binder: 2945:2945 --> 0:0 transaction failed 29189/0, size 32-0 line 2149
Always this identical line, precisely once per second.
Even the numbers are always the same (though I believe the first, 2945 in this case, changes after a reboot).
Various threads here contain journal output that contains such lines, but it is never addressed in the problem/solution.
So, everything seems to work regardless and I probably shouldn’t worry about it, but it annoys me still.
Any ideas what this “binder” even is? and where is this line 2149
that apparently causes the message?
I tried this:
zypper info $(zypper search --provides binder | grep ^i | cut -d\| -f2)
Which tells me that binder is some Android* kernel module that deals with all interfaces and has loads of plugins. That’s very wide…
How can I narrow it down?
Disclaimer: I know, it is NOT a problem. I could just ignore it. If that’s all you have to say, please don’t.
* hasnothing to do with the Android subsytem.
