Yesterday I managed to install SFOS 5.1.0.11 Pispala on an XA2 (! 2018 !).
Today I tried to call my friend from the new operating system, without success. When I making a call, the phone switches from the 4G to the non-existent 2G network (T-COM HU) for some reason. The call fails. A few seconds later, the phone switches back to the 4G network. My friend can’t call me either. The phone back to 2G, and if the incoming call ended, it switch back to 4G.
" From January 2026, Telekom will gradually switch its 2G traffic to Yettel’s network, and their own 2G infrastructure will be effectively discontinued. After that, only the 4G and 5G-based networks will be operational. "
The T-COM SIM cards can not to connect to the Yettel network.
Why does the Xperia F5122 work properly?
Does this mean that I can throw away all my older phones? I am retired with modest resources, and I do not like android system…
It seems that from now on I will have to visit my friends in person.
-=L=-
I did not read all info from my link. Else I would have said above.
I am afraid we here in Germany will come to that soon™. Or hopefully not so soonish or not at all.
No 3G anymore. All 4G/5G require VoLTE. And providers about to retire 2G (why keep existing/proven/wide-spread technology up when it just costs them). I do wonder about all cars and vending machines and other IioT
All my precious would just even more precious
But maybe times come back and I can pull my old Wählscheibentelefon out of the cellar.
Here is the AI generated answer from my very old (???) phone
" The Nokia C1-01 does not support VoLTE, as it is a 2G/EDGE-era feature phone released in 2010 ( !!! ) and lacks the necessary hardware and software for 4G voice calling. "
The phone works flawlessly with a T-COM prepaid card. The question is : How? I use it every day for “business” purposes.
I don’t understand…
P.S. : I was a technician at NOKIA Hungary for 2 years in Komárom, until the factory was closed at the third quarter of 2014.
Ein bisschen Nostalgie : Éppen 10 éve, hogy bezárt a Nokia – Szia Komárom
Yettel and (Vodaf)one sims used to work in my XA2, and still work in my Xperia X III.
On calls the network switches back to 2G from 4G.
Unfortunately I don’t have a Telekom sim around or even in the close family that I could test.
Could it be related to the fact that Telekom uses the Yettel 2G network, and somehow Sailfish has an issue with in-country roaming?
Can you test with a Yettel or One sim?
As I wrote, the 16 year old NOKIA C1-01 works flawlessly even now. There is no 4G, no VoLTE, because the phone does not have the necessary electronic and software components. If I transfer this card to an XA2, it will not be possible to make or receive calls regardless of the 2G/4G setting. Yet the phone has the necessary electronic components.
Maybe the software is not good?
OFF
What do I want?
I like to use a mobile phone, a text message, an offline map while hiking, even where there is no signal - to take pictures. (Sailfish OS )
What don’t I want?
Watching movies online, listening to low resolutin music, reading unnecessary news. edit pictures with or without AI, do banking, post on Facebook, etc. on a palm-sized screen. ( android os )
ON
An XA2 with SailfishOS would have been ideal for this. Not the latest, but it’s small enough, light enough, and the battery lasts long enough.
I took out the One card from my dog’s GPS tracker. I bought this card in May and have already used it several times. The last time was 3 weeks ago. The result is the same.
I asked for my neighbour’s Yettel card. He uses this card every day.
I can not make or receive a call, and doesn’t matter if the preferred network is 2G or 4G.
This phone was officially registered in Hungary…
( Not Chinese, Indian, Japanese or overseas. )
As already pointed out, you will not be calling with 4G with that phone - it will be told to use 2G instead and place the call there. If 2G says “Network Denied”, maybe - just maybe - the network denied you?!
There are 3 main mobile providers in Hungary currently: Telekom (previously Westel), Yettel (previously Pannon GMS then Telenor) and One (previously Vodafone).
Hi!
Here’s a short video about why I think it’s a software bug:
You can clearly see that the dial app fall down to the desktop without touching the display. No matter what I’m trying to call either a real or invalid number.
The dialler works normally when I take out the card.
I handed a video of the old F5121 while dialling. I think this would be expected for the XA2 as well. Here, too, the phone switches from 4G to 2G, and a few seconds after the failed call ends, back to 4G.
I restored the original android system. Both making and receiving calls work fine with the Telekom SIM card with which the phone did not work with the Sailfish system.
And, would you now try again with SFOS?
At least we know now that device is okay and it has been seen by the network once.
And, you did not say explicitly, that you enabled roaming in SFOS when testing.
