[X10III] Connection in roaming not working anymore
Hello there,
Since three days my X10III cannot connect anymore to any cell tower (void signal strength symbol).
Use case:
  • Xperia 10 III with SFOS 4.6.0 installed;
  • Sim Iliad Italy in roaming on Germany.
Everything was working perfectly fine since three days, the phone would connect in roaming to either o2 - de, Vodafone.de or Telekom.de, in 4G, both in automatic and manual modes.
Suddenly, since three days, no connection in automatic mode. When I try in manual mode to search for networks, I get them listed. But whenever I tap on one of them, the waiting circle spins for a long time and then I get the notification of “Connection error”.
Restarting the network services doesn’t change anything, nor any other attempt like change of access point, 2G, 3G etc.
I’m trying to understand in parallel with the italian operator if it’s their culprit, or something has changed in the german networks… but could you help me to understand weather SFOS is fine?
Thanks.
Your post does not list results after
  • reboot
  • or restart ofono
Does your X10III work with German SIMs and German operators?
Did you exceet the fair use of your EU roaming?
I would suggest to file a Bug Report if you think it is a problem of SailfishOS.
Thank you both for your help.
Actually the SIM got de-magnetised / fried / whatever, inserting it into another phone with android would also give strange behaviours. Never happened to me, I thought it was a legend.
I spoke to the ISP center and they confirmed me I will have to replace it. Bye bye!
