I was grabbing some other logs with dmesg when I saw something curious there:
[88480.368490] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.370116] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.562815] [drm:dsi_display_set_mode] [msm-dsi-info]: mdp_transfer_time_us=15666 us
[88480.562822] [drm:dsi_display_set_mode] [msm-dsi-info]: hactive= 1080,vactive= 2520,fps=60
[88480.562871] [drm:dsi_ctrl_isr_configure] [msm-dsi-info]: dsi-ctrl-0: IRQ 385 registered
[88480.574322] dsi_panel_driver_touch_pinctrl_set_state: invalid 'somc_ts_int_active' pinstate
[88480.576128] @@@@ panel power on @@@@
[88480.623313] somc_panel_color_manager: somc_panel_inject_crtc_overrides (786): Override: Already have original funcs! Is setup called twice??
[88480.623413] somc_panel_color_manager: somc_panel_pcc_setup (884): Cannot read uv data: missing command
[88480.623438] somc_panel_color_manager: somc_panel_pcc_setup (888): u,v is flashed 0.
[88480.623458] somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Couldn't apply PCC calibration
[88480.623499] somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Cannot send HSIC calibration
[88480.629626] sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power up
[88480.629657] sec_ts 1-0048: [sec_input] sec_ts_start_device
[88480.629677] sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: ACTIVE
[88480.629764] (NULL device *): deviceless supply vdd not found, using dummy regulator
[88480.629966] (NULL device *): deviceless supply avdd not found, using dummy regulator
[88480.632094] sec_ts 1-0048: [sec_input] sec_ts_power: on: avdd:on, dvdd:on
[88480.637350] dsi_panel_driver_oled_short_det_handler: VREG_NG interrupt!
[88480.709609] sec_ts 1-0048: [sec_input] sec_ts_wait_for_ready: 09, 00, 10, 00, 00, 00, 00, 00 [0]
[88480.709624] sec_ts 1-0048: [sec_input] sec_ts_start_device: cover open, not send cmd
[88480.709855] sec_ts 1-0048: [sec_input] sec_ts_set_grip_type: re-init grip(0), edh:0, edg:0, lan:0
[88480.710712] sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 61 2 2 3 0 0 0
[88480.785047] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.789897] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.866986] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.871167] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88480.887234] droid-hal-init: processing action (ril.ecclist1=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:10)
[88481.947521] sec_ts 1-0048: [sec_input] [P] tID:0 x:587 y:13 z:30 major:7 minor:7 tc:1 type:0 noise:0
[88482.087851] sec_ts 1-0048: [sec_input] [R] tID:0 mc:15 tc:0 lx:608 ly:875 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
[88483.036012] sec_ts 1-0048: [sec_input] [P] tID:0 x:455 y:906 z:37 major:9 minor:9 tc:1 type:0 noise:0
[88483.218268] sec_ts 1-0048: [sec_input] [R] tID:0 mc:21 tc:0 lx:1079 ly:999 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
[88483.454417] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.460472] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.484245] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.498568] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.526892] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.540678] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.545438] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.550049] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.564878] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.582789] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88483.780908] set HBM mode=1
[88484.457486] sec_ts 1-0048: [sec_input] [P] tID:0 x:487 y:898 z:41 major:10 minor:10 tc:1 type:0 noise:0
[88484.498480] sec_ts 1-0048: [sec_input] [R] tID:0 mc:2 tc:0 lx:486 ly:899 v:0100 cal:A2 id(0,0) p:0 noise:0 lp:(0)
[88484.529177] set HBM mode=0
[88487.180085] sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power down
[88487.180187] (NULL device *): deviceless supply vdd not found, using dummy regulator
[88487.180317] (NULL device *): deviceless supply avdd not found, using dummy regulator
[88487.184514] sec_ts 1-0048: [sec_input] sec_ts_power: off: avdd:on, dvdd:on
[88487.184594] sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: SUSPEND
[88487.184613] Entering OFF state from 0
[88487.184616] AOD mode OFF
[88487.397686] @@@@ panel power off @@@@
This is:
- Unlock using fingerprint
- Open top menu
- Swipe brightness from mid, to max, back to mid
- Lock using power button
The most interesting bit I think:
set HBM mode=1 // Swiped to max brightness / screen reaches max brightness
set HBM mode=0 // Swiped to lower brighness / screen lowers brightness down from max
This is what happens, when I fingerprint-unlock the screen with full brightness, and lock it again:
[88915.948070] [drm:dsi_display_set_mode] [msm-dsi-info]: mdp_transfer_time_us=15666 us
[88915.948077] [drm:dsi_display_set_mode] [msm-dsi-info]: hactive= 1080,vactive= 2520,fps=60
[88915.948124] [drm:dsi_ctrl_isr_configure] [msm-dsi-info]: dsi-ctrl-0: IRQ 385 registered
[88915.959483] dsi_panel_driver_touch_pinctrl_set_state: invalid 'somc_ts_int_active' pinstate
[88915.961236] @@@@ panel power on @@@@
[88916.008562] somc_panel_color_manager: somc_panel_inject_crtc_overrides (786): Override: Already have original funcs! Is setup called twice??
[88916.008614] somc_panel_color_manager: somc_panel_pcc_setup (884): Cannot read uv data: missing command
[88916.008644] somc_panel_color_manager: somc_panel_pcc_setup (888): u,v is flashed 0.
[88916.008670] somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Couldn't apply PCC calibration
[88916.008720] somc_panel_color_manager: somc_panel_colormgr_apply_calibrations: Cannot send HSIC calibration
[88916.015121] sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power up
[88916.015162] sec_ts 1-0048: [sec_input] sec_ts_start_device
[88916.015189] sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: ACTIVE
[88916.015293] (NULL device *): deviceless supply vdd not found, using dummy regulator
[88916.015673] (NULL device *): deviceless supply avdd not found, using dummy regulator
[88916.017847] sec_ts 1-0048: [sec_input] sec_ts_power: on: avdd:on, dvdd:on
[88916.022780] dsi_panel_driver_oled_short_det_handler: VREG_NG interrupt!
[88916.094287] sec_ts 1-0048: [sec_input] sec_ts_wait_for_ready: 09, 00, 10, 00, 00, 00, 00, 00 [0]
[88916.094302] sec_ts 1-0048: [sec_input] sec_ts_start_device: cover open, not send cmd
[88916.094523] sec_ts 1-0048: [sec_input] sec_ts_set_grip_type: re-init grip(0), edh:0, edg:0, lan:0
[88916.095315] sec_ts 1-0048: [sec_input] sec_ts_read_event: STATUS 1d 61 2 2 3 0 0 0
[88916.198566] set HBM mode=1
[88916.253020] droid-hal-init: processing action (ril.ecclist1=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:10)
[88916.257761] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88916.267108] droid-hal-init: processing action (ril.ecclist=*) from (/usr/libexec/droid-hybris/system/etc/init/ecclist.rc:6)
[88916.827450] healthd: battery l=34 v=3832 t=31.7 h=2 st=2 c=132446 fc=0 cc=8 chg=u
[88917.903470] set HBM mode=0
[88917.919899] rpmh_rsc_send_data: 211 callbacks suppressed
[88917.919903] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.929426] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.929444] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.934501] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.939145] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.943332] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.958085] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88917.980261] qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x30010
[88918.003702] sec_ts 1-0048: [sec_input] sec_ts_dsi_panel_notifier_cb: power down
[88918.003803] (NULL device *): deviceless supply vdd not found, using dummy regulator
[88918.003930] (NULL device *): deviceless supply avdd not found, using dummy regulator
[88918.008004] sec_ts 1-0048: [sec_input] sec_ts_power: off: avdd:on, dvdd:on
[88918.008073] sec_ts 1-0048: [sec_input] sec_ts_pinctrl_configure: SUSPEND
[88918.008091] Entering OFF state from 0
[88918.008092] AOD mode OFF
[88918.221126] @@@@ panel power off @@@@
