BUILD ID = OS VERSION (Settings > About product): 4.3
HARDWARE (XA2, X10, X10 II, …): gemini pda
UI LANGUAGE: german
DESCRIPTION: when you set orientation to landscape, it is inverted.
PRECONDITIONS: none
choose landscape orientation instead dynamic in settings.
Orientation to be choosen should be landscape inverted, but only landscape is available.
When you choose landscape, display is upside down.
I know all the patches, i only want to choose landscape inverted in sailfish settings, but there are only entries for portrait and landscape.
hi @tac , I dont know if I did it wrong previously, or if anything has changed, but I can fix the rotation now in correct landscape mode on gemini pda.
use the pull down menu from the top to go to free rotation mode, hold the device in desired landscape configuration, use the fix rotation toggle (maybe more than once) in the pull down menu, and it fixes in current orientation.
(edit: in the screen settings, you should keep rotation as dynamic)
