REPRODUCIBILITY (% or how often): 100
BUILD ID: 3.3.0.16 Rokua
HARDWARE (Jolla1, Tablet, XA2,…): Xperia 10
UI LANGUAGE: German
REGRESSION: (compared to previous public release: Yes, No, ?): I don’t know
When using some android apps like dict.cc and yandex browser, when typing something, changing the cursorposition and typing again, the cursorposition does not stay but will jump back to the first used position and add the typed text there (or delete if the delete button is used). The only trick to be able to change something at another position is to switch to the desktop and back into the app. Then again only the first chosen cursor position will work no matter how often or where i put the cursor.
open dict.cc
type something in
after a few seconds replace the cursor to another position
type something
at the new cursor position should the typed be added
the cursor jumps back to the first position and adds the typed there
I am seeing this occasionally on Fennec F-Droid, too. IIRC, swiping the keyboard away, and focusing the text field again is a workaround. Certainly a papercut nevertheless.
Can confirm this bug , in any browser , since a few years noticed on different types of mobiles and builds, i hoped some bugs , new or old would be fixed asap but that’s wishful thinking on my side.
After a very long time of NOT having this issue (to the point that I managed to completely forget about its existence), this nasty bug magically re-appeared on 4.6.0.13 and now troubles me on every text input in Android apps
