The Jolla Phone 2026 has no wireless charging, and I wanted to just put it on a Qi pad. The Other Half connector has a power input pin that charges the phone, so I tried feeding it from a cheap Qi receiver on my TOH DevKit, and it works.
It’s a prototype on the breadboard cover, not a finished cover yet.
What it does
Put your Jolla on any Qi charging pad and it charges, with no cable and no extra software.
What it is
Hardware: a generic 5 V / 1 A Qi receiver module (a flat coil plus a small board), its output soldered to the TOH’s power input pin (pin 1) and GND.
Speed: the docs say charging through pin 1 is limited to 1 A, so with this 5 V receiver I expect about 5 W. For “passive charging” like on long car rides or at work where you just set the phone down for a couple hours it fulfills its purpose exactly and should keep the battery topped up.
What works
Charging on my Qi pad: the phone starts charging as soon as it lies on the pad and stops when I lift it (see the GIF).
Next I’d like to build it into a real 3D-printed cover. I would expect it to fit into pretty much the same thickness as any default jolla case since it doesnt need any place to house extra electronics like microcontrollers or breakout boards.
I am currently not planning on selling anything yet, mostly because of the bureaucratic overhead this would cause. Once i know how to sell properly I might do it, but right now I lack the necessary legal knowledge.
Install
You need a TOH DevKit (or any cover with a contact board that brings out pin 1) and a 5 V Qi receiver module.
Check the receiver: lay the coil on your Qi pad and measure its output with a multimeter. You should see about 5 V.
Unplug the USB cable from the phone.
Solder the receiver’s + to the contact board’s VIN pad (pin 1) and − to GND. Nothing else may touch VIN: never connect it to the cover’s 5 V (pin 7), which is the phone’s power output.
Tape the coil onto the back of the cover, copper side out, and put the cover on the phone.
Lay the phone on the Qi pad and check the lock screen for “Charging…”.
Questions for you guys
The PI flag: the TOH spec has a “power input TOH” flag in the cover’s memory chip. Charging works without it here; does anyone know what the phone does with it?
A real cover: would you use a thin Qi charging cover, or would you rather have Qi as part of a battery cover?
Details
How it works (for developers)
Pin 1 takes 5–9 V and charges the phone; the docs say charging from the TOH is disabled while USB power is connected.
Kernel: according to the usb-moded source, power on pin 1 shows up on the same charger as USB (on my phone /sys/class/power_supply/primary_chg), with usb_typeDCP (like a wall charger) instead of SDP (a PC). I haven’t read these values while charging yet.
usb-moded reads usb_type since 0.86.0+mer70 (“TOH Charging”, sailfishos/usb-moded#28), so it should treat TOH power as a charger and not show the USB mode dialog.
Usually I would share some source code or files but its mostly just the TOH DevKit with the qi charger soldered to it. Maybe I add a git repo if it gets more complicated than that for further iterations of the project.
Made with the help of Claude. Tested on Jolla Phone 2026, Sailfish OS 5.2.0.22 - use at your own risk.
thanks for the reply. i am currently thinking on how to design the cover.
the problem with using default covers and just adding to it is that you can’t solder the pin-connector-board on the bottom cause you must not introduce distance between the pins and the board. and if you solder on the oder side you have like a half mm bump thats also suboptimal.
but its a good call. maybe i try it on a default cover first and see if it introduces problems.
i tried for like 20 minutes to get it working with a default jolla cover. It might be that i am dumb but either i cant get the positioning of the contact pcb right today, or maybe the jolla only accepts charging once a back cover has been detected via the 6.2k resistor for dev mode or 10k resistor for chip / rom mode.
not sure but lmk if you can get it to work. seems like one of those things that just works when i had a good nights sleep without changing anything in the process
I so feel this. But apparently not the case this time: the EEPROM apparently needs to tel the phone that it can charge it. Not sure if that applies in dev mode, or is ignored - but for normal operation anyway.
i guess expensive is relative. i paid 20 euro for 10 empty PCBs with 0.6mm thickness at JLCPCB cause they have to be ENIG (gold) finish to work properly with the pins afaik. but idk about pricing of assembled and flex boards.
Is the final version going to charge 5-6 times faster?
Cause my j2 needs 2.5h for a full charge with a 30W MacBook charger as an example.
I’m happy to see the TOH, don’t get me wrong. I’m just wondering if your statement about it being a prototype (regarding speed) means that from estimated 2 workdays of charging time would get to something reasonable like 3 hours, or we are talking about a watt or 2?
This will probably not age well.
With real world usage that you should expect about 60% efficiency, plus the actual charging curve from the bms, plus the heat, you should at least triple what you expect.
Again, the phone charges right now, wired, 30W, in 2.5H.
But anyway, no need to drag this until we see first short term and then more of a long term results with a final product.
It depends on the user expectations. For some users charging overnight or put the phone on the coil during work/study or any other longer activity is great use case.
That single digit wattage (the theoretical TOH interface limit) was debated long ago already.
I’m sure there will be people totally fine with it. This is a hardware limitation so there’s nothing else we can do other than argue if 10-15 hours works for some people or not.
My comment was about the expected charging time because it doesn’t look realistic with my experience.
Great use case for me. This gizmo is already charging faster than my typical charging routine. I only do slow charge, 2.5 W on computer USB. Similar to the electric car debate, there is no need to consider how long it would take to charge fully, because it very rarely occurs to have to charge it fully. I charge my phone when coming back from work, on a slow USB, so it goes back to 80% of charge in whatever time it needs, but typically not that long because it’s going to start from 40-50%.
if it needs 2.5h hours for a complete charge it is not using 30W. I have a charger with a display that shows the charging power, and when it shows (slightly below) 30 W the required time for a complete (in fact only up to 90%)) charge is slightly more than 1 h
Just pointing out that 2.5W is generally not the norm for people who use their phones, and definitely not the benchmark after the 1980s.
But if this sort of “micro dosing” on the charger works for you, sounds good to me.
Let’s leave this topic for now and maybe use the other discussion because I don’t really want to drag this here where it’s definitely off topic (at least now).
Obviously. No phone is charging with constant power through the charging cycle. At least phones without faulty BMS or swelling batteries (and I have a few of those actually).
definitely thinking about it. but as my original post says (and since we are in the eu), it’s pretty much impossible from a bureaucratic standpoint for me as a tinkerer to sell these properly. from what i understand, even selling a handful would mean:
radio equipment directive: a qi receiver counts as radio equipment, so it would need lab testing (radio + emc), technical documentation and a declaration of conformity before it can get a ce mark
general product safety regulation: risk assessment, documentation, traceability, a contact person for the authorities. no exception for small sellers
weee: registering as an electronics producer and reporting in every eu country i’d ship to
liability: if a cover ever fries someone’s phone, that’s on me, so i’d want insurance too
realistically “production at scale” probably means like 10 of them, maybe a few dozen in an optimal world. i don’t think that justifies what i estimate at roughly €3,000–10,000 up front plus a few hundred euros a year simply in bureaucratic costs.
since i am financially deep in the red with my jolla R&D anyway and have come to terms with never making that money back, i am thinking of doing giveaways once the final versions are done.
