[Working Prototype] Qi Charging TOH: wireless charging for your Jolla Phone 2026
thanks for the feedback. i too think that its a great use case for putting it down on the table at work and then going home with a topped up battery or vice versa. Basically whenever you are somehwere for a long time you can just place the phone on the charger and it will keep it topped off :slight_smile:
Well, you can just sell them privately with a clear statement of non-conformance and a waiver of warranty. The directives can safely be ignored as long as you’re not selling on a platform and just do it directly. I even ignore the directives on platform sales because they are mostly bullshit. A cell-phone will easily be approved in the current regimen though it is demonstrable that it’s emissions (EMF) are an extreme interference source in many contexts (try a home recording studio. mobile phones banned). EDIT: yeah, It’s also captain obvious that a cellphone is going to be an EMF nightmare. Just saying.
If your intention is to make money then give us your instructions how to buy from you. If you don’t want more money, then give us the reference to the hardware you tested and works.
Franken-Palm’ed my original Jolla Phone that way back then, reusing a so-called Touchstone and its receptor. Recommend!
This is so cool.
I would definitely buy this, when it is done.
