The Jolla Phone 2026 has no IR blaster, and I kept wanting one for the TV and the projector. So I built an IR module for my TOH DevKit: a cheap IR transmitter and receiver on the breadboard, plus an app that has the remotes.
It’s a prototype on the breadboard cover, not a finished cover yet. I’m not an expert in any of this, so if you see something I got wrong or know a better way, please tell me.
What it does
Your Jolla becomes a universal remote: pick your TV, projector or soundbar from about 1950 remotes, or teach it any button from the original remote, and control it from the phone.
What it is
Hardware: a 38 kHz IR receiver module and an IR transmitter module (a cheap Arduino kit), both on the RP2040-Zero’s 3.3 V. The RP2040 only does the timing: it sends the on/off durations the phone gives it and records what the receiver sees.
IR Remote app: everything else happens on the phone.
- Add remote: pick your device from the Flipper-IRDB database (about 1950 remotes, public domain), search by brand or model. It then stays in your list of remotes.
- Buttons in their usual places: power, D-pad, volume/channel, colour keys, media keys and number pad where you’d expect them; anything else goes under “More buttons”.
- Long press any button → Record new signal: point the original remote at the back of the phone and press the button. This overwrites the button, so you can fix or complete any remote. A blank remote lets you record every button yourself.
- Universal remotes (TV, projector, audio, air conditioner, from the Flipper Zero project, downloaded when you add one): every tap tries the next code, and Worked keeps the one your device reacted to.
Protocols: NEC, Samsung, RC5, RC6 (Philips), Sony SIRC, Panasonic (Kaseikyo), RCA, Pioneer, and raw recordings for everything else. I checked NEC, RC5, RC6, Samsung and Sony by letting the board receive its own signals: they come out with the right timing.
What works
- My Grundig TV and my NexiGo Aurora Pro projector turn on from the phone (see the GIFs).
- Recording: my projector isn’t in the database, so I recorded its Power button from the original remote. The app recognised it as an NEC code and saved it as that, not as a raw recording.
I haven’t measured the range yet. I expect it to be short, because the transmitter module drives its LED straight from the 3.3 V pin; a transistor and a stronger LED are next.
After that the next step would probably be to design a 3D-printable case for it - while we are at it I will fix the wobble the camera bump causes by making the camera bump wider, which coincidentally will also house all the electronics. I expect the ToH to be about the same thickness as a non-electronic cover since the bigger camera bump should comfortably house he PCBs.
I am currently not planning on selling anything yet, mostly because of the bureaucratic overhead this would cause. Once i know how to sell properly I might do it, but right now I lack the necessary legal knowledge.
Install
You need a working TOH DevKit with its phone package installed.
Wire the modules to the RP2040-Zero (pin numbers as printed on the Zero):
- receiver: OUT → 14, VCC → 3V3, GND → GND
- transmitter: DAT → 7, VCC → 3V3, GND → GND
Use 3V3, not 5V: the receiver’s output follows its supply, and the RP2040’s pins only take 3.3 V. If you added the DevKit’s optional LED on pin 14, take it off: the receiver uses that pin now.
Flash the firmware: download
toh-ir-fw.uf2from the latest release, hold BOOT on the Zero, plug it into your PC, copy the file onto the RPI-RP2 drive. -
Install the app: download the
.rpmfrom the latest release on the phone and tap it in the file manager. -
Take the cover off and put it back on (the phone reads the cover’s config on attach), then open IR Remote.
Uninstall
devel-su pkcon remove toh-ir
The DevKit firmware can go back onto the Zero the same way as in step 2.
Questions for you guys
- The phone’s own IR driver: the kernel has an IR transmitter driver (
/dev/lirc0, “MTK PWM IR Transmitter”), but every send fails with “Cannot allocate memory”, and the specs don’t list an IR LED. I think it’s a leftover from MediaTek’s reference design. Does anyone know more? - A real cover: would you use a small IR cover (just the LED, the receiver and a tiny microcontroller), or rather have IR as part of a bigger multitool cover?
Source & Download
How it works (for developers)
- Firmware (Arduino, RP2040-Zero): the DevKit’s I²C target at 0x42, plus IR registers: a send buffer (durations as 16-bit microseconds, carrier frequency), a learn command and a buffer for the recorded frame, each with a checksum. The phone validates and retries, because the first transfers after the RP2040 restarts can come back garbled.
- toh-ird (Go): a session D-Bus service started on demand. It encodes the protocols, keeps your remotes as Flipper
.irfiles in~/.local/share/toh-ir/remotes/(so they should also work on a Flipper), and has a small command line for testing (probe,code <protocol> <address> <command>,send,learn). - App: pure QML, like the DevKit app.
- symbiosis config: an extra YAML next to the DevKit’s. symbiosis merges the access lists of all YAML files in a cover’s folder, so a second app for the same cover only needs its own file.
Made with the help of Claude. BSD-3-Clause. The remote database is Flipper-IRDB (CC0); the universal remotes come from the Flipper Zero firmware (GPL-3.0) and are downloaded by the app, not included. Tested on Jolla Phone 2026, Sailfish OS 5.2.0.22 - use at your own risk.
