My 10 III, 4.4.0.68 does downloads.
This not a common problem, I think.
Was the echo (on WhatsApp) fixed on the 10 iii? Did anyone solve high battery drain when idle?
The hotspot problem is with the 10 iii providing it? That I can live with. I see no reason why it should have a problem using a hotspot from a different device.
I can get one for around âŹ210.
I lost my XA2.
If I were you I would buy it.
Is 5g working? My carrier (o2 germany) switched and seems to have dropped 4gâŠ
No, 5G is not working. However I donât think O2 has dropped 4G systematically. Maybe it is a temporal local thing.
Iâd be very surprised if there is anywhere with only 5G.
There is no âdropâ of 4G here. 5G here is hit in miss unless youâre in the center of Munich, or the like. Nor will there be a drop for quite some time. 3G on the other hand is a goner. I believe. But, I like 2.5 best anyway
You could check your area for known problems using o2 Störung? Netzausfall & Netzprobleme im Live-Check prĂŒfen
