REPRODUCIBILITY: 75% (often)
OSVERSION: 4.4.0.72
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.0.176 - aarch64
UI LANGUAGE: Polski (user: pl_PL, os: pl_PL.utf8)
REGRESSION: no
I went back to travelling, which made me realised that network switching behaviour is much different when hotspot is enabled or not. By default, network switching on SFOS is a bit rough, but good enough.
But when I enable hotspot and move enough it will have to switch networks a few time, I will end up with it uses using 3G, no matter how good 4G range is and how bad 3G is. At least after disabling hotspot it will switch to 4G after a while.
What is more annoying, is when sometimes it gets stuck on 3G without data transfer, and then only way to fix it is to reboot the phone.
This behaviour happens to be every time I drive a bus or a train, sometimes it takes an hour, sometimes 20minutes. Happens even sometimes when I am stationary.
Is ofono’s behaviour different when hotspot is on or off? Could it be changed back to stock, as it is much more reliable?
- Turn on WiFi Hotspot
- Drive a car or bus, where the phone has to switch between 4G and 3G a few times, or just go through a place with weak signal
- Soon it gets stuck on 3G, and if you disable hotspot sometimes it will go back ti 4G after a few seconds
- Sometimes though, it will get stuck on 3G but with no data transfer. Then even if I disable hotspot, it will still stay stuck like that, with no data and 3G
- If I turn on airplane on, or swtich to 3G preference and then back to 4G preference, or even restart ofono it will connect to 4G for a second, and then switch back to 3G, still without data.
EXPECTED RESULTS:
ACTUAL RESULTS:
- Patchmanager: yes
- OpenRepos: yes
- Chum: yes
- Other: yes:
MicroG and a lot of Android apps
Home Encryption: enabled
