This fix should take effect immediately, but maybe we messed something up again. Would be great if you can make an issue on Gitlab.
Had an out-of-band ping from @projectmoon as well, fixed!
This is probably suuuper stupid question, but can I signin to Gitlab without giving out credit card?
Apologies if this is a stupid question but how does it work? I wasnāt able to find it.
Oh yes, absolutely. Accounts are free of charge. The most viable alternative to filing an issue is to make either @direc85 or me suffer from the same problem :'-)
I now see how it can be double interpreted. When receiving or sending more than one attachment, you can now swipe through the messageās attachments. The alternative interpretation, where you can see all attachments of a chat, is not yet implemented (but also highly desirable!).
I did change the setting from WF, force closed it and reopened, but didnāt reboot the phone. But at least for now the names donāt follow the device contacts and I canāt manually link them
I have the same issue still after the update
Just tested this and hey presto! I can scroll through the images, though it didnāt play an attached mp4 video.
Can confirm this.
Was added to a group yesterday, contains only pics. Would not see the group in WF untill i did send a message in signal.
Then group is visible in WF without any messages
Picture sharing is still broken on beta 43, sadly.
Try uninstalling and reinstalling the share plugin. I have updated the repo on OpenRepos recently.
that fixed it, thanks!
This release restores group messaging. Since July (0.6.0-beta.42), group messages have been silently arriving but failing to decrypt, so conversations progressively and permanently went silent (1:1 messages were unaffected). Whisperfish would ignore sender key distribution messages, because of a misplaced early return. We also started sending DMEās, which basically means groups will heal rather quickly after installing. This also fixes identity key resets (which were wrongly associating ACIās and PNIās and hence never resetting except for exceptional cases). Furthermore, identity-key-change notices (and pending message requests) no longer inflate the cover unread badge.
--verbose log listHi,
Thanks for the update and all the huge work.
It seems I receive one notification per new message (I didnāt count but many, anyway).
Is it only me, or is it kind of normal at the moment?
Thanks
Yeh. Weāve rewired the notification system a gazillion times by now, and every time some new idiocy pops up like this⦠Iām tempted to rewrite the thing in Rust and just expose the delta via QML :'-)
Ok, thanks, good then.
I donāt understand what you say about Rust and Qml but totally agree! ![]()
Is there a way to import the chat history in Whisperfish? Sorry if itās something obvious that Iām missing, I looked everywhere amd I didināt find that option and read through multiple forum posts.
Correct me if Iām wrong, but I tried a couple of times, but couldnāt find a way. I think itās impossible as of now.
My groups are still silent except for my own posts.
I got the same problem. Linking contacts to a contact in Whisperfish/ Signal just shows: No contacts
Also does the manual way of adding an emoji to Whisperfish worked (I tested with the newest/ current release) for any of you?
The other one with patched emoji keyboard is not possible atm due to it not being updated to 5.2.x
A bit of a bummer for me. But thanks anyway!
