I think you mean this issue and this fix. It only stops the service in the background, not the “individual” process. I’m not sure if we should issue killall harbour-whisperfish too, that sounds too big of a sledgehammer here…
I have been able to make Whisperfish <beta.10 close its UI, but still remain running, by closing it after device lock period while the device is in charger and the screen not turning off in charger. I think I’ll make an issue about it to see if it’s something we could grab and fix - but that’s quite low priority.
I’m using Whisperfish (beta11) as a secondary device, and I am unable to send messages to at least one contact (HTTP 428 error). Resetting identity keys did not fix the problem.
That is a known issue, and it is being tackled on soon, hopefully in time for the next release. I’ll add it to the opening post, too, so thanks for nudging the topic
I can elaborate, but not reproduce right now.
I was able to start Signal Desktop as well as sending and receiving messages, but none of these actions have been causing any reaction or entry of any kind in WF, it was as if both have no interaction at all.
I disconnected Signal Desktop then and tried to link it again, but without luck, I entered the QR address, but nothing happened.
I followed the guide then in the FAQ to restart WF and register again, but now I am only getting “Failed to setup Signal client” and I’m locked out entirely from using it.
I will read here if there is an approach for this issue and report back.
Thanks!
Edit: Starting from console I was able to register again, no idea what this was caused by.
I was able now to link Signal Desktop again and I have the same status quo: I can send and receive messages with Signal Desktop, but I can’t see any of this in WF, I can’t send any messages in WF and I can’t receive messages with WF.
HI again @Smirftsch! Sounds like you can reproduce it now. Would you be able to get a log on Gitlab, or alternatively mail/DM me one for me to make an issue? Difficult to know what’s going on here without a log. You may want to check the FAQ for sanitizing the log before you send it. If you send it to me, I’ll double check the sanitization.
After another killall and restarting Signal Desktop it appears to be working now and I am getting indeed messages on both sides. I’ll do another restart trying to reproduce with --verbose for you.
This ticket just explained why the --captcha argument failed for multiple people: BusyBox doesn’t support arguments longer than 1024 (or something similar, if it’s not exactly that wording). It so happens fish doesn’t suffer from the same limitation, which is why I wasn’t able to reproduce it myself. Better later than never …
I use Whisperfish beta11 daily and it works almost flawlessly. Big thank you for the app! The only real flaw I’ve noticed is Whisperfish crashing in the background, which means I need to notice it has crashed in order to restart the app to receive new messages. Then again, this seems like an OS level error.
Today I noticed that images need to have a .jpeg or similar type of suffix to be sent successfully. I was having difficulties sending one particular photo to my friend, until I renamed it from picture to picture.jpg. Fernschreiber, for example, is able to send the image without the suffix, but Whisperfish hangs the message and needs to be rebooted to send any new messages.
I’m sorry if this is a known issue, I tried to search the topic, but didn’t find any mention about this.
Thanks for the feedback! Glad to hear it’s working well!
I have no immediate guesse why WF would hang in the background. I haven’t had any issues with it… Could you capture logs of it? There are instructions of it in the wiki. Remember sanitating the log!
Sending images (well, any files really) without extension is a curious use case indeed. Whisperfish shouldn’t hang though, so that’s a bug. That should be an easy fix, if the issue is where I think it is. Would you mind dropping an issue about this in GitLab? I can do it, too, if you prefer that
Sorry, I was being a bit unclear in my first post. What I wanted to say was, that WF hanging in the background may be due to low memory killer (or other similar OS process) and it’s not caused by WF itself. I can try to capture relevant logs regarding this issue, if you or @rubdos find this interesting.
I don’t have a GitLab account, so I’d appreciate if you or somebody else could file the report on my behalf! Do you think it would be possible to send files without the filename extension in the future?
I managed to reproduce the non-working sending of attachment with copying a PNG screenshot to a file without attachment. For some reason, it may fail the QML side, or the Rust side. I grabbed the logs of the crashes, so I’ll create the issue.
Thanks for reporting!
Edit: On second look, there’s only a Rust crash, the assumed QML error is benign.
Oh right, the crashing. You didn’t mention what device you were using, but that sounds like an OOM situation. If you’re running Xperia 10 III, you might want to check out this post/thread (the swappiness stuff can be ignored).
Ditto, BUT, there are a couple of cases where the contact IS in my contacts (ie. the telephone number is there). This I found disturbing. I’ll try to gather more information. One contact I have a thread where he’s identified (ie. contact name shows) but a later message (initiated from his end) has a uiid, but not name.
@tuplasuhveli I just made a merge request to fix the crash by setting the default MIME type to application/octet-stream if the file extension is missing. This lets the attachment to be sent, but Signal Android doesn’t show the thumbnail - which is actually expected in this case. Images (well, any other known file types too) with wrong extension are kind of a corner case after all.
@nephros I’ve hit that a few times too; I have a number in my contacts and another “contact” in Whisperfish with UUID only. It’s not immediately fixable now, save some database voodoo perhaps which is obviously not recommened. It’s a known issue, with top priority.
@martijntje We already have part of that in place at the receiver side, so having that at the sender side would make sense too.
@poetaster Signal is working towards a system without mandatory phone numbers, and this is part of the result. The UUID-contacts are contacts for which we do not know the phone number (but for who we could most probably request it from the server). This is a whole new feature in the Signal API and needs quite a bit of work to get up there.
Would it be possible to add a “note” or “nick” or “local name” on the Whisperfish side so I can at least have some idea who or what that contact is? I mean something that is stored on the device/user data only independently from Signal?
Personally I wouldn’t even need an UI for it, a JSON or XML file in ~/.local or ~/.config mapping uuid to some string would be good enough.
I’m currently working towards getting the complete profile downloaded. It’s slightly less code than I thought it was going to be. Not sure when it’ll be finished though. Going through a very busy time with many other things…
I somehow solved this by linking the UUID to a contact. You need to have a corresponding contact, though, and have to be sure that the UUID in question really has that name. In larger groups, this is quite tedious, so I really look forward to Ruben’s work on this.
Sending messages to V2 groups also does not work (here), they never get sent.
