I installed it. When I open the app it just say: (translatet from norwegian) unable to setup signal client
I’m having the same issue at the moment. I originally installed WP from Storeman which was beta 9. I started setup, but stopped part way through. When I next went back to continue I get this screen
I restarted WP and the phone a few times and nothing changed.
Then I tried installing beta 46 via Harpoon, which gets me a bit further. I have managed to get as far as getting an SMS code but then WP didn’t accept it, it just spun once entered. Then I got the failed to setup signal client screen again. I’ve tried a few more times and get various amounts through setup, but never as far as getting an SMS code again.
I wondered if it could be some bad config from beta 9 or something so I was going to reinstall, but I don’t seem to be able to uninstall WP from either the app draw, harpoon or storeman. I get this error message from Storeman
I’m on a JP26 running 5.2.0.22
You can try to reset the client data via terminal. Has worked for me in the past.
rm -rf ~/.local/share/harbour-whisperfish ~/.config/harbour-whisperfish ~/.local/share/be.rubdos/harbour-whisperfish ~/.config/be.rubdos/harbour-whisperfish
Didn’t help unfortunately. I got as far as doing the captcha then when it returned from the browser I got the failed message again. Same on a few attempts sometimes getting the captcha after entering my phone number, sometimes not.
Isnt that an alternative build targeting Sailfish 4.6?
Hi i am on 5.2.0.22 at Xperia XA2 and latest WF. Attachment sending is broken can anybody confirm?
Textmessages only are working. ![]()
Would hosting in chum be an option?
How do I start a conversation with a contact from my contact list on the device?
The only options for that is using either your primary Signal app for that or if you have Desktop Signal. Once the conversation exists you can use that also on Whisperfish.
Starting a new conversation is not yet a feature in Whisperfish, Ruben may correct me if I said anything wrong ![]()
Hi, I like the idea of having my old android phone at home with android apps, if anything goes wrong I am not completely cut off. I cannot have the same Signal running on two different android phones. So I installed whisperfish and while all went well until I had to scan the QR, I went looking for another phone, meanwhile the QR timed off. No chance getting it back, I get error on client setup, and please restart whisperfish. Done that, and the phone too, no QR just the same error message. What should I do next to get it installed and working?
Starting new chats requires using e.g. a linked Signal Desktop for it.
QR code timeout when linking Whisperfish has a fix pending, but it’s not out just yet. Should not take that long to get it released. Stay tuned, we have quite a nice bunch of fixes and changes ready (or almost ready)!
To install, you have two options:
- Releases from OpenRepos
- “Nightly” builds from the Gitlab Package Registry.
In most cases, there should be no need to install from Git directly. We push regular updates to OpenRepos, when they make sense.
But no idea what version you should get there
The nightly build worked! Tnx
Being able to start conversations is kinda important for it to be useful, though?
It is certainly a feature that we all would like to have but honestly for me it is not a deal breaker. Others can start a conversation and I do have the desktop signal application so when at home I can start one as well.
The way I use Signal, it is really basically mostly the same conversations anyway.
@Beethoven The nightly build worked for me as well. Image uploads works again with it.
Guys, I have just returned to sailfish from using graphene for years (Jolla Phone 2026, before xperia), stop fooling around (yes I know, AI slop sucks but mostly it is knowledge amplifier - garbage in, garbage out). Clone molly at GitHub - mollyim/mollyim-android: Enhanced and security-focused fork of Signal. · GitHub , run AI over it and make AI implement the missing features in whisperfish.
Use Strata to avoid paying a dime: GitHub - Niko1221/Strata: Qwen3.8-Flash-Next on any consumer hardware: one-click install for Windows / Linux. Strata inference engine, OpenAI/Anthropic API on localhost, optional image input. · GitHub , I am getting 2000 tokens/s on reading and 60-70 tokens on writing with Coder IQ1_M (optimized Fedora 44, with 64 DDR5 6000, Radeon 9070, Ryzen 7800X3D), it is Qwant 3.8 stripped of non coding related parts and it actually works great - do review code and avoid one shot prompts, guide it. Imagine yourself as team manager.
I am software developer for 35 years, AI sucks, I was even laid off for not using it enough in core team in one HFT company, but it is fast. Sailfish is starving for native applications that are on similar level as android/ios apps and this is killing the adaptation. Get over it and just provide the features.
(and yes, this goes for any project)
With great power…you know how this goes right?
it appears whisperfish installed straight from openrepos is not finishing the registration. I used to have it working some years back on my xperia; but now on the Jolla phone it crashes when I try to register the device (right after entering the country + number).
