Messages show as unsent in status under settings. How can connect signal desktop? Whisperfish is my primary client. Reconnecting did not help.
It’s probably a Signal change. In that case, we can only wait for a new whisperfish release.
Sending attachments is currently broken. Since OR is down, uploading there won’t work, but fix is done and incoming.
Well then it looks like I am the only one where sending anything does not work. Or can anybody else confirm?
OK I restarted my phone completely and now sending messages works again. Weird…
Out of curiosity, did you try restart WF? I have had problems that didn’t get fixed by closing WF and reopening it. And problem was that I had activated “Background mode” so of course just closing the app and reopening didn’t do anything… Stupid me… Do you have that also enabled? If so, next time you could try to close WF from it settings using the “Quit Whisperfish”, which will really close it. That has fixed the problem in my case, but of course achievable also by restarting the whole phone.
I had the same issue. Quitting and restarting Whisperfish didn’t work. A reboot did the trick.
Yes I have background mode enabled and used quit WF from settings but it did not help.
For me Whisperfish seems broken. No QR-code appears. Only an advise to start Whisperfish again. I tried the command to reset and I did also restart the phone.
JP26
Sailfish 5.2.0.22
0.6.0.beta.46-1
I don’t know whst else could help.
Now I was able to scan the QR-code and connect Whisperfish as a secundary device. But after that I only see: Whisperfish, start a conversation via a connected device. My chats do not sync. On the iPhone Signal app (primary device) it shows Whisperfish as a connected device.
This is completely normal, Whisperfish doesn’t sync your messages from your primary device which were sent BEFORE you linked Whisperfish.
Now that it is linked, all conversations should appear in Whisperfish, with whatever connected device you send them
Unfortunately, for me too, since lately I’m not able to send image attachments! I restarted Whisperfish, tried resending, other JPGs and taking photos with the camera, but to no avail..
Also cannot send audio attachments :sob:
It seems to be an issue on Signals side. Even bridges in Matrix Chats fail to upload files like Voicemessages
Attachments send issue has been fixed, but releasing can’t be done because Openrepos is in read-only mode.
Starting new conversations requires lots of enablement work, but it is on the list (and some work has been done towards it).
Syncing chats when linking also requires a lot of (different) enablement work, and it’s also on the list (it would fix other issues too, iiuc).
However, there is the next techical change already coming (because of couse there is!), with a deadline, so we need to do that one first… But there are other smaller fixes coming as well, so stay tuned for those!
Thanks a lot for keeping up the good work.
Thanks for the update, can you please tell us why openRepos in in read-only mode for so long? (I had an issue with s1p and the developer said last month that the issue is fixed but can’t be uploaded to OpenRepos.)
Only the maintainer of OpenRepos would be able to definitively answer that, but from the outside it looks like the site is running some quite old software versions in it’s backend and probably the update to enable it to run safely again takes a bit more effort because of that.
Neebie here. New to everything here. Tried to install from OpenRepos, but my j2026 wont setup the signal client. Any tips?
Hi, welcome to SFOS!
Not sure to understand exactly the issue.
Some questions:
Does WP start?
Do you use it as main or secondary?
Does it display the QRcode?
