I think at installing play store stuff I have overwritten my original saved system.img backup with a corrupt one and now I cannot start aliendalvik engine any more on my Sony Xperia 10 III with latest official update installed.
So I want to extract the file from the fresh downloaded flash image file so I does not must reflash my device.
Where is the system.img stored so I can only install these file by hand? I mounted the sailfish.img001 file from the flash image download but it looks like it is not inside of these file. I wonder me but also reinstall android support does not reinstall the file after moving them to another place.
Nice if someone could give me the steps also to extract them. But to know where it is would be also allready helpfull.
nemo@PGXperiiia10:~ $ rpm -qf /opt/alien/system.img
aliendalvik-system-10.0.0.62.1.4-1.9.1.jolla.aarch64
nemo@PGXperiiia10:~ $ pkcon install --allow-reinstall aliendalvik-system
Resolving
Testing changes
Finished [ ] (0%)
The following packages have to be installed:
aliendalvik-system-10.0.0.62.1.4-1.9.1.jolla.aarch64 Android App Support system image
Proceed with changes? [N/y]
[root@Xperia10III defaultuser]# rm /opt/alien/system.img
rm: remove '/opt/alien/system.img'? y
[root@Xperia10III defaultuser]# pkcon install --allow-reinstall aliendalvik-system
Auflösen [ ] (0%) Paket nicht gefunden: aliendalvik-system
AusfĂĽhrung des Befehls fehlgeschlagen: Dieses Werkzeug konnte keine verfĂĽgbaren Pakete finden: Keine Pakete gefunden
[root@Xperia10III defaultuser]# rpm -qf /opt/alien/system.img
appsupport-system-unprivileged-11.0.0.60.28-1.11.1.jolla.aarch64
[root@Xperia10III defaultuser]# pkcon install --allow-reinstall appsupport-system-unprivileged
Auflösen
Änderungen werden getestet
Fertig
Installieren
Starten
Pakete werden installiert
Fertig
[root@Xperia10III defaultuser]# ls -l /opt/alien/system.img
ls: /opt/alien/system.img: No such file or directory
Any idea? So I though it comes with the flash image.
