When VoLTE is active sending sms not possible - SFOS 4.4.0.72
REPRODUCIBILITY: 0% (not specified)
OSVERSION: 4.4.0.72
HARDWARE: Sony Xperia 10 III - xqbt52 - xqbt52 - 1.0.0.176 - aarch64
UI LANGUAGE: Dansk (user: da_DK, os: da_DK.utf8)
REGRESSION: yes (since: 4.4.0.64 - aarch64)
Not able to send sms after upgrading to SFOS 4.4.0.72 and with 4G Calling activate.
  1. Activate 4G calling
  2. Send sms
  3. Staying in “Sendind” for a long time and may come with an error.
EXPECTED RESULTS:
Sending sms
ACTUAL RESULTS:
Not able to send sms.
  • Patchmanager: no
  • OpenRepos: yes
  • Chum: yes
  • Other: no:
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.8+git1
Please use a title matching the contents of the post.
Yes, problems with 4G Calling.
Can you rename it to “Can’t send sms while volte is active” ?
I took the liberty to rename the subject.
I was wondering about the issue myself.
(10 III, 4.4.0.72, 4G, SMS working but VoLTE not active)
Edit: Vodafone, Germany
Can confirm with a xperia 10 II, SFOS 4.4.0.72, and german telefonica
Can’t confirm with X10III and Elisa/FI; sending and receiving works for me. It may be related to only some operators then…
the servicenumber looks unusual, “+491760000443”,145. When I try to set it to +491760000443, a message appear “Problem with changing the SMS message centre address”
Just a little search on the internet, and the “+491760000443”,145 is not unusual. See this:
" The address_type Parameter"
145 . Meaning: The SMSC address is formatted using the typical ISDN / telephony numbering plan (ITU E.164/E.163) and it is an international number.
SMS works (receiving and sending) as expected on my 10 III (Telekom DE) with active VoLTE.
I too got this error but only after upgrading from 4.4.0.68 to 4.4.0.72. Prior to this I had no issues sending sms while having voLTE enabled. Calling and receiving smses does still work.
I’m also using the same device with Danish language. My provider is HALLO (TDC). What’s your provider @elkiaer ?
Just checked changing language from Danish to English (UK) does not help (which would also be a stange fix).
Its correct that the sms issue occurred after upgrading to 4.4.0.72.
I have Telmore, also using the TDC Net.
Sometimes strange solutions will help, so I also try this :sunglasses:
A friend of mine has CBB (Telmore Denmark). As he has the same model with SFOS I’ll test VoLTE on it this weekend and see whatever it works with his provider.
UPDATE: My friend does not have this issue.
@flypig : can I see a log somewhere why the sending of the SMS goes wrong?
@p1rat: thanks for offering to try. I guess the first step would be to check the log output from the messages app using:
devel-su journalctl --system -f | grep jolla-messages
You could also try collecting the oFono logs.
The usual warning applies: the logs may contain private data, so check them carefully before sharing them with anyone.
Thanks for reporting this @elkiaer, and for all of the subsequent reports and testing. We now have an internal report about this so I’ve tagged it as “tracked”. It would be useful to have feedback about anything unusual appearing in the logs when SMS sending is failing.
Hi flypig, I just couldn’t send an SMS, too.
I tried your command devel-su journalctl --system -f | grep jolla-messages, but there is no output for more than 1 minute. So i cancled it by ‘strg + c’ and got the following.
[defaultuser@Xperia10III ~]$ devel-su journalctl --system -f
Password:
-- Logs begin at Wed 2022-10-19 18:50:09 CEST. --
Okt 19 18:50:43 Xperia10III kernel: [kworke][0xaee190d0a1][18:50:43.920369] wlan: [26982:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
Okt 19 18:50:43 Xperia10III kernel: [soft_i][0xaee190d7e4][18:50:43.920466] wlan: [0:I:HTT] htt_get_first_packet_after_wow_wakeup: First packet after WOW Wakeup rcvd
Okt 19 18:50:43 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
Okt 19 18:50:43 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufs_fixup_device_setup : vid=01ad, model=H9HQ15AECMADAR, spec ver=0210 , fw ver=A902
Okt 19 18:50:43 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
Okt 19 18:50:43 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
Okt 19 18:50:43 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
Okt 19 18:50:43 Xperia10III kernel: OOM killer enabled.
Okt 19 18:50:43 Xperia10III kernel: Restarting tasks ... done.
Okt 19 18:50:43 Xperia10III kernel: PM: suspend exit
Okt 19 18:50:44 Xperia10III kernel: PM: suspend entry (deep)
Okt 19 18:50:44 Xperia10III kernel: PM: Syncing filesystems ...
Okt 19 18:50:44 Xperia10III kernel: sd 0:0:0:0: Power-on or device reset occurred
Okt 19 18:50:44 Xperia10III kernel: done.
Okt 19 18:50:44 Xperia10III kernel: Freezing user space processes ...
Okt 19 18:50:44 Xperia10III kernel: qcom_rpmh DRV:apps_rsc TCS Busy, retrying RPMH message send: addr=0x42e08
Okt 19 18:50:44 Xperia10III kernel: Freezing of tasks aborted after 0.012 seconds
Okt 19 18:50:44 Xperia10III kernel: OOM killer enabled.
Okt 19 18:50:44 Xperia10III kernel: Restarting tasks ... done.
Okt 19 18:50:44 Xperia10III kernel: PM: suspend exit
Okt 19 18:50:44 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
Okt 19 18:50:44 Xperia10III kernel: PM: Syncing filesystems ... done.
Okt 19 18:50:44 Xperia10III kernel: Freezing user space processes ... (elapsed 0.013 seconds) done.
Okt 19 18:50:44 Xperia10III kernel: OOM killer disabled.
Okt 19 18:50:44 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
Okt 19 18:50:44 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
Okt 19 18:50:44 Xperia10III kernel: [kworke][0xaee1d5abca][18:50:44.155398] wlan: [26963:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
Okt 19 18:50:44 Xperia10III kernel: [kworke][0xaee1d5c993][18:50:44.155796] wlan: [26963:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
Okt 19 18:50:44 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
Okt 19 18:50:44 Xperia10III kernel: sd 0:0:0:2: Power-on or device reset occurred
Okt 19 18:50:44 Xperia10III kernel: sd 0:0:0:1: Power-on or device reset occurred
Okt 19 18:50:44 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
Okt 19 18:50:44 Xperia10III kernel: [kworke][0xaee1da280d][18:50:44.170709] wlan: [17993:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
Okt 19 18:50:44 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
Okt 19 18:50:44 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
Okt 19 18:50:44 Xperia10III kernel: Freezing of tasks aborted after 0.013 seconds
Okt 19 18:50:54 Xperia10III kernel: Freezing user space processes ... (elapsed 0.012 seconds) done.
Okt 19 18:50:54 Xperia10III kernel: OOM killer disabled.
Okt 19 18:50:54 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
Okt 19 18:50:54 Xperia10III kernel: Suspending console(s) (use no_console_suspend to debug)
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee207ff90][18:50:44.327183] wlan: [17993:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee2081bea][18:50:44.327561] wlan: [17993:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
Okt 19 18:50:54 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_suspend:enter
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee20d6d38][18:50:44.345711] wlan: [1773:I:HDD] __wlan_hdd_bus_suspend: 1066: starting bus suspend
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee20d7256][18:50:44.345780] wlan: [1773:I:PMO] pmo_core_enable_wow_in_fw: 813: Prevent link down, non-drv wow is enabled
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee20d72d1][18:50:44.345786] wlan: [1773:I:PMO] pmo_core_enable_wow_in_fw: 817: system suspend wow
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee20d73f4][18:50:44.345801] wlan: [1773:I:WMI] send_wow_enable_cmd_tlv: 1831: suspend type: WOW_IFACE_PAUSE_DISABLED flag is 0x20
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaee20f865f][18:50:44.352873] wlan: [1773:I:HDD] __wlan_hdd_bus_suspend: 1142: bus suspend succeeded
Okt 19 18:50:54 Xperia10III kernel: Disabling non-boot CPUs ...
Okt 19 18:50:54 Xperia10III kernel: CPU1: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU1 killed (polled 0 ms)
Okt 19 18:50:54 Xperia10III kernel: CPU2: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU2 killed (polled 0 ms)
Okt 19 18:50:54 Xperia10III kernel: CPU3: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU3 killed (polled 0 ms)
Okt 19 18:50:54 Xperia10III kernel: IRQ 5: no longer affine to CPU4
Okt 19 18:50:54 Xperia10III kernel: CPU4: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU4 killed (polled 1 ms)
Okt 19 18:50:54 Xperia10III kernel: CPU5: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU5 killed (polled 1 ms)
Okt 19 18:50:54 Xperia10III kernel: CPU6: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU6 killed (polled 1 ms)
Okt 19 18:50:54 Xperia10III kernel: CPU7: shutdown
Okt 19 18:50:54 Xperia10III kernel: psci: CPU7 killed (polled 0 ms)
Okt 19 18:50:54 Xperia10III kernel: suspend ns:   11468216509850        suspend cycles:     751117778335
Okt 19 18:50:54 Xperia10III kernel: resume cycles:     751316786363
Okt 19 18:50:54 Xperia10III kernel: Enabling non-boot CPUs ...
Okt 19 18:50:54 Xperia10III kernel: Detected VIPT I-cache on CPU1
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU1: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU1: Booted secondary processor 0x0000000100 [0x51df805e]
Okt 19 18:50:54 Xperia10III kernel: CPU1 is up
Okt 19 18:50:54 Xperia10III kernel: Detected VIPT I-cache on CPU2
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU2: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU2: Booted secondary processor 0x0000000200 [0x51df805e]
Okt 19 18:50:54 Xperia10III kernel: CPU2 is up
Okt 19 18:50:54 Xperia10III kernel: Detected VIPT I-cache on CPU3
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU3: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU3: Booted secondary processor 0x0000000300 [0x51df805e]
Okt 19 18:50:54 Xperia10III kernel: CPU3 is up
Okt 19 18:50:54 Xperia10III kernel: Detected VIPT I-cache on CPU4
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU4: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU4: Booted secondary processor 0x0000000400 [0x51df805e]
Okt 19 18:50:54 Xperia10III kernel: CPU4 is up
Okt 19 18:50:54 Xperia10III kernel: Detected VIPT I-cache on CPU5
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU5: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU5: Booted secondary processor 0x0000000500 [0x51df805e]
Okt 19 18:50:54 Xperia10III kernel: CPU5 is up
Okt 19 18:50:54 Xperia10III kernel: Detected PIPT I-cache on CPU6
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU6: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU6: Booted secondary processor 0x0000000600 [0x411fd0d0]
Okt 19 18:50:54 Xperia10III kernel: CPU6 is up
Okt 19 18:50:54 Xperia10III kernel: Detected PIPT I-cache on CPU7
Okt 19 18:50:54 Xperia10III kernel: arch_timer: CPU7: Trapping CNTVCT access
Okt 19 18:50:54 Xperia10III kernel: CPU7: Booted secondary processor 0x0000000700 [0x411fd0d0]
Okt 19 18:50:54 Xperia10III kernel: CPU7 is up
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfba6fb][18:50:54.770802] wlan: [0:E:QDF] htc_rx_completion_handler: 442: Received initial wake up
Okt 19 18:50:54 Xperia10III kernel: no screen_state.
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeedfe426c][18:50:54.779701] wlan: [1773:I:HDD] wlan_hdd_bus_resume: 1280: starting bus resume
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeedfe4558][18:50:54.779740] wlan: [1773:I:PMO] pmo_core_psoc_send_host_wakeup_ind_to_fw: 1219: Host wakeup indication sent to fw
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe7bfb][18:50:54.780469] wlan: [0:F:WMA] WLAN triggered wakeup: PATTERN_MATCH_FOUND (9), vdev: 0 (STA)
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe80f6][18:50:54.780535] wlan: [0:F:WMA] WLAN wake reason counters:
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8187][18:50:54.780542] wlan: [0:F:WMA] uc:423 bc:0 v4_mc:29 v6_mc:9 ra:0 ns:0 na:0 icmp:0 icmpv6:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe820c][18:50:54.780549] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8292][18:50:54.780556] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8538][18:50:54.780592] wlan: [0:I:WMA] wma_wow_parse_data_pkt: 2172: Src_mac: 44:4e:6d:b5:81:63, Dst_mac: 3c:01:ef:f7:44:fd
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8663][18:50:54.780607] wlan: [0:I:WMA] WOW Wakeup: IPV4 TCP Packet rcvd
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8779][18:50:54.780622] wlan: [0:I:WMA] Pkt_len: 60, src_port: 42567, dst_port: 80
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8839][18:50:54.780632] wlan: [0:F:WMA] WLAN wake reason counters:
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe88b4][18:50:54.780638] wlan: [0:F:WMA] uc:424 bc:0 v4_mc:29 v6_mc:9 ra:0 ns:0 na:0 icmp:0 icmpv6:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe8930][18:50:54.780644] wlan: [0:F:WMA] assoc:0 disassoc:0 assoc_resp:0 reassoc:0 reassoc_resp:0 auth:0 deauth:0 action:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe89ad][18:50:54.780651] wlan: [0:F:WMA] pno_match:0 pno_complete:0 gscan:0 low_rssi:0 rssi_breach:0 oem:0 scan_11d:0
Okt 19 18:50:54 Xperia10III kernel: [soft_i][0xaeedfe9c43][18:50:54.780899] wlan: [0:I:HTT] htt_get_first_packet_after_wow_wakeup: First packet after WOW Wakeup rcvd
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeedfed70e][18:50:54.781683] wlan: [1773:I:HDD] wlan_hdd_bus_resume: 1345: bus resume succeeded
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeedfee3b1][18:50:54.781851] wlan: [26982:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
Okt 19 18:50:54 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0
Okt 19 18:50:54 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufs_fixup_device_setup : vid=01ad, model=H9HQ15AECMADAR, spec ver=0210 , fw ver=A902
Okt 19 18:50:54 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2
Okt 19 18:50:54 Xperia10III kernel: sec_ts 1-0048: [sec_input] sec_ts_pm_resume:enter
Okt 19 18:50:54 Xperia10III kernel: OOM killer enabled.
Okt 19 18:50:54 Xperia10III kernel: Restarting tasks ...
Okt 19 18:50:54 Xperia10III kernel: i2c_pmic 2-0009: ignoring dependency for device, assuming no driver
Okt 19 18:50:54 Xperia10III kernel: done.
Okt 19 18:50:54 Xperia10III kernel: PM: suspend exit
Okt 19 18:50:54 Xperia10III kernel: PM: suspend entry (deep)
Okt 19 18:50:54 Xperia10III kernel: PM: Syncing filesystems ...
Okt 19 18:50:54 Xperia10III kernel: sd 0:0:0:0: Power-on or device reset occurred
Okt 19 18:50:54 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
Okt 19 18:50:54 Xperia10III kernel: Freezing of tasks aborted after 0.004 seconds
Okt 19 18:50:54 Xperia10III kernel: Restarting tasks ... done.
Okt 19 18:50:54 Xperia10III kernel: PM: Syncing filesystems ... done.
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeee357eaf][18:50:54.968238] wlan: [17993:I:HDD] hdd_suspend_wlan: 1244: WLAN being suspended by OS
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeee359987][18:50:54.968596] wlan: [17993:I:PMO] pmo_core_is_wow_applicable: 319: lpass enabled, enabling wow
Okt 19 18:50:54 Xperia10III kernel: sd 0:0:0:2: Power-on or device reset occurred
Okt 19 18:50:54 Xperia10III kernel: sd 0:0:0:1: Power-on or device reset occurred
Okt 19 18:50:54 Xperia10III kernel: PM: Some devices failed to suspend, or early wake event detected
Okt 19 18:50:54 Xperia10III kernel: [kworke][0xaeee37fdd1][18:50:54.976760] wlan: [288:I:HDD] hdd_resume_wlan: 1302: WLAN being resumed by OS
Okt 19 18:50:55 Xperia10III kernel: PM: Syncing filesystems ... done.
Okt 19 18:50:55 Xperia10III kernel: ufshcd-qcom 1d84000.ufshc: ufshcd_ioctl: User buffer is NULL!
Okt 19 18:50:55 Xperia10III kernel: Freezing user space processes ...
Okt 19 18:50:55 Xperia10III kernel: Freezing of tasks aborted after 0.014 seconds
Okt 19 18:50:55 Xperia10III kernel: OOM killer enabled.
Okt 19 18:50:55 Xperia10III kernel: Restarting tasks ... done.
Okt 19 18:50:55 Xperia10III kernel: PM: suspend exit
Okt 19 18:50:55 Xperia10III kernel: PM: suspend entry (deep)
Okt 19 18:50:55 Xperia10III kernel: binder: 7254 RLIMIT_NICE not set
Okt 19 18:50:55 Xperia10III kernel: Freezing user space processes ... (elapsed 0.011 seconds) done.
Okt 19 18:50:55 Xperia10III kernel: OOM killer disabled.
Okt 19 18:50:55 Xperia10III kernel: Freezing remaining freezable tasks ... (elapsed 0.003 seconds) done.
I have same issue with xperia 10 II - dual sim but only using one sim card. Greentel on Telia network in Denmark.
Ofono.log until it gives up.
2022-10-30 11:58:55.987 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien getVoiceRegistrationStateResponse_1_2 ok
2022-10-30 11:58:55.987 src/alien-radio-service.c: alien_radio_request_data_flush() slot1_alien getVoiceRegistrationState request 0x000011ec done
2022-10-30 11:58:55.987 src/alien-radio-service.c: alien_radio_voice_reg_1_2_respond() slot1_alien [000011ec] 1 14
2022-10-30 11:58:55.987 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioResponse getVoiceRegistrationStateResponse_1_2
2022-10-30 11:58:55.987 src/binder_network.c: binder_network_poll_voice_state_cb() slot1 registered,lte,14,-1,44170262,0
2022-10-30 11:58:56.374 src/sms.c: tx_queue_entry_new() pdu_len: 28, tpdu_len: 27
2022-10-30 11:58:56.476 src/sms.c: tx_next() tx_next: 0x343f90f0
2022-10-30 11:58:56.477 src/binder_sms.c: binder_sms_send() pdu_len: 28, tpdu_len: 27 flags: 0x00
2022-10-30 11:58:56.484 imsradio0 < 43 sendImsSms
2022-10-30 11:58:56.484   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:58:56.485   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:58:56.485   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    2::IImsR adio....
2022-10-30 11:58:56.485   0030: 13 00 00 00 85 2a 74 70  00 00 00 00 90 6c 3e 34    .....*tp .....l>4
2022-10-30 11:58:56.485   0040: 00 00 00 00 40 00 00 00  00 00 00 00 00 00 00 00    ....@... ........
2022-10-30 11:58:56.485   0050: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:58:56.486   0060: 01 00 00 00 d8 b1 55 38  79 00 00 00 06 00 00 00    ......U8 y.......
2022-10-30 11:58:56.486   0070: 00 00 00 00 00 00 00 00  00 00 00 00 08 00 00 00    ........ ........
2022-10-30 11:58:56.487   0080: 00 00 00 00 85 2a 74 70  01 00 00 00 50 b0 55 38    .....*tp ....P.U8
2022-10-30 11:58:56.487   0090: 79 00 00 00 01 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:58:56.487   00A0: 00 00 00 00 18 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:58:56.488   00B0: 01 00 00 00 60 bd 3e 34  00 00 00 00 1b 00 00 00    ....`.>4 ........
2022-10-30 11:58:56.488   00C0: 00 00 00 00 00 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:58:56.489   00D0: 00 00 00 00                                         ....
2022-10-30 11:58:56.533 imsradio0 > 37 sendImsSmsResponse
2022-10-30 11:58:56.534   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:58:56.534   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:58:56.534   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    2::IImsR adioResp
2022-10-30 11:58:56.534   0030: 6f 6e 73 65 00 00 00 00  13 00 00 00 ff ff ff ff    onse.... ........
2022-10-30 11:58:56.534   0040: 03 00 00 00 01 00 00 00                             ........
2022-10-30 11:58:56.535 src/vendor_qti_ims_radio.c: vendor_qti_ims_radio_send_ims_sms_response() [imsradio0] msgref:4294967295 result:3 reason:1
2022-10-30 11:58:56.535 src/sms.c: tx_finished() tx_finished 0x343f90f0
2022-10-30 11:58:56.535 src/sms.c: tx_finished() Sending failed, retry in 5 secs
2022-10-30 11:58:56.809 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:58:56.811   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:58:56.813   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:58:56.814   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:58:56.814   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:58:56.814   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:58:56.814   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:58:56.814 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:58:56.814 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:58:56.814 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -61 dBm (97%)
2022-10-30 11:58:56.814 src/network.c: ofono_netreg_strength_notify() strength 97
2022-10-30 11:58:59.112 mce: Battery level is 80
2022-10-30 11:59:01.903 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:01.905   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:01.905   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:01.905   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:01.905   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:01.906   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:01.906   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:01.906 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:01.906 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:01.907 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -65 dBm (87%)
2022-10-30 11:59:01.907 src/network.c: ofono_netreg_strength_notify() strength 87
2022-10-30 11:59:02.212 src/sms.c: tx_next() tx_next: 0x343f90f0
2022-10-30 11:59:02.215 src/binder_sms.c: binder_sms_send() pdu_len: 28, tpdu_len: 27 flags: 0x00
2022-10-30 11:59:02.219 imsradio0 < 43 sendImsSms
2022-10-30 11:59:02.221   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:02.221   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:02.222   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    2::IImsR adio....
2022-10-30 11:59:02.222   0030: 14 00 00 00 85 2a 74 70  00 00 00 00 60 91 3f 34    .....*tp ....`.?4
2022-10-30 11:59:02.222   0040: 00 00 00 00 40 00 00 00  00 00 00 00 00 00 00 00    ....@... ........
2022-10-30 11:59:02.222   0050: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:02.222   0060: 01 00 00 00 d8 b1 55 38  79 00 00 00 06 00 00 00    ......U8 y.......
2022-10-30 11:59:02.222   0070: 00 00 00 00 00 00 00 00  00 00 00 00 08 00 00 00    ........ ........
2022-10-30 11:59:02.223   0080: 00 00 00 00 85 2a 74 70  01 00 00 00 50 b0 55 38    .....*tp ....P.U8
2022-10-30 11:59:02.223   0090: 79 00 00 00 01 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:02.223   00A0: 00 00 00 00 18 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:02.223   00B0: 01 00 00 00 e0 d1 00 28  79 00 00 00 1b 00 00 00    .......( y.......
2022-10-30 11:59:02.223   00C0: 00 00 00 00 00 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:59:02.224   00D0: 00 00 00 00                                         ....
2022-10-30 11:59:02.236 imsradio0 > 37 sendImsSmsResponse
2022-10-30 11:59:02.236   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:02.236   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:02.236   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    2::IImsR adioResp
2022-10-30 11:59:02.237   0030: 6f 6e 73 65 00 00 00 00  14 00 00 00 ff ff ff ff    onse.... ........
2022-10-30 11:59:02.237   0040: 03 00 00 00 01 00 00 00                             ........
2022-10-30 11:59:02.237 src/vendor_qti_ims_radio.c: vendor_qti_ims_radio_send_ims_sms_response() [imsradio0] msgref:4294967295 result:3 reason:1
2022-10-30 11:59:02.237 src/sms.c: tx_finished() tx_finished 0x343f90f0
2022-10-30 11:59:02.237 src/sms.c: tx_finished() Sending failed, retry in 10 secs
2022-10-30 11:59:04.463 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:04.466   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:04.468   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:04.468   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:04.468   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:04.468   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:04.469   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:04.469 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:04.470 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:04.470 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -71 dBm (72%)
2022-10-30 11:59:04.470 src/network.c: ofono_netreg_strength_notify() strength 72
2022-10-30 11:59:09.582 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:09.587   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:09.588   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:09.588   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:09.589   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:09.589   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:09.589   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:09.590 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:09.590 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:09.591 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -71 dBm (72%)
2022-10-30 11:59:12.141 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:12.145   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:12.147   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:12.147   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:12.147   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:12.147   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:12.148   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:12.148 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:12.148 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:12.149 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -73 dBm (67%)
2022-10-30 11:59:12.149 src/network.c: ofono_netreg_strength_notify() strength 67
2022-10-30 11:59:12.212 src/sms.c: tx_next() tx_next: 0x343f90f0
2022-10-30 11:59:12.212 src/binder_sms.c: binder_sms_send() pdu_len: 28, tpdu_len: 27 flags: 0x00
2022-10-30 11:59:12.212 imsradio0 < 43 sendImsSms
2022-10-30 11:59:12.213   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:12.213   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:12.214   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    2::IImsR adio....
2022-10-30 11:59:12.215   0030: 15 00 00 00 85 2a 74 70  00 00 00 00 a0 9c 3e 34    .....*tp ......>4
2022-10-30 11:59:12.216   0040: 00 00 00 00 40 00 00 00  00 00 00 00 00 00 00 00    ....@... ........
2022-10-30 11:59:12.216   0050: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:12.217   0060: 01 00 00 00 d8 b1 55 38  79 00 00 00 06 00 00 00    ......U8 y.......
2022-10-30 11:59:12.217   0070: 00 00 00 00 00 00 00 00  00 00 00 00 08 00 00 00    ........ ........
2022-10-30 11:59:12.218   0080: 00 00 00 00 85 2a 74 70  01 00 00 00 50 b0 55 38    .....*tp ....P.U8
2022-10-30 11:59:12.218   0090: 79 00 00 00 01 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:12.218   00A0: 00 00 00 00 18 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:12.226   00B0: 01 00 00 00 e0 d1 00 28  79 00 00 00 1b 00 00 00    .......( y.......
2022-10-30 11:59:12.226   00C0: 00 00 00 00 00 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:59:12.226   00D0: 00 00 00 00                                         ....
2022-10-30 11:59:12.236 imsradio0 > 37 sendImsSmsResponse
2022-10-30 11:59:12.236   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:12.236   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:12.236   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    2::IImsR adioResp
2022-10-30 11:59:12.236   0030: 6f 6e 73 65 00 00 00 00  15 00 00 00 ff ff ff ff    onse.... ........
2022-10-30 11:59:12.236   0040: 03 00 00 00 01 00 00 00                             ........
2022-10-30 11:59:12.236 src/vendor_qti_ims_radio.c: vendor_qti_ims_radio_send_ims_sms_response() [imsradio0] msgref:4294967295 result:3 reason:1
2022-10-30 11:59:12.237 src/sms.c: tx_finished() tx_finished 0x343f90f0
2022-10-30 11:59:12.237 src/sms.c: tx_finished() Sending failed, retry in 15 secs
2022-10-30 11:59:17.266 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:17.269   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:17.271   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:17.271   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:17.271   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:17.271   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:17.271   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:17.272 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:17.272 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:17.273 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -69 dBm (77%)
2022-10-30 11:59:17.273 src/network.c: ofono_netreg_strength_notify() strength 77
2022-10-30 11:59:19.823 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:19.824   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:19.824   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:19.824   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:19.825   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:19.825   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:19.825   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:19.825 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:19.826 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:19.826 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -69 dBm (77%)
2022-10-30 11:59:24.311 src/modem.c: get_modem_property() modem 0x343d80e0 property SystemPath
2022-10-30 11:59:24.312 src/modem.c: get_modem_property() modem 0x343ca500 property SystemPath
2022-10-30 11:59:24.320 src/modem.c: get_modem_property() modem 0x343d80e0 property SystemPath
2022-10-30 11:59:24.324 src/modem.c: get_modem_property() modem 0x343ca500 property SystemPath
2022-10-30 11:59:24.335 src/modem.c: get_modem_property() modem 0x343d80e0 property SystemPath
2022-10-30 11:59:24.344 src/modem.c: get_modem_property() modem 0x343ca500 property SystemPath
2022-10-30 11:59:25.689 slot1 > 10 dataCallListChanged
2022-10-30 11:59:25.690   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:25.690   0010: 2e 72 61 64 69 6f 40 31  2e 30 3a 3a 49 52 61 64    .radio@1 .0::IRad
2022-10-30 11:59:25.690   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:25.690   0030: 01 00 00 00 85 2a 74 70  00 00 00 00 b8 71 b7 37    .....*tp .....q.7
2022-10-30 11:59:25.690   0040: 79 00 00 00 10 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:25.690   0050: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:25.690   0060: 01 00 00 00 c8 71 b7 37  79 00 00 00 78 00 00 00    .....q.7 y...x...
2022-10-30 11:59:25.690   0070: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:25.693   0080: 00 00 00 00 85 2a 74 70  01 00 00 00 40 72 b7 37    .....*tp ....@r.7
2022-10-30 11:59:25.693   0090: 79 00 00 00 07 00 00 00  00 00 00 00 01 00 00 00    y....... ........
2022-10-30 11:59:25.693   00A0: 00 00 00 00 10 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:25.693   00B0: 01 00 00 00 48 72 b7 37  79 00 00 00 0c 00 00 00    ....Hr.7 y.......
2022-10-30 11:59:25.693   00C0: 00 00 00 00 01 00 00 00  00 00 00 00 20 00 00 00    ........ .... ...
2022-10-30 11:59:25.693   00D0: 00 00 00 00 85 2a 74 70  01 00 00 00 58 72 b7 37    .....*tp ....Xr.7
2022-10-30 11:59:25.693   00E0: 79 00 00 00 12 00 00 00  00 00 00 00 01 00 00 00    y....... ........
2022-10-30 11:59:25.693   00F0: 00 00 00 00 30 00 00 00  00 00 00 00 85 2a 74 70    ....0... .....*tp
2022-10-30 11:59:25.693   0100: 01 00 00 00 70 72 b7 37  79 00 00 00 1e 00 00 00    ....pr.7 y.......
2022-10-30 11:59:25.693   0110: 00 00 00 00 01 00 00 00  00 00 00 00 40 00 00 00    ........ ....@...
2022-10-30 11:59:25.694   0120: 00 00 00 00 85 2a 74 70  01 00 00 00 90 72 b7 37    .....*tp .....r.7
2022-10-30 11:59:25.694   0130: 79 00 00 00 0f 00 00 00  00 00 00 00 01 00 00 00    y....... ........
2022-10-30 11:59:25.694   0140: 00 00 00 00 50 00 00 00  00 00 00 00 85 2a 74 70    ....P... .....*tp
2022-10-30 11:59:25.694   0150: 01 00 00 00 a0 72 b7 37  79 00 00 00 01 00 00 00    .....r.7 y.......
2022-10-30 11:59:25.694   0160: 00 00 00 00 01 00 00 00  00 00 00 00 60 00 00 00    ........ ....`...
2022-10-30 11:59:25.694   0170: 00 00 00 00                                         ....
2022-10-30 11:59:25.694 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien dataCallListChanged
2022-10-30 11:59:25.694 src/alien-radio-service.c: alien_radio_indication_data_call_list_changed() slot1_alien 1 data call(s)
2022-10-30 11:59:25.694 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.0::IRadioIndication dataCallListChanged
2022-10-30 11:59:25.694 src/binder_data.c: binder_data_call_list_1_0() num=1
2022-10-30 11:59:25.694 src/binder_data.c: binder_data_call_new_1_0() [status=0,retry=-1,cid=0,active=2,type=IPV4V6,ifname=rmnet_data2,mtu=1500,address=100.85.111.235/29,dns=194.19.194.192 194.19.128.132,gateways=100.85.111.236,pcscf=]
2022-10-30 11:59:25.694 src/binder_data.c: binder_data_set_calls() data calls changed
2022-10-30 11:59:25.695 src/binder_gprs_context.c: binder_gprs_context_call_list_changed() slot1 call 0 didn't change
2022-10-30 11:59:25.695 slot1 < 130 responseAcknowledgement
2022-10-30 11:59:26.108 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:26.108   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.108   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:26.109   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:26.109   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:26.109   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:26.109   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
2022-10-30 11:59:26.109 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien currentSignalStrength_1_2
2022-10-30 11:59:26.109 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioIndication currentSignalStrength_1_2
2022-10-30 11:59:26.109 src/binder_netreg.c: binder_netreg_strength_notify() slot1 -69 dBm (77%)
2022-10-30 11:59:26.112 slot1 > 3 networkStateChanged
2022-10-30 11:59:26.112   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.113   0010: 2e 72 61 64 69 6f 40 31  2e 30 3a 3a 49 52 61 64    .radio@1 .0::IRad
2022-10-30 11:59:26.113   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:26.113   0030: 00 00 00 00                                         ....
2022-10-30 11:59:26.113 src/alien-radio-service.c: alien_radio_indication_proc() slot1_alien networkStateChanged
2022-10-30 11:59:26.113 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.0::IRadioIndication networkStateChanged
2022-10-30 11:59:26.114 src/binder_network.c: binder_network_state_changed_cb() slot1
2022-10-30 11:59:26.115 src/binder_network.c: binder_network_poll_state() slot1
2022-10-30 11:59:26.115 slot1 < [00001060] 23 getOperator
2022-10-30 11:59:26.115   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.115   0010: 2e 72 61 64 69 6f 40 31  2e 30 3a 3a 49 52 61 64    .radio@1 .0::IRad
2022-10-30 11:59:26.115   0020: 69 6f 00 00 60 10 00 00                             io..`...
2022-10-30 11:59:26.115 slot1 < [00001061] 21 getVoiceRegistrationState
2022-10-30 11:59:26.115   0020: 69 6f 00 00 61 10 00 00                             io..a...
2022-10-30 11:59:26.116 slot1 < [00001062] 22 getDataRegistrationState
2022-10-30 11:59:26.116   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.116   0010: 2e 72 61 64 69 6f 40 31  2e 30 3a 3a 49 52 61 64    .radio@1 .0::IRad
2022-10-30 11:59:26.116   0020: 69 6f 00 00 62 10 00 00                             io..b...
2022-10-30 11:59:26.131 src/alien-radio-service.c: alien_radio_service_handle_request() slot1_alien [000011ed] getOperator
2022-10-30 11:59:26.131 src/alien-radio-service.c: alien_radio_operator_respond() slot1_alien [000011ed] "Greentel" "Greentel" "23820"
2022-10-30 11:59:26.131 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.0::IRadioResponse getOperatorResponse
2022-10-30 11:59:26.132 slot1 > [00001062] 143 getDataRegistrationStateResponse_1_2
2022-10-30 11:59:26.132   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.132   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:26.132   0020: 69 6f 52 65 73 70 6f 6e  73 65 00 00 85 2a 74 70    ioRespon se...*tp
2022-10-30 11:59:26.132   0030: 00 00 00 00 40 72 b7 37  79 00 00 00 0c 00 00 00    ....@r.7 y.......
2022-10-30 11:59:26.132   0040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.132   0050: 00 00 00 00 85 2a 74 70  00 00 00 00 50 72 b7 37    .....*tp ....Pr.7
2022-10-30 11:59:26.132   0060: 79 00 00 00 68 00 00 00  00 00 00 00 00 00 00 00    y...h... ........
2022-10-30 11:59:26.132   0070: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.132   0080: 01 00 00 00 b8 72 b7 37  79 00 00 00 00 00 00 00    .....r.7 y.......
2022-10-30 11:59:26.132   0090: 00 00 00 00 01 00 00 00  00 00 00 00 18 00 00 00    ........ ........
2022-10-30 11:59:26.132   00A0: 00 00 00 00 85 2a 74 70  01 00 00 00 b8 72 b7 37    .....*tp .....r.7
2022-10-30 11:59:26.132   00B0: 79 00 00 00 00 00 00 00  00 00 00 00 01 00 00 00    y....... ........
2022-10-30 11:59:26.132   00C0: 00 00 00 00 28 00 00 00  00 00 00 00 85 2a 74 70    ....(... .....*tp
2022-10-30 11:59:26.132   00D0: 01 00 00 00 b8 72 b7 37  79 00 00 00 00 00 00 00    .....r.7 y.......
2022-10-30 11:59:26.132   00E0: 00 00 00 00 01 00 00 00  00 00 00 00 38 00 00 00    ........ ....8...
2022-10-30 11:59:26.132   00F0: 00 00 00 00 85 2a 74 70  01 00 00 00 b8 72 b7 37    .....*tp .....r.7
2022-10-30 11:59:26.133   0100: 79 00 00 00 58 00 00 00  00 00 00 00 01 00 00 00    y...X... ........
2022-10-30 11:59:26.133   0110: 00 00 00 00 48 00 00 00  00 00 00 00 85 2a 74 70    ....H... .....*tp
2022-10-30 11:59:26.133   0120: 01 00 00 00 10 73 b7 37  79 00 00 00 04 00 00 00    .....s.7 y.......
2022-10-30 11:59:26.133   0130: 00 00 00 00 05 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.133   0140: 00 00 00 00 85 2a 74 70  01 00 00 00 18 73 b7 37    .....*tp .....s.7
2022-10-30 11:59:26.133   0150: 79 00 00 00 03 00 00 00  00 00 00 00 05 00 00 00    y....... ........
2022-10-30 11:59:26.133   0160: 00 00 00 00 10 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.133   0170: 01 00 00 00 20 73 b7 37  79 00 00 00 09 00 00 00    .... s.7 y.......
2022-10-30 11:59:26.133   0180: 00 00 00 00 05 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:59:26.133   0190: 00 00 00 00 85 2a 74 70  01 00 00 00 30 73 b7 37    .....*tp ....0s.7
2022-10-30 11:59:26.133   01A0: 79 00 00 00 09 00 00 00  00 00 00 00 05 00 00 00    y....... ........
2022-10-30 11:59:26.133   01B0: 00 00 00 00 40 00 00 00  00 00 00 00 85 2a 74 70    ....@... .....*tp
2022-10-30 11:59:26.133   01C0: 01 00 00 00 40 73 b7 37  79 00 00 00 00 00 00 00    ....@s.7 y.......
2022-10-30 11:59:26.133   01D0: 00 00 00 00 01 00 00 00  00 00 00 00 58 00 00 00    ........ ....X...
2022-10-30 11:59:26.133   01E0: 00 00 00 00                                         ....
2022-10-30 11:59:26.133 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien getDataRegistrationStateResponse_1_2 ok
2022-10-30 11:59:26.133 src/binder_network.c: binder_network_poll_data_state_cb() slot1 registered,lte,19,-1,44170262,0,20
2022-10-30 11:59:26.133 src/binder_network.c: binder_network_poll_data_state_cb() slot1 data registration changed
2022-10-30 11:59:26.134 src/alien-radio-service.c: alien_radio_service_handle_request() slot1_alien [000011ee] getNetworkSelectionMode
2022-10-30 11:59:26.134 src/alien-radio-service.c: alien_radio_service_remote_object_tx_done() slot1_alien android.hardware.radio@1.0::IRadioResponse getNetworkSelectionModeResponse
2022-10-30 11:59:26.136 src/alien-radio-service.c: alien_radio_service_handle_request() slot1_alien [000011ef] getDataRegistrationState
2022-10-30 11:59:26.136 src/alien-radio-service.c: alien_radio_data_reg_1_2_respond() slot1_alien [000011ef] 1 19
2022-10-30 11:59:26.138 src/alien-radio-service.c: alien_radio_service_remote_object_tx_done() slot1_alien android.hardware.radio@1.2::IRadioResponse getDataRegistrationStateResponse_1_2
2022-10-30 11:59:26.138 src/alien-radio-service.c: alien_radio_service_handle_request() slot1_alien [000011f0] getVoiceRegistrationState
2022-10-30 11:59:26.138 src/alien-radio-service.c: alien_radio_request_data_handle() slot1_alien getVoiceRegistrationState request 0x000011f0 pending
2022-10-30 11:59:26.139 slot1 > [00001060] 22 getOperatorResponse
2022-10-30 11:59:26.139   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.139   0010: 2e 72 61 64 69 6f 40 31  2e 30 3a 3a 49 52 61 64    .radio@1 .0::IRad
2022-10-30 11:59:26.139   0020: 69 6f 52 65 73 70 6f 6e  73 65 00 00 85 2a 74 70    ioRespon se...*tp
2022-10-30 11:59:26.139   0030: 00 00 00 00 80 71 b7 37  79 00 00 00 0c 00 00 00    .....q.7 y.......
2022-10-30 11:59:26.139   0040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.139   0050: 00 00 00 00 85 2a 74 70  00 00 00 00 90 71 b7 37    .....*tp .....q.7
2022-10-30 11:59:26.139   0060: 79 00 00 00 10 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:26.139   0070: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.139   0080: 01 00 00 00 a0 71 b7 37  79 00 00 00 09 00 00 00    .....q.7 y.......
2022-10-30 11:59:26.139   0090: 00 00 00 00 01 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.139   00A0: 00 00 00 00 85 2a 74 70  00 00 00 00 b0 71 b7 37    .....*tp .....q.7
2022-10-30 11:59:26.139   00B0: 79 00 00 00 10 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:26.139   00C0: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.139   00D0: 01 00 00 00 c0 71 b7 37  79 00 00 00 09 00 00 00    .....q.7 y.......
2022-10-30 11:59:26.139   00E0: 00 00 00 00 03 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.139   00F0: 00 00 00 00 85 2a 74 70  00 00 00 00 d0 71 b7 37    .....*tp .....q.7
2022-10-30 11:59:26.140   0100: 79 00 00 00 10 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:26.140   0110: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.140   0120: 01 00 00 00 e0 71 b7 37  79 00 00 00 06 00 00 00    .....q.7 y.......
2022-10-30 11:59:26.140   0130: 00 00 00 00 05 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.140   0140: 00 00 00 00                                         ....
2022-10-30 11:59:26.140 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien getOperatorResponse ok
2022-10-30 11:59:26.140 src/alien-radio-service.c: alien_radio_response_handle_get_operator() slot1_alien "Greentel" "Greentel" "23820"
2022-10-30 11:59:26.143 slot1 > [00001061] 142 getVoiceRegistrationStateResponse_1_2
2022-10-30 11:59:26.144   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:26.144   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:26.144   0020: 69 6f 52 65 73 70 6f 6e  73 65 00 00 85 2a 74 70    ioRespon se...*tp
2022-10-30 11:59:26.144   0030: 00 00 00 00 40 72 b7 37  79 00 00 00 0c 00 00 00    ....@r.7 y.......
2022-10-30 11:59:26.144   0040: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.144   0050: 00 00 00 00 85 2a 74 70  00 00 00 00 50 72 b7 37    .....*tp ....Pr.7
2022-10-30 11:59:26.144   0060: 79 00 00 00 78 00 00 00  00 00 00 00 00 00 00 00    y...x... ........
2022-10-30 11:59:26.144   0070: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.144   0080: 01 00 00 00 c8 72 b7 37  79 00 00 00 00 00 00 00    .....r.7 y.......
2022-10-30 11:59:26.144   0090: 00 00 00 00 01 00 00 00  00 00 00 00 28 00 00 00    ........ ....(...
2022-10-30 11:59:26.144   00A0: 00 00 00 00 85 2a 74 70  01 00 00 00 c8 72 b7 37    .....*tp .....r.7
2022-10-30 11:59:26.144   00B0: 79 00 00 00 00 00 00 00  00 00 00 00 01 00 00 00    y....... ........
2022-10-30 11:59:26.144   00C0: 00 00 00 00 38 00 00 00  00 00 00 00 85 2a 74 70    ....8... .....*tp
2022-10-30 11:59:26.144   00D0: 01 00 00 00 c8 72 b7 37  79 00 00 00 00 00 00 00    .....r.7 y.......
2022-10-30 11:59:26.144   00E0: 00 00 00 00 01 00 00 00  00 00 00 00 48 00 00 00    ........ ....H...
2022-10-30 11:59:26.144   00F0: 00 00 00 00 85 2a 74 70  01 00 00 00 c8 72 b7 37    .....*tp .....r.7
2022-10-30 11:59:26.144   0100: 79 00 00 00 58 00 00 00  00 00 00 00 01 00 00 00    y...X... ........
2022-10-30 11:59:26.144   0110: 00 00 00 00 58 00 00 00  00 00 00 00 85 2a 74 70    ....X... .....*tp
2022-10-30 11:59:26.144   0120: 01 00 00 00 20 73 b7 37  79 00 00 00 04 00 00 00    .... s.7 y.......
2022-10-30 11:59:26.144   0130: 00 00 00 00 05 00 00 00  00 00 00 00 00 00 00 00    ........ ........
2022-10-30 11:59:26.144   0140: 00 00 00 00 85 2a 74 70  01 00 00 00 28 73 b7 37    .....*tp ....(s.7
2022-10-30 11:59:26.144   0150: 79 00 00 00 03 00 00 00  00 00 00 00 05 00 00 00    y....... ........
2022-10-30 11:59:26.144   0160: 00 00 00 00 10 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:26.144   0170: 01 00 00 00 30 73 b7 37  79 00 00 00 09 00 00 00    ....0s.7 y.......
2022-10-30 11:59:26.144   0180: 00 00 00 00 05 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:59:26.144   0190: 00 00 00 00 85 2a 74 70  01 00 00 00 40 73 b7 37    .....*tp ....@s.7
2022-10-30 11:59:26.144   01A0: 79 00 00 00 09 00 00 00  00 00 00 00 05 00 00 00    y....... ........
2022-10-30 11:59:26.144   01B0: 00 00 00 00 40 00 00 00  00 00 00 00 85 2a 74 70    ....@... .....*tp
2022-10-30 11:59:26.144   01C0: 01 00 00 00 50 73 b7 37  79 00 00 00 00 00 00 00    ....Ps.7 y.......
2022-10-30 11:59:26.144   01D0: 00 00 00 00 01 00 00 00  00 00 00 00 68 00 00 00    ........ ....h...
2022-10-30 11:59:26.145   01E0: 00 00 00 00                                         ....
2022-10-30 11:59:26.145 src/alien-radio-service.c: alien_radio_response_proc() slot1_alien getVoiceRegistrationStateResponse_1_2 ok
2022-10-30 11:59:26.145 src/alien-radio-service.c: alien_radio_request_data_flush() slot1_alien getVoiceRegistrationState request 0x000011f0 done
2022-10-30 11:59:26.145 src/alien-radio-service.c: alien_radio_voice_reg_1_2_respond() slot1_alien [000011f0] 1 14
2022-10-30 11:59:26.145 src/alien-radio-service.c: alien_radio_service_remote_object_submit_tx() slot1_alien android.hardware.radio@1.2::IRadioResponse getVoiceRegistrationStateResponse_1_2
2022-10-30 11:59:26.145 src/binder_network.c: binder_network_poll_voice_state_cb() slot1 registered,lte,14,-1,44170262,0
2022-10-30 11:59:27.212 src/sms.c: tx_next() tx_next: 0x343f90f0
2022-10-30 11:59:27.212 src/binder_sms.c: binder_sms_send() pdu_len: 28, tpdu_len: 27 flags: 0x00
2022-10-30 11:59:27.212 imsradio0 < 43 sendImsSms
2022-10-30 11:59:27.212   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:27.212   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:27.212   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 00 00 00 00    2::IImsR adio....
2022-10-30 11:59:27.212   0030: 16 00 00 00 85 2a 74 70  00 00 00 00 e0 c7 3b 34    .....*tp ......;4
2022-10-30 11:59:27.212   0040: 00 00 00 00 40 00 00 00  00 00 00 00 00 00 00 00    ....@... ........
2022-10-30 11:59:27.212   0050: 00 00 00 00 00 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:27.212   0060: 01 00 00 00 d8 b1 55 38  79 00 00 00 06 00 00 00    ......U8 y.......
2022-10-30 11:59:27.212   0070: 00 00 00 00 00 00 00 00  00 00 00 00 08 00 00 00    ........ ........
2022-10-30 11:59:27.212   0080: 00 00 00 00 85 2a 74 70  01 00 00 00 50 b0 55 38    .....*tp ....P.U8
2022-10-30 11:59:27.212   0090: 79 00 00 00 01 00 00 00  00 00 00 00 00 00 00 00    y....... ........
2022-10-30 11:59:27.212   00A0: 00 00 00 00 18 00 00 00  00 00 00 00 85 2a 74 70    ........ .....*tp
2022-10-30 11:59:27.212   00B0: 01 00 00 00 20 52 3e 34  00 00 00 00 1b 00 00 00    .... R>4 ........
2022-10-30 11:59:27.212   00C0: 00 00 00 00 00 00 00 00  00 00 00 00 30 00 00 00    ........ ....0...
2022-10-30 11:59:27.212   00D0: 00 00 00 00                                         ....
2022-10-30 11:59:27.221 imsradio0 > 37 sendImsSmsResponse
2022-10-30 11:59:27.221   0000: 76 65 6e 64 6f 72 2e 71  74 69 2e 68 61 72 64 77    vendor.q ti.hardw
2022-10-30 11:59:27.221   0010: 61 72 65 2e 72 61 64 69  6f 2e 69 6d 73 40 31 2e    are.radi o.ims@1.
2022-10-30 11:59:27.221   0020: 32 3a 3a 49 49 6d 73 52  61 64 69 6f 52 65 73 70    2::IImsR adioResp
2022-10-30 11:59:27.221   0030: 6f 6e 73 65 00 00 00 00  16 00 00 00 ff ff ff ff    onse.... ........
2022-10-30 11:59:27.221   0040: 03 00 00 00 01 00 00 00                             ........
2022-10-30 11:59:27.221 src/vendor_qti_ims_radio.c: vendor_qti_ims_radio_send_ims_sms_response() [imsradio0] msgref:4294967295 result:3 reason:1
2022-10-30 11:59:27.221 src/sms.c: tx_finished() tx_finished 0x343f90f0
2022-10-30 11:59:27.221 src/sms.c: tx_finished() Max retries reached, giving up
2022-10-30 11:59:27.221 src/sms.c: sms_tx_queue_remove_entry() 0x343f90f0
2022-10-30 11:59:27.221 plugins/smshistory.c: sms_history_sms_send_status()
2022-10-30 11:59:29.615 slot1 > 53 currentSignalStrength_1_2
2022-10-30 11:59:29.615   0000: 61 6e 64 72 6f 69 64 2e  68 61 72 64 77 61 72 65    android. hardware
2022-10-30 11:59:29.615   0010: 2e 72 61 64 69 6f 40 31  2e 32 3a 3a 49 52 61 64    .radio@1 .2::IRad
2022-10-30 11:59:29.615   0020: 69 6f 49 6e 64 69 63 61  74 69 6f 6e 00 00 00 00    ioIndica tion....
2022-10-30 11:59:29.615   0030: 00 00 00 00 85 2a 74 70  00 00 00 00 68 70 b7 37    .....*tp ....hp.7
2022-10-30 11:59:29.615   0040: 79 00 00 00 4c 00 00 00  00 00 00 00 00 00 00 00    y...L... ........
2022-10-30 11:59:29.615   0050: 00 00 00 00 00 00 00 00  00 00 00 00                ........ ....
Are there any news? Every time I send a SMS, I had to deactivate in settings > 4G calling(beta) and after that enable it again-not to miss an incoming call.
This is crazy. Any hints from jolla? Hot fix? Came across the same issue and seems like it has 100% repro for some providers.
My is Orange Poland with just one sim Xperia 10m3
I’m hoping for the next update …SMS is a really basic functionality for a phone.
