what is sailjail,
what is it supposed to do?
how to deactivate it altogether?
for example the browser cannot access any internet site while launched from the desktop icon
(this from the last version 4.5.0.19)
if i launch it from the terminal it works as it should
Sailjail is the sandboxing solution used in SFOS. It is supposed to grant each app the configured access rights. The browser should have internet access, there must be a wrong configuration in place. When started from CLI sandboxing is not active.
Could also be due to waydroid/dnsmasq? Is dnsmasq installed, is it disabled? (it should be) There was also a connman issue related to resolv.conf and sailjail that might be related.
@nephros
pkcon refresh; pkcon update
end up with no warning at all
@piggz
no waydroid installed
how do i check for dnsmasq if installed or disabled
what means this sentence
“There was also a connman issue related to resolv.conf and sailjail that might be related.”
i am simple user!!
and how to check that
