What about lspci and lsusb missing in SFOS?
pkcon search lspci
nor
pkcon search lsusb
Can you give me some information.
UPDATE
I used the lspci for debian arm64 with its libpci.so.3 but it is uselss because /proc/bus/pci is missing
pkcon search lspci
nor
pkcon search lsusb
UPDATE
pkcon search usbutils
Thanks but useless, it does not show up no any information.
Works fine for me.
Which device and SFOS version? Mine X10II with 4.5.0.19.
/sys/bus/usb/devices/ is empty on my XA2 and X (wo reboot)…
EDIT: reboot alone doesn’t change anything…
This has always been working when i have tried it over the years. Xperia 10 III at 4.5.0.19 this time, but not very relevant.
Mind that lsusb will (correctly) show no devices until any are plugged in.
Why do I see my XA2 on the PC and on the XA2 I don’t even see a root hub? What is missing?
Presumably lsusb applies only to host mode.
I am surprised that the smartphone itself has nothing connected to USB but under certain PoV, it makes sense: everything is on the SoC and there is no reason to use USB like in the laptop for which every manufacter wish to attach their own periferals (e.g. webcam).
