Yes, because I hadn’t upload the other screenshot. Temperature are strange as it’s showing -3 and the curve starts from -3, but I think the issue comes from foreca.
The main issue, as I try to describe is that foreca use a icon with snow and rain, but Sailfish OS displays only an icon with rain.
How do you know the app should be showing “partly cloudy with wet snow”?
And what do you want to say with showing the broken website?
I think it would be helpful if you were more complete in describing your reasoning.
Doesn’t @pherjung mean that the SF app and Foreca website should show the same icons for the same location at the same time.
And it seems not to be the case.
Is that it?
Ok, now I understand.
Please note that the website and the SFOS screen do not always match (or better, they usually do not match). Maybe that the SFOS Foreca screen just did not want to show snow. Is this repeatable? (I can’t check this myself since I live in Rome where it snows once every 3-4 years.)
