Have the same problem.
The settings show up, but the option don’t get recognized by the volume control. Its still the stock behaviour.
Logfiles can only be accessed if you enable the dev mode in patchmanager.
It tells me that there are no logs. I restarted patchmanager and settings a few times with no change.
@Ada ah very good idea, if you Could implementiert the Fine granular steps as well would be nice
Mhm strange
20chars
A device restart seems to fix this! Thanks for the patch!
sadly this is currently not supported and not on the roadmap since it would be quite the big patch. maybe later but not anytime soon.
@kan_ibal @doctorflynt thanks for reporting, and sorry for the trouble! I found the cause: in the Patchmanager web catalog I had put the patch in the category “Settings”. So Restart preloaded services only restarted the Settings app, not the homescreen, which is where the volume keys are handled.
I’ve changed the category to “Homescreen”, so new installs from the web catalog should restart the right thing.
If you already installed it: reboot once (thanks @doctorflynt for finding that!). After that the options are in Settings → Sounds and feedback, and the keys should follow them. I also added the reboot hint to the original post.
Thx for replying, so maybe in future.
