zypper ref
zypper up (installs updated config with waydroid gbinder config)
zypper in waydroid-runner
waydroid init (or waydroid init -s GAPPS etc)
Open from launcher
zypper ref
Open from launcher
Is the pen working within Waydroid? If yes, how is the experience?
I flashed my tablet without the script manually. i cant reformat the user data :
Fastboot error
./fastboot format:ext4 userdata
< waiting for any device >
Warning: userdata type is f2fs, but ext4 was requested for formatting.
the tablet was with ubuntu touch before.
SailfishOS is working but my Data Partition is only 3,6 GB
How can i format the data partition ?
Unfortunately, I donāt know. My tablet ran VollaOS and I used a script, and my data partition is about 6.8 GB. Perhaps @piggz can help you.
The looks like userdata was formatted ok ⦠did you say Y to encrypting home durint setup? you -need- to say yes to that or home exists on the root partition, and doesnt get another device.
Ah okay i said no, because i want no or i dont need lockcode.
I will test today again.
Not sure about that - no further preparations like fomatting he device? You can directly flash it from the tablet without a desktop computer? Iām a litlle bit confused now.
Obviously you run that from a computer with the tablet connected in fastboot mode (as it says) and not the tablet itself.
So the same way as with the Xperias⦠Itās been more then four years that I last did thisā¦
Maybe you can found some additional information on the Volla website Ubuntu Touch Dualboot configuration.
The download contains a script flash.sh
Put tablet into fatsboot mode, connected to a linux computer over USB
Run the script, probably as root
sudo sh flash.sh
And that -should- do everything
I switches from Ubuntu Touch to Jolla-5.2.0.22-halium-mimir-testing.
Sailfish runs so smooth on the Volla tablet. Iām really impressed! Even the Volla keyboard witch touchpad works and it gets even better an USB mouse is in landscape orientation usable. That didnāt work on the xperia phones but here on the tablet it works
@piggz Thanks a lot for the port!
Two question left:
In the system setting there is as Build 5.0.0.77 (Tampella) written and a website that gives the webbrowser version reports āFirefox 91.0ā. Did I missed some update instructions or is it only cosmetic one the testing release?
After wake-up not every time is the Volla keyboard an mouse recognised. I had the same behaviour on ubuntu touch. Due to that i guess this is an hardware issue. Has someone the same issue?
Im fairly sure the version should be 5.2.0.22. I checked the CI build log, and it certainly used the 5.2.0.22 repos.
Can you check with the āssu reā command ?
On the keyboard, yeah, sometimes i have to re-dock it also.
ssu re reports:
WARNING: ssu.ini does not seem to be writable. Setting values might not work.
āDevice release is currently: 5.0.0.77ā
hmm, you installed Release release-testing-5.2.0.22-user1 Ā· HelloVolla/sailfish-release-halium-mimir Ā· GitHub ??
I checked the data on the OS that I used for flashing. Iām really sorry, I flashed the 5.0.0.77. So I installed the old version. I had some issues with flashing and it seems my lasted try was to use the released version and not the latest testing version. Is there an update possibility or is with every version the flashing procedure needed?
OTA updates are absolutely fine, just not with the normal sailfish GUI used on official devices:
devel-su
ssu re
ssu ur
zypper ref
zypper dup
You must make sure there is an x.y major version in the OBS repo, at nemo:hw:testing:volla:halium-mimir:x.y
Oh, and for clarity, the images on the CI are named:
Update was successful with following commands:
devel-su
ssu re 5.2.0.22
ssu ur
zypper ref
zypper dup
Thanks!
