[VNC] using phone from desktop?
I would like to use my phone from my desktop computer via VNC, especially for writing stuff. I know there have been a few posts in TJC about VNC but I can’t seem to find them again.
There’s this project, which I installed once IIRC but it was not possible to use the desktop keyboard (to send keyboard events):
Did anyone manage to use the keyboard through VNC? Do you know any alternatives to lipstick2vnc?
I know there are a few projects for getting remote desktop access from the phone (but that’s not what I need):
You only need to compile and install libvncserver and lipstick2vnc - they worked well at least since SailfishOS 2.0.
Pre-compiled packages here.
Thank you! Did I read well, that this only works through bluetooth and not via wifi? Is this a big deal to get wifi working? I am just a user, no programmer, so I would not know how to do that…
I didn’t find the time to try your packages yet. Did you include uinput keyboard handler by teleshoes · Pull Request #10 · mer-qa/lipstick2vnc · GitHub? This merge request seems to implement exactly what I was missing but I didn’t test it either.
It should only work over USB, not Bluetooth nor Wifi. Enabling wireless support is not something you’d generally want because its too insecure.
By default those two packages only work via USB networking; they can work via wifi, provided you configure/patch them, but I wouldn’t recommend allowing any device on the local network to snoop around your phone desktop.
No, it won’t work via bluetooth because it needs a network interface.
Hey,
shouldn’t Sailfish Connect offer the desired function?
https://openrepos.net/content/r1tschy/sailfish-connect
Will be easily usable with a linux pc. There was also another client ages ago, Jolla communicator, but the functionality is not that big:
Messaggiero Post :slight_smile:
I expected that it would let you use your pc keyboard, but strangely it does the opposite:
  • Touchpad - Create mouse input from your phone.
  • Keyboard - Create keyboard input from your phone.
