Has been using the vnc server successfully since the last update os
Since April os update. Cannot connect to the vnc server on phone.
Anyone has know is there a configuration problem or other way to make the vnc server work again?
I wanted to connect to my phone today, too, and it didn’t work. Stumbled upon your post. I don’t know if it ever worked.
BTW: I’m running windows. I can start the server, SSH into the device for tunneling and when I try to connect via RealVNC Viewer it says “connecting” forever. When I close ssh RealVNC Viewer gives an error message immediately so at least I know that the port was open.
Any ideas?
Hey all,
Can’t connect from phone to a server, either. When starting the app from command line, I get a lot of error messages concerning missing libs. Nevertheless the connection seems to be established, but I can see only a black rectangle…
Just a follow-up here: I “solved” it by using kamkast from OpenRepos. It’s controllable via command line and offers to cast the screen contents. I have a delay of ~1.3 seconds though.
also met:channel 3: open failed: connect failed: Connection refused
