Hi I want to run virtual android machine on my phone sony xperia 10 ii phone witch is with last update sailfishos ?
Do you know some app or anything else to do it but i want to be a fast and lite ?
Thanks
Thanks
What do you want to do with the virtual android? As the xperia10II is a supported device, you can just use the android support from the jolla store to run android apps (you need a bought sailfishOS for that).
Great but know itâs want to be a power user i use the command âsuâ but i donât know witch password of the device pin code or of the jolla account ?
The main goal is to lie the system and to have normal Viber and WhatsApp because the sailfish os doesnât support the google service i cant import chat backup from my old device but to be a simple back up not to do some program things witch i donât understand
And if i create virtual machine and then login with my account and then i will have back up from google services.
Thatâs it
A generic virtual machine will not help you with that, nor will WayDroid.
You would have to install google services in waydroid as well. There is as far as i know no simple solution with google services preinstalled.
However, you can install microG. This enables google services in sailfishOS.
For a tutorial look here: https://forum.sailfishos.org/t/microg-on-sfos-4
There is even a video.
For the su (or devel-su) command you need to enable developer mode in the settings and use the password from there. The su commands are for Switch User and switches to the root user. This user has permissions to do everything and can destroy things (and repair them). Feel free to ask questions here. Weâre happy to help
Thanks for information but I try with command su the ask me for password I know the password but when i start to write no show ****** or even real signs then when I press the enter goes to the bottom row i start to write again but go one more row and then say me fail⌠where Iâm wrong ? Iâm doing that from terminal right ?
It is normal linux behavior to be completly silent in a password prompt. Thus so far everything is fine. To become root user on a sfos device, you need to use devel-su instead of su. Does that work for you?
While I am happy to encurage you to modify your system and learn to do that, it might be more efficient to backup whatsapp from an android device into a file and restore that on sfos.
I realized how it works you have to wait a bit before say is it accept or not but know have to remember what is my password because you say the password is that you login in developer mode i try with this password but say me me âauthentication failureâ⌠is it possible to be different password from my developer menu ?
Thanks now I learn something new but for step 4 Iâm not sure is it work because i try with only âsuâ but again not accept my password only in âdevel-suâ but i know in instruction says
- You will be asked to enter new password for root user two times (it has nothing to do with the password that you have set up in step 2 - choose whatever you like, but choose a really strong one!).
- The password for root is now set - donât forget it! You can now use
suinstead ofdevel-suto become root user.
Thanks for useful information i learn something new !
Hey man,
Is it possible to give me some step by step solution how to install because i open the site I read the readme file but i donât understand how i mean is it have first to download all the files and then via usb to upload to phone or is possible to download by terminal with command ? I thin from terminal and some command it wit be more easy for me.
Thanks.
Iâm not on SF at the moment, so if you have updated to 4.4, I canât help you with any issues. If youâre on 4.3 or less, just install Chum repo, https://chumrpm.netlify.app/, and then pkcon install Waydroid. Then you have the option of using Waydroid Settings or Waydroid Runner, so pkcon install that. Then run waydroid init on your phone.
Hm I donât understand anything
May I join this discussion here? I have also a similar problem, would like to install Waydroid on a Volla phone and do not know how to do this in a proper way.
I found Waydroid and Waydroid Runner in Chum, but donât know how to install it correctly and failed once in earlier time.
Can you please help me to do everything in the right order and fotget nothing?
The Volla phone is on SFOS 4.4.0.64
Thanks in advance!
