Video calls in Threema need bug fix
Could see and hear my grandchildren singing at my birthday with Threema video calling.I can see them,but they don’t see me because my Sailfish phone makes no connection to camera. The little camera icon in the right corner above is cut through and does not change during the session.No problems with voice.Device: Xperia 10 III with Sailfish 5.0.0.68.I gave all permissions needed and searched this forum for Threema problems too.Can this bug be fixed?
!-- Please don’t delete this template as it will be used in automated processes.
Review the guidelines and follow the template when creating a bug report.
Guidelines: About the Bug Reports category
If you are uncertain about how to fill out the template, we recommend asking about your issue in the General category first.
Try to provide all the basic information in the top section:
How reliably can one cause it to happen in % or how often
The OS VERSION from Settings in About product.
Which hardware you are using. E.g. XA2, X10, X10 II, …
What language your phone is using
Is this a regression compared to previous public release or is it new?
OS / software versions: Please indicate version number instead of current/latest, as every version has been current or latest!
REPRODUCIBILITY:
OS VERSION:
HARDWARE:
UI LANGUAGE:
REGRESSION:
