How can I install telnet to work in terminal? there is an app inettools on openrepos but not for 64bit. Any way to use the command?
I hope you are trying this just for testing/network debugging purposes: telnet’s security track record is a disaster.
Anyway, if you absolutely must: both ‘curl’ and ‘screen’ can be used for telnet connections, both of which you can install from the command line via pkcon.
thx a lot. I know bout security, just playing around with an own bbs server
