Use BeaconDB as online positioning service
Anyone is using any of the BeacomDB compatible APPs (all Android based) from their SFOS to scan and add data to the database?
I tried but don’t really know how it works, it connected to gps but in 20 minutes it did create nothing at all
Some suggestions to make it work?
Installed, tried to dend something, failed
So, i installed an app called tower collector from f-droid and it worked, all of a sudden, at the same time also neostumbler started working
I decided to stay with neostumbler (which is now working) cause i liked the interface more
Yesterday I tried both, Tower and NeoStumbler and, aparently, no one collect any data. I’ll give another chance to both apps.
It’s necesary any special configuration in microG?
I don’t have the slightest idea, surely you have to enable position in microg i suppose
Why would microg even come into play? Do those apps need google services??
had a try right now, the position is working even with microg disabled so i would say no
i do have another app which surprisingly requires microg for position, so probably i have missmatched it for that
so, i finally understood how neostumbler works, it needs to have access to position for the gps and to calls for retrieving cell data
i tried disabling access to calls but then the app just does nothing, if access to calls is given back, it almost immediately starts to collecting beacons
i have only tried with cellular data by the way and not with wifi
retried today, did enable calls but still nothing recorded.
did find the fix button in settings, added rights to detect nearby … but nothing yet
Well, i’ve taked the app from f-droid, try using that
It misses some options (like the ā€œstart collecting when movingā€ which is tied to gplay it seems but it works, i just have to manually start the app collecting…
I did start collect manually even when not moving …
In the sense that you were able to make it work?if so, very nice
I don’t get anyway, why the app is collecting beacons even when a beacon in the same position was already collected but i guess it’s fine…
On a side note
I’m not 100% sure, but i have the feeling that beacondb is really helping my xa2 to connect to the gps
It’s still slow, but i’m seeing an higher succes rate in connecting from when i installed it, and seems to connect to more satellites
But i need some other user to confirm my theory as maybe it’s just a feeling (like the one when you update and everything is smoother, then after two days everything is back to normal :stuck_out_tongue: )
No it did nog work, today neither
It did work. You need only two things. Live mobile network for cell number and GPS with fix for location. Tower app is more reliable.
i observed that tower app catches so called ā€œlow accuracyā€ measurements, and ā€œhigh accuracyā€ ones
i thought maybe neostumbler only catches high accuracy ones
still it’s working for me, with the correct permissions (calls above all)
no chance tried today again both apps on c2
puremaps did navigation, neostumber nor tower collector did collect anything
Did you give you the correct permissions to the app?it’s definitely working here…
Like what? Both show that they have gps location, 10-15 m accuracy, but nothing to send
