Having issues with usb-otg on Xperia X. Here’s the gist:
Using SanDisk Extreme SSD. Originally got no response whatsoever when connecting to phone. Booted to Android recovery, (TWRP), and usb-otg mounted easily, and disk files accessible. After rebooting, disk showed up in Settings “Storage” section as unsupported, and only option was format. I installed usbstick utils and exfat-utils from Openrepos, and then the files showed up, and the disk was mounted at /media/usbstick, BUT it still showed the same in Settings. Being curious, I started uninstalling and reinstalling things to try to figure out what was making it work, but now I can’t get it to work anymore, no matter what I install. Also, my sdcard won’t auto-mount anymore. I think I screwed up some system files somewhere by installing and uninstalling many packages…
Attempting to mount manually, (mount /dev/sda1 /media/usb) results in “unknown filetype exfat”. Manual mount had worked one time before - I guess I messed up exfat support somehow . I installed exfat-utils and fuse-exfat from Openrepos, and have tried it with, without, and with different combinations of the various programs, but never working anymore.
Fs is exfat, labeled as hpfs in fdisk -l output.
Any ideas? Thanks
