Hi,
I want to build a NucleoTNC and connect it to my Xperia10ii via USB-C and then adress it via APRSdrois, as described here: https://mobile.twitter.com/Mobilinkd/status/1272232693854613507
Can Android apps access devices attached via USB (or would this be feasible with Waydroid?).
Thanks in advance!
Chris
No, that should be the same as other related limitations.
