USB-C to 3.5mm jack adapters known to work with Sailfish OS
Well, yes, an no. You are espousing a fragmentation of ‘recommend’, ‘how-to’ etc, into the fine grained. I’m trying to avoid repeating my experience with buying the apple dongles. Though I appreciate @Mister_Magister efforts, the fact is, it was bad PURCHASING decision. Based on quite detailed forum advice. So, had someone said to me, but, but, you’ll have to set up some event driven thingy to pop the volume in THAT case, I might have avoided it. And spared myself the 15 teuro. Or maybe not.
Sigh. Well, had you said that before your recommendation WITH NO qualifications, I might have behaved differently. IE, not bought it. Jeez.
Well sorry about that but the fact remains it’s still best price to performance :slight_smile:
Bullshit. The soutchi cheapy at less than half the price is just as good. Shall I start getting it on the scope?
And if that is the measurement stick - i have to retract this endorsement, as it will blow your ears off with IEMs.
THIS, is bullshit. Compare the graphs
sure, if you do correct measurements per standards and prove that it’s just as good, sure.
As proof that this thread makes no sense, here’s Scarlett 18i20 audio interface, 18 inputs 20 outputs, works flawlessly on sfos
[nemo@Edge30Neo ~]$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 1: USB [Scarlett 18i20 USB], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
[nemo@Edge30Neo ~]$
You can’t get actual audio to play because it would require bunch of set up but device itself works and you could actually set it up.
For reference, it’s this device
Oh nonono, the two theoreticians with no J2 are now taking over the thread explaining how apple 40% volume = gold cables and you should just trust the specifications even when 2 examples of hw complying with specs were found to misbehave (3 if you count apple kek), guise, pls post your experiences not wild theories
Edit: we heard your main theory 100% compliance and everything just works already
Um, citation? Which graphs? I don’t even yet know which DAC is actually used by which project. Are your just blowing smoke?
these graphs
Those graphs are not comparable to the products I compared.
Look, you have a penchant for publishing opinions (ie. about higher bit depths) which are patently false. I have not called you out on it in the past, since I honour the work that you do, but don’t bullshit.
Fact is, when comparing a 2 fold price difference and not having an AUDIBLE difference, cheaper wins.
If you really want me to go there, then:
  1. Which test equipment shall we choose.
  2. What source material (ie. frequency domain material) shall we choose.
  3. Where shall we publish the results that isn’t bullshit.
oh yes they absolutely are. Any argument as to why they aren’t?
oh look, another lie
I only stated truth
That’s your opinion, not a fact. Whether what your ear can hear as a difference or what some other ear might hear as a difference is personal opinion, not a fact. Only measurements can be stated as a fact.
Just do the test like the guy in article did
Gold cables
20 chars
Some people hear difference between 800€ headphones and 400€ headphones, others don’t, when you’re one of those who don’t hear the difference, stating that it’s a fact that there’s no difference, is total bullshit
Ah, different products, different dacs? What the fuck?
Ummm, well, you have claimed that higher bit depths are ‘always better’ in a blog post, have you not?
I think you have a low bar for what you consider to be truth. I would like to measure that.
It’s not even clear what hardware and software were involved in that.
so? You can’t measure and compare how different dacs measure? You can’t compare different products? The fuck?
it’s true
IIRC he posted that in different post, but i genuinely don’t care
I build audio hardware for a living. I spend 12 hours a day building analog and digital systems to produce sounds on various amplification hardware, some of my own, and a wide variety of speaker configurations. I would suggest that I’m fairly sensitive to differences in the ‘qualities’ of audio produced by a wide variety of ‘things’ over a wide variety of other ‘things’.
It doesn’t matter, what your ear hears and what your can distinguish, is your own personal experience, not a fact.
If you can’t comprehend such simple thing, then example: One guy dips hand in a water and says it’s cold, other guy dips hand in water and says it’s alright. Those are opinions, not facts. Fact is the water is at 10°C
Ok, dude. How do I reproduce this Review: Apple vs Google USB-C Headphone Adapters | Audio Science Review (ASR) Forum
I will do so, if you can tell me what:
  1. Software
  2. hardware
is required to reproduce it?
Do you have any experience with audio hardware at all? Are you kidding me? I learned to master vinyl, for god’s sake.
